PC Building Guide
Add Your Comments
One of the big reasons that some people have trouble building computers is that there is an absolute myriad of components out there that have certain compatibilities with other parts, which means that the combination has to be flawless for the system to work. Experienced builders can usually sort out different components according to their specs and price, but some who are new to building likely have no idea how to do this. That is where this guide comes in.
I started with a goal – the system cost should be under $1500 USD and include everything but a case, optical drives and an OS (the three things you are most likely to have already). The case and OS are things that really depend on who you are. The system should have ample horsepower to handle pretty much anything you throw at it: next gen games, HD video, possibly a little CAD, plus all the regular office tasks.
So I started shopping, using parts I had for review and a bit of my own money to put together the ultimate machine for gaming and every day tasks and so, on to the build!
CPU
I had originally though of going AMD on this build, but I had to think like a true system builder/enthusiast and remember Core2Duo! So it was socket 775 or bust and since I didn’t have the 200 smackers to drop on an E6300, I decided to go with a Pentium D. I was originally looking at the 805 but after my local computer store decided to stop restocking it, I decided to go with the 820. After checking online I found that it could do up to 5 GHz, and that was good enough for me! Now for a few pictures of this beast:
Pic
Like most Intel products the Pentium D comes in a blue/white schemed box.
Pic
Pentium D 820 +? The difference between a regular Pentium D and this one (from what I can ascertain) is that the + supports Intel VIIV.
Pic
The rear of the box sports a window so we can check out the included cooling solution.
Pic
The heatsink is quite large for a stock heatsink, but it has to be to cool down a CPU that puts out 130 watts of heat! (As much as one of those fancy new quad-cores)
Pic
The heatsink has a copper base for better heat absorption and a square of pre-applied thermal compound.
Pic
And a big heatsink for such a small CPU.
Pic
And of course the important information on the CPU itself.
And a little info on the CPU (well the whole Pentium D series:)
Pic
Pros
  • Dual-core
  • 1 MB of cache per processor
  • Supports 64-bit
  • Supports Execute disable bit
  • Is decently fast
  • Dirt cheap! (For a dual-core)
  • Very fast vs. single cores in multithreaded apps (like the Hammer editor!)
  • Is supposed to overclock like a beast (beating 4 GHZ per core)
Cons
    Based on the hot-running, power guzzling Prescott architecture
  • Is going to be forced out of the lower price bracket with the coming price cut
  • Puts out 130 watts of heat (!)
  • Is completely outclassed by Core2
Overall
I can’t recommend this processor with the huge price cut to the Core2 line rumored to be happening soon. Plus it is relatively slow compared to other processors from both Intel and AMD. So hold off buying a processor in the comings weeks, it looks like we are in for some dramatic price changes!
{mospagebreak}
Motherboard
For the motherboard, I decided upon an ASUS P5NSLI, mainly because it has support SLI and SATAII RAID. I chose ASUS because I have had no problems in any system I had one of their boards in (three so far).
Pic
The board comes packaged well, as are all ASUS products. The box mentions that the board is Core2 capable and has SLI support. On the back there is also a labeled picture of the board, so you know exactly what you are getting before you open the box.
Pic
The package includes the board, manual, SATA cables and power adapters, an SLI bridge, IDE and floppy cables, an I/O shield plate, a USB expansion slot, Q-Connectors, and the software CD.
Pic
The board features the LGA 775 CPU socket, 4 slots for up to 16Gbs of DDR2, 2 PCI-E 16x slots and a number of other features I will cover later on.
Pic
The board also has 2 IDE ports, a floppy port and 4 SATA II ports (notice the odd location of the floppy port).
Pic
The four DDR2 slots are color coded for easy installation of dual-channel memory.
Pic
Solid caps feed the CPU, and some of the voltage regulators are covered by a large passive heatsink.
Pic
Fanless Design: Zero Noise, no moving parts, stating the obvious?
Pic
The board has 2 PCI slots, 3 PCI-e 1x slots, and 2 PCI-e 16x slots that each operate at 8x in SLI mode (selected via the card you see).
Pic
Why is the floppy connector here?
Pic
On the rear I/O we have keyboard and mouse ports, a parallel port, serial port, S/PDIF out, 4 USB, gigabit Ethernet, and audio jacks.
