Patriot Viper 4 DDR4-3000 MHz Memory Kit Review
Add Your Comments
At the beginning of January this year, Patriot launched their Viper 4 line of DDR4 memory. The kits are designed for Intel’s X99 chipset and come in varying quad-channel capacities and speeds. Today’s review sample is the 16 GB DDR4-3000 MHz kit (PV416G300C6QK), which consists of 4X4 GB modules. The Viper 4 series falls in the middle of Patriot’s DDR4 offerings – below the Viper Extreme Edition and above the Signature Line. Patriot has been in the memory game for many years and has released impressive enthusiast-level memory kits during this time. Let’s have our first look at Patriot’s Viper 4 memory and see how it stacks up against the competition.
Specifications/Features/Product Information
The information below is provided by the Patriot Memory product page. As we mentioned above, this kit is comprised of 4X4 GB modules rated at 3000 MHz. The kit runs at 1.35 V with timings of 16-16-16-36. The Viper 4 color scheme consists of two black stripes at the top and bottom of the main body and a red heatsink at the very top.
Patriot Viper 4 DDR4-3000 Product Information/Specifications/Features
Product Information
Product Name
Extreme Performance
Patriot Part#
PV416G300C6QK (4 x 4GB)
Description Viper 4 Series, DDR4 16GB (4 x 4GB)
3000 MHz Quad-Channel Kit
Certifications/Safety RoHS
Product Warranty
Lifetime Warranty
Unit Dimensions .28” (D) x 5.2” (W) x 1.68” (H)
.71cm (D) x 13.3cm (W) x 4.26cm (H)
Unit UPC 0815530019145
Packaging Type Blister Pack
Packaging Dimensions .98” (D) x 4.82” (W) x 7” (H)
2.28cm (D) x 12.24cm (W) x 17.78cm (H)
Net Weight .45 lbs / 208 gm
Specifications & Features
Series Viper 4
Color Black Sides / Red Top
Capacity 16GB (4X4GB) Quad Kit
DIMM Type 288-Pin NON-ECC UDIMM
Voltage 1.35V
Tested Frequency PC4-24000 (3000 MHz)
Tested Timings 16-16-16-36
Base Frequency PC4-17000 (2133 MHz)
Base Timings 15-15-15-36
Tested Platforms Intended for Intel X99 Platforms
Feature Overclock XMP 2.0
Once the kit is installed, here is what CPU-Z and the motherboard’s UEFI BIOS have to say.
CPU-Z Memory Tabs
CPU-Z Memory Tabs
UEFI BIOS SPD Table
UEFI BIOS SPD Table
The Patriot Memory marketing folks have this to say about the Viper 4 series memory kits.
Patriot Memory’s Viper 4 Series memory modules are designed with true performance in mind. Built for the latest Intel® X99 platform, the Viper 4 series provides the best performance and stability for the most demanding computer environments.
The Viper 4 series utilizes a custom designed high performance heat shield for superior heat dissipation to ensure rock solid performance even when using the most taxing applications. Built from the highest quality Build of Materials, Patriot Memory’s Viper 4 Series memory modules are hand tested and validated for system compatibility.
Available in quad channel kits, 16GB and 32GB kits, Patriot Memory’s Viper 4 Series will be offered at speeds from 2400MHz up to 3000MHz and XMP 2.0 ready. Hand tested for quality assurance the Viper 4 series is backed by a lifetime warranty.
Packaging/Product Tour
The mostly black and white retail box contains the two plastic clam shells used to keep the memory protected. The front of the box outlines a few of the Viper’s features and capabilities, while the back has a marketing blurb and Patriot Memory contact information. Both the front and back have a plastic window allowing for a sneak peek of the product. Tucked away inside the box is a small case badge type sticker.
Box Front
Box Front
Box Back
Box Back
Box Contents
Box Contents
Box Contents
Box Contents
The next series of pictures shows the Patriot Viper 4 kit laid out in different configurations. Patriot says the heatspreaders are a custom design that offers superior heat dissipation, and they certainly look impressive. Aesthetically speaking, the only negative I see is the green PCB. I think a black PCB would go a long way towards improving the overall looks of the Viper 4 modules.
