Sometimes you can go crazy looking for the right tool when fixing small electronic devices.
I have a great local hardware store but they’re more geared to the usual larger tool sizes. The good guys at NewerTechnology have put together a nifty assortment of small tools for the tinkerers among us.
{highslide}articles/NewertechTools/new5.jpg{/highslide}
The toolkit contains:
• Straight Blade 1.8mm
• Straight Blade 3.0mm
• Phillips #00
• Phillips #2
• Torx T6
• Torx T8
• Torx T10
• Scissor Clamp
• Tweezers
• (2) Nylon Pry Tools (aka “Spudgers”)
• Nylon Carrying Case
The tips are hardened steel…
{highslide}articles/NewertechTools/new1.jpg{/highslide}
…and magnetized:
{highslide}articles/NewertechTools/new6.jpg{/highslide}
The tops of the drivers rotate so that you can hold them in place with your index finger while using them – IMHO a must for small tools.
{highslide}articles/NewertechTools/new4.jpg{/highslide}
Included with this kit are two small plastic pry-bars (aka “spudgers”) – if you’ve ever tried to open a screen bezel or do your own battery replacement for an Ipod, these are what you need:
{highslide}articles/NewertechTools/new3.jpg{/highslide}
Finally also included are a tweezers and scissor clamp – handy for holding small parts:
{highslide}articles/NewertechTools/new2.jpg{/highslide}
All this with a nice carry case – not a bad piece of kit. Street price about $18. Worth a serious look if you’re like me – always tinkering with electronics and scurrying arround for the right small tool.
Related posts:
- Kingwin Portable 5.25″ Aluminum Hard Drive Enclosure
- JETART MiniStand Notebook Cooler
- NewerTechnology USB 2.0 Universal Drive Adapter
- Portable Apps for Flash Drives
- Running 3-Pin Fans on 7V The Easy Way
Tags: HowTo