And the board’s specs:
Specifications
CPU
LGA775 socket for Intel ® Core ™2 / Pentium ® D / Pentium ® 4 / Celeron ® D Processors
Compatible with Intel ® 05B/05A/06 processors
Intel ® EM64T / EIST* / Hyper-Threading Technology ready
* Refer to www.asus.com for Intel CPU support list
Chipset
NVIDIA ® nForce ™ 570 SLI ™ Intel ® Edition
 – NB: C19SLI
 – SB: MCP51
Front Side Bus
1066 / 800 / 533MHz
Memory
4 x DIMM, max. 16GB, DDR2 667 / 533, non-ECC, un-buffered memory
Dual channel memory architecture
Expansion Slots
2 x PCI-E x16
 – Single VGA mode: x16, x1 (Default)
 – SLI mode: x8, x8
3 x PCI-E x1
2 x PCI 2.2
SLI
Under Single VGA mode (Default):
 – 1 x PCI Express x16 graphics card on the first slot (blue)
 – 1 x PCI Express x1 card on second slot (black)
Under SLI ™ mode: support two identical SLI-ready graphics cards
ASUS EZ Selector
ASUS two-slot thermal design
Storage
2 x Ultra DMA 133/100/66/33
4 x Serial ATA 3 Gb/s
Support SATA RAID 0, 1, 0+1,  5 and JBOD
LAN
Marvell ® 88E8001 PCI Gb LAN controller
ASUS AI NET 2 network diagnosis before entering OS
Audio
ADI AD1986A SoundMAX 6-channel CODEC
Jack Sensing and Enumeration
S/PDIF out interface
ASUS AI Lifestyle Features
ASUS Q-Connector
ASUS O.C. Profile
ASUS CrashFree BIOS 2
ASUS EZ Flash 2
Other ASUS Special Features
ASUS Music Alarm
ASUS Q-Fan
ASUS Fanless Design
ASUS MyLogo2
Overclocking Features
Intelligent overclocking tools:
 – AI Overclocking (intelligent CPU frequency tuner)
Precision Tweaker
 – vDIMM: 4-step DRAM voltage control
 – vCore: Adjustable CPU voltage at 0.0125V increment
SFS (Stepless Frequency Selection):
 – FSB tuning from 133MHz up to 400MHz at 1MHz increment
 – Memory tuning from 533MHz up to 1200MHz at 1MHz increment
 – PCI-E frequency tuning from 100MHz up to 150MHz at 1MHz increment
Overclocking Protection:
 – ASUS C.P.R. (CPU Parameter Recall)
Back Panel I/O Ports
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Parallel
1 x Serial
1 x S/PDIF Out (Coaxial)
1 x RJ45
4 x USB 2.0/1.1
6-Channel Audio I/O
Internal I/O Connectors
2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1xCPU / 1xChassis / 1xPower Fan connectors
Azalia Analog front panel audio connector
System panel connector
1 x SLI selector card connector
S/PDIF out connector
Chassis Intrusion connector
CD / AUX audio in
24-pin ATX Power connector
4-pin ATX 12V Power connector
BIOS
4 Mb Flash ROM, Award BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ASUS EZ Flash 2,  ASUS CrashFree BIOS 2
Accessories
1 x SLI soft bridge
SATA signal and power cables for 2 devices
1 x UltraDMA 133/100/66 cable
1 x IDE cable
1 x FDD cable
1 x USB module
I/O Shield
2 in 1 Q-connector
User’s manual
Form Factor
ATX Form Factor, 12″x 9″ (30.5cm x 22.9cm)
Support CD
Drivers
ASUS PC Probe II
ASUS Update
ASUS Music Alarm
NVIDIA ® RIS (Remote Installation Service) application
Anti-virus software (OEM version)
USB
8 USB2.0 ports (4 ports at mid-board, 4 ports at back panel)
Pros
  • Supports SLI
  • Supports Core2Duo
Cons
  • The 570i is just a rebadged Nforce 4 with a new southbridge
  • The memory voltage only goes up to 2.1 volts (what’s the point of supporting 1200mhz memory if the voltage isn’t up to the task?)
  • Is very unstable until you play with voltages (which may be a barrier to new builders)
  • CPU voltage adjustment does nothing
Overall
Avoid this board like the plague! It is not worth the trouble. Do not associate the 570i with the 570 AMD chipset (like I did) – they are two different things. Despite what other reviews may say, if you take a peek around the Asus forum there is nothing but people complaining about this board. Do yourself a favor and get a good 650i board instead.
{mospagebreak}
Cooling
For cooling I have a CoolIt Eliminator TEC Liquid cooler – thanks to the guys at CoolIt for sending this my way. The Eliminator is not only fairly inexpensive for a liquid cooling system but it should be able to cool the Pentium D, although for cooling a CPU that puts out this much heat, CoolIt recommends their Freezone system.
