Thought I show you what I found with my Palomino, compared to T-Bird using various mobos.
OS: Windows 2000 Pro (SP2)
Memory: 1 x 256MB Crucial PC2100
CPU: 1.33GHz T-Bird; 1.2GHz AthlonMP “Palomino” core
Boards: A7V133, MSI K7T266 and K7 Master (board rev. 1.1), BIOS 1.1Final and 1.2beta2 (Palomino
support)
AGP: Creative Labs GeForce2 32MB @ 200/333MHz (default)
PCI 1: empty
PCI 2: empty
PCI 3: SB Live! Value
PCI 4: Adaptec SCSIā 2940U2W
PCI 5: NetGear FA-310TX NIC
Heatsink: Swiftech MC462A
HDDs:
CD-ROM: Plextor 40MAX (SCSI)
CDRW: Plextor 4220 (SCSI)
USB: 3Com Home Connect WebCam
Direct X 8.0a
VIA 4-in-1 version 4.29 FINAL
Detonator. 11.01 and 12.60
Desktop resolution/bit depth: 1024×768, 32bit full color
K7 Master BIOS settings:
AGP 4X enabled
Fast Writes enabled
Super Bypass enabled
Side Band enabled
Memory settings:
FAST 8-8-7-2-5-2-2 (for 133 and 140FSB)
SLOW 8-8-8-3-7-2-3 (for 150 FSB)
K7T266 settings:
R126 bridge closed with 102 SMD resistor
1.10 beta2 “b” BIOS
CAS 2.0
4-way interleave
1T command on
AGP aperture: 128
AGP 4X
AGP fastwrite enabled
AGP Sideband enabled
Marc Wessel’s WCPRSET registry tweak (use performance/stability version). I
avoided the ‘Ultra/benchmark’ version due to instability and lock-ups in 3D
benchmark and games. I do not have complete benchmarks for KT266Pro as I do
not have this board anymore.
*Note: I had some instability with the FAST settings during 150 FSB. It
would lock up in 3DMark and Q3A, so I had to turn it down just for this
test. Aside from this slight adjustment, all other tests ran superbly
without a single freeze or error. They all passed Prime95 torture test with
MP3 playing in the background.
I ran three consecutive runs on each test after each reboot. Took the best
score out of three runs and screen captured it (Print Screen key) along with
H-Oda’s WCPUID which shows the bus frequency and multipliers.
A7V133 was tested with all features maxxed as well. CAS 2 of course. (Don’t
own it any more)
Ed. note: If you don’t have Excel, you can get an Excel viewer here.