Meet the Patriot Memory Viper 4
Viper 4 Laid Out
Patriot Memory Viper 4 Laid Out
Viper 4 Laid Out (Opposite Side)
Patriot Memory Viper 4 Laid Out (Opposite Side)
Viper 4 Alternate Angle
Patriot Memory Viper 4 Alternate Angle
Viper 4
Patriot Memory Viper 4 Side View
Testing for Stability at Rated Speed/Timings
Once the memory is installed in our test bed, we always begin with a stability check at advertised speed/timings/voltage. We use our new Ultra-X R.S.T. Premium USB memory tester to check for stability. Thanks to the guys at Ultra-X for providing us with the tester, and we’re proud to be one of only a few review sites that have one. The Ultra-X R.S.T. Premium is a bootable USB device that really pounds on memory for several hours and will definitely find if any instability is present. Depending on the total capacity of the memory kit being tested, it can take a very long time to complete the five passes we prefer to run. A glance at the picture below shows it took well over six hours to complete all five passes. The kit came up clean with no errors reported, so we’re confident we have a perfectly stable kit here.
Ultra-X 5 Pass Stable
For a quick in-OS stability check, we run the 32M HyperPi benchmark. Here again, everything looks good.
HyperPi In-OS Stable
Benchmarks
Here are the components used in our X99 test bed with all the comparison kits listed just below. The five kits we have in our comparison group include today’s Viper 4 review sample and four previously reviewed kits. Links are to their respective reviews.
Test System Components
Motherboard ASUS Rampave V Extreme
CPU Intel i7 5960X
Memory Various – See Table Below
Video Card EVGA GTX 780 Ti Classified
Storage Samsung 840 Pro SSD 256 GB
Cooling Custom Water
Operating System Windows 7 Pro x64
Comparison Kits
Brand Series Speed Channels Capacity Timings Voltage
Patriot Viper4 DDR4 3000 Quad 4X4 GB 16-16-16-36-2T 1.35 V
G.Skill Ripjaws4 DDR4 3000 Quad 4X4 GB 15-15-15-35-2T 1.35 V
Corsair Vengeance LPX DDR4-2800 Quad 4X4 GB 16-18-18-36-2T 1.2 V
G.Skill Ripjaws4 DDR4-2666 Quad 4X4 GB 15-15-15-35-2T 1.2 V
ADATA XPG Z1 DDR4-2400 Quad 4X8 GB 16-16-16-39-2T 1.2 V
The G.Skill DDR4-3000 MHz, ADATA, and Corsair kits were all tested using the ASUS X99 Deluxe motherboard, while the G.Skill DDR4-2666 MHz was tested on the Rampage V Extreme motherboard. Both motherboards used the memory’s XMP Profile with the CPU at its stock settings for all tests. Both of the motherboards also feature the ASUS OC Socket, so results should be consistent between the two motherboards used for testing.
The graphs below show percentage values with the Patriot Viper 4 kit (today’s review sample) being the basis and therefore, always 100%. In the scored benchmarks, a higher percentage is better, while in timed benchmarks, a lower percentage is better. Below each chart is a table with the raw data used to compile the chart.
Synthetic Testing
Beginning with AIDA64’s memory tests, we see the Viper 4 falling a tad behind the G.Skill 3000 MHz kit in the latency test (lower is better), but coming out on top of the other three kits. The copy test show the Viper 4 and G.Skill 3000 MHz kits in a virtual dead heat and well ahead of the other test samples. The write test shows very little difference between the test samples, as expected. The read test again shows the Viper 4 and G.SKill 3000 MHz kits within a whisker of each other and ahead of the rest of the field.
AIDA64 Memory Test Results
AIDA64 Memory Benchmarks – Raw Data
Kit Read Write Copy Latency
Patriot Viper 4 DDR4-3000 61665 46973 66972 65.7
G.Skill Ripjaws4 DDR4-3000 61874 46994 67752 64.0
Corsair Vengeance LPX DDR4-2800 59046 47684 56632 69.8
G.Skill Ripjaws4 DDR4-2666 60378 46997 62783 68.9
ADATA XPG Z1 DDR4-24000 59793 47921 61091 69.8
We don’t normally see much difference in performance when running SuperPi and wPrime, and that held true here as well. There was roughly a 2% difference across the board, but less than that in most cases.
SuperPi and wPrime Results
SuperPi and wPrime Test Results
SuperPi & wPrime – Raw Data
Kit SPi 1M
SPi 32M wP 32M wP 1024M
Patriot Viper 4 DDR4-3000 10.343 533.521 3.572 103.459
G.Skill Ripjaws4 DDR4-3000 10.358 535.128 3.588 101.728
Corsair Vengeance LPX DDR4-2800 10.281 529.356 3.527 101.728
G.Skill Ripjaws4 DDR4-2666 10.342 538.528 3.526 103.554
ADATA XPG Z1 DDR4-24000 10.296 543.115 3.525 103.586
Rendering, Compression, and Video Conversion Testing
Our Cinebench test results show the Viper 4 coming out on top in the R10 benchmark. The R11.5 and R15 benchmarks show very little difference between all the test samples.
