NPH Big
Heatsink Test – Joe
SUMMARY: Big, low noise and decent cooling.
Pic
Size: 126 x 77 mm; 60 fins; Heat Column 33 x 150 mm
The good guys at Thermal Transtech were nice enough to send a sample of their nPowerTEK NPH Big heatsink to test out. This is a bit different from other heatpipes in that the heatpipe is one large column:
Columns
Pic courtesy of nPowerTEK
The heat column runs through the fins, cooled by a 120 mm fan.
The base appears adequately flat; I used the Poor Man’s Flatness Test and it looks like there might be some high spots on it:
Base
Base
Parts that ship with the unit for Intel 775 mounting:
Parts
The Test
The NPH Big was tested on an Asus P5WD2 motherboard P4 Motherboard Test Platform with a modified Pentium D 805 to read CPU case temps (both supplied by Directron). The NPH Big was tested with the fan that is included.
Heatsink
Case Temp
Ambient Temp
C/W
On-Die Temp¹
NPH Big, 1659 rpm, <50 dBA²
41.6
26.1
0.16
50
¹MBM on-die temperatures.
²50 dBA measured 8″ from the fan intake corresponds to about 30 dBA measured 3 feet from the fan, a very quiet noise level.
Results place the NPH Big in mid-rank of heatsinks tested to date (Heatsink Ranking).
CONCLUSIONS
The nPowerTEK NPH Big does a very nice cooling job and the included fan is quiet – a nice package for decent cooling at low noise.
Thanks again to Thermal Transtech for sending this our way to try out.
Disclosure: Joe Citarella has a financial interest in a company developing thermosyphon products for electronic chip cooling.
  1. nPowerTek NPH-1000
  2. nPowertek NPH 775-140 HC
  3. nPowertek NPH 775 Tower Heatsink
  4. TTIC-NPH-201 Socket A Heatsink
  5. TTIC-NPH-101 P4 Heatsink
Tags:
