Motherboard Power Transistor Temps
SUMMARY: Running T-Birds at 1.2 GHz+ speeds results in significant power transistor temps.
I decided to buy a T-Bird 1133 because of its high power output – just the thing to test heatsinks and watercoolers. Ed bought one, and after seeing how well it hit the low 1400s, I decided it was time to upgrade the cooling test bed.
Now, we’re not talking about puny 50 watt CPUs here – I ran the 1133 on an ABIT KT7 at 12.5 x 110 to get 1375. Interesting thing: Even though I selected 110 FSB in BIOS, the board ran at 114 FSB, giving me 1425 rather than 1375 (and yes, I did check more than once). I have to say the KT7 I have always throws a surprise my way (sometimes takes 3 times to boot up when I change a heatsink).
Anyhow, running at 1425 MHz and 1.9 volts gives me 86.2 watts of heat from the CPU – not trivial! I ran this with a Danger Den Cooling Cube, Be Cooling waterblock (drilled for thermocouple in the base) and Danner 1.5 submersible pump with the following results:
TEST RESULTS: T-BIRD @ 1425, 1.9 Volts
CPU Temp
Ambient Temp
Delta
C/W
MBM Temp
T-Bird @ 1425
29.2 C
22.2 C
7.0
.08
44 C
Great results, but what did interest me was the Motherboard Monitor (MBM) reading: 44 C. What it indicated was a high temp on the secondary heatpath. I felt around on the motherboard and immediately realized that the 6 power transistors were on the warm side, so I placed a thermocouple on them:
Power Transistor Temps: 44.9 C
If you feel along the socket periphery, you will notice that it is warm also. What’s happening here is that the heat from the power transistors migrates to the socket, placing an additional cooling burden on the CPU.
The point here is that as we start to push CPUs well beyond 1 GHz, think very seriously about using active cooling on your motherboard’s power transistors. I did this on the Iwill KK266, and have added a fan to the heatsink I placed over the power transistors (pic below).
Iwill
Note that the fan overhangs the heatsink and is held on by two screws. I made the heatsink by cutting an old one to fit. The six power transistors all lie in a row, so one heatsink over all of them is a good approach. I used thermal epoxy to glue the heatsink on – it’s a permanent hack!
The ABIT KT7 and KT7A has the same layout, so this can be used on it. ASUS uses a power riser, so if you want to actively cool it, it’s going to be more demanding.
Email Joe
Be the first to comment
Leave a Reply