Cinebench Test Results
Cinebench R10, R11.5, R15 Benchmarks – Raw Data
Kit CB R10
CB R11.5 CB R15
Patriot Viper4 DDR4-3000 44812 15.24 1409
G.Skill Ripjaws4 DDR4-3000 44800 15.17 1407
Corsair Vengeance LPX DDR4-2800 44206 15.49 1412
G.Skill Ripjaws4 DDR4-2666 44333 15.26 1401
ADATA XPG Z1 DDR4-2400 43761 15.26 1407
The 7zip compression benchmark has the Viper 4 in a dead heat with the Corsair and G.Skill 3000 MHz kits and slightly ahead of the rest of the test samples. The x264 and PoV Ray 3.73 results show all of the test samples again within a couple percentage points of each other.
7zip, x264, PoV Ray 3.73 Test Results
7zip, PoV Ray 3.73, x264 Test Results
7zip, PoV Ray 3.73, x264 – Raw Data
Kit 7zip PoV Ray
x264 P1 x264 P2
Patriot Viper 4 DDR4-3000 43496 2842.87 205.88 83.35
G.Skill Ripjaws4 DDR4-3000 43532 2847.19 205.88 83.42
Corsair Vengeance LPX DDR4-2800 43640 2903.74 208.17 84.80
G.Skill Ripjaws4 DDR4-2666 43235 2845.25 205.88 83.43
ADATA XPG Z1 DDR4-24000 42945 2849.11 204.98 83.20
As far as performance goes, the Patriot Viper 4 exhibited test results just as we’d expect. The most impressive part of our testing was that the Viper 4 kit was for the most part able to keep up with the G.Skill 3000 MHz kit, which has lower timings than the Viper 4 kit does.
Overclocking
I wasn’t expecting much overclocking headroom as my previous experience with 3000 MHz kits didn’t offer much past their out-of-box speeds. However, I was able to get the Viper 4 up to 3120 MHz using 1.45 v, but the timings had to be lowered to 17-17-17-40 in order to call the overclock stable. Lowering the timings had a negative effect on performance, and it actually took a few seconds longer to complete HyperPi 32M than when the kit was set to its XMP profile. For comparison sake, when I overclocked the G.Skill 3000 MHz kit during that review, I had to manipulate the 3rd tier timings to get any overclocking at all done, which really killed its performance. The Viper 4 kit didn’t need 3rd tier timing adjustments, so in one sense, that’s an improvement.
3120 MHz Overclock
3120 MHz Overclock
Lowering the timings didn’t offer too much headroom either, which only allowed a setting of 15-16-16-36. Interestingly enough, the time to complete HyperPi 32M again took longer to complete than when the kit was left at its XMP profile setting.
15-16-16-36 Timings
15-16-16-36 Timings
Conclusion
As DDR4 memory continues to evolve, we’re beginning to see prices reduce and higher speeds becoming the norm. When DDR4 first hit the market, you couldn’t touch a 16 GB 3000 MHz kit for under $400. Today, they are available for around $300, which is a pretty substantial drop in such a short period of time. In the case of Viper 4 DDR4-3000 MHz kit, it’s currently available at Newegg for $319. That lands it right in the middle of similar kits from other manufacturers… higher than some, less than others. Keep in mind, the Viper 4 is new to the market, and that usually means the price will fluctuate after a few weeks.
As far as performance goes, there really isn’t anything to complain about as the Viper 4 kit performed as we’d expect. Overclocking proved to be a bit of a challenge; but as we’ve found out with other high MHz kits, that seems to be expected.
Aesthetically, the Viper 4’s red and black theme is a popular color choice and would look great with any of the multitude of motherboards on the market using the same color scheme. The only gripe here would be the green PCB, but it’s not like you see an overabundance of green once the memory is installed.
Patriot Memory has a viable option in the 16 GB Viper 4 DDR4-3000 MHz kit if you’re planning an X99 system build, and it’s worthy of consideration.
Overclockers_clear_approvedClick the stamp for an explanation of what this means.
Dino DeCesari (Lvcoyote)
Leave a Reply
Discussion
  1. Seems this kit is probably Samsung-based, I briefly owned a kit of Patriot Viper Extreme DDR4-3000 with the same loose timings (16-16-16) and they used Samsung chips.