Pic
The Eliminator comes in a big white box, displaying the cooling unit. Notice the anti-kinking wire that has been wrapped around the tubes. The Eliminator is based on Coolit’s MTEC technology, which uses TECs to help cool the liquid then pumps it through a CPU waterblock to cool the CPU.
Pic
Luckily while the Eliminator’s packaging doesn’t name its competitors it does tell us what type of heat load all the systems were put under to get these results. CoolIt used an FX55 or 100 watt simulated die heater. The Pentium D 820 puts out 130 watts of heat, so it should really put this system through its paces.
Pic
The detailed specifications are indeed detailed, telling us about each component and it’s function, weight and dimensions. Lucky for all of us this system is designed for use with both AMD and Intel processors
Pic
Breaking into the box, you find the users manual plus the cooling system and its components securely packaged in protective foam. The installation guide is comprehensive and printed in full color (yay!)
Pic
Included with the main cooling unit are the various clips and screws used to mount it.
Pic
And now to the cooling unit itself, you can see from this angle that it is quite long and has an awesome looking aluminum fairing on the side.
Pic
Looking in from the top we can see two of the three TECs, the pump, heat exchanger, and circuit board with a Molex connection that powers the whole contraption.
Pic
Looking in from the front end you can see the power control switch (I say power instead of fan because I think this switch also regulates the power of the TECs).
Pic
From this angle we can see the aluminum mounting bracket and the 92mm x 38mm fan that cools the heat exchanger.
Pic
Made in China? Ah well – so is everything else these days so I’m not complaining. Notice that it says CPU AND GPU Cooler, hmmm… sounds like a mod waiting to happen! Also notice that the pump is reflective (with the CoolIt logo on the top) – very cool.
Pic
That is one thick fan!
Pic
This is the first time I have ever seen an original fan badge on a cooling product (most are rebadged) – congrats to CoolIt for giving these guys some credit!
Pic
The CPU block is made of nickel-plated copper and has a small plastic cap attached to the bottom
Pic
Believe it or not, I am fairly sure this is good old AS5. It is NOT a thermal pad – do NOT touch it!
Install
This part was fairly easy, but I would recommend having an extra set of hands handy just in case. Press on to the build section for process and pictures
Performance
System on High
CPU Idle: 38ºC
CPU Load 47ºC
Noise:
At this setting the unit is very loud and is easily heard over the other fans in the case.
System on Medium
CPU Idle: 43ºC
CPU Load 53ºC
Noise:
At this setting the unit is much quieter and its sound is in tune with the other fans in the system.
System on Low
CPU Idle: 54ºC
CPU Load 67ºC
Noise:
At this setting the unit is completely silent and can barely be heard even with an ear right new to it.
Pros
  • Cools 130 watts of CPU down to under 50c (no small feat!)
  • Is incredibly quiet on low-power
  • Is very easy to install
  • No need to connect tubes, etc.
  • Good pre-applied TIM
  • Nickel plated copper block
  • 3-speed settings
  • Cool blue LEDs
  • Competitively priced with other high performance liquid cooling systems at $199.99 USD
Cons
  • Due to the system being based on TECs it cannot take over a certain heat load (over 100 watts is my guess) without drastically losing performance
  • Your case must have a 120mm rear fan mount (or space to drill holes) if you are going to install the unit
Overall
There is no doubt in my mind that CoolIt has a real winner here.
While the system could not really handle the 130 watts of heat the Pentium D was producing, I have no doubt that the system would perform exceedingly well with a CPU that produces 100 watts or less of heat, meaning that almost all CPUs on the market today will be able to be cooled down exceedingly well by this unit, the exception being Pentium Ds and the Core2Quad QX6700.
For systems with this much heat output, CoolIt recommends their Freezone system anyway, and if you have the money to drop on a quad-core you can probably afford the step up in price for the best cooling performance. The thing that really makes this system a winner is the price – $200 USD. This is what you can expect to pay for an entry-level kit from any high-quality liquid-cooling system manufacturer. That being said, I have no difficulty recommending this cooling system to both the newbie and the experienced system builder.
{mospagebreak}
PART II
Graphics
I was originally going to go with a 7950GT for this system, but while my local computer store was attempting to get one in the 320 MB version of the 8800GTS came out that was very competitively priced compared to the 7950GT, so I ordered eVGA’s Superclocked version.
Pic
:Insert Godzilla noises: This is one of the most powerful GPUs on the planet right now and I have my hands on one! This sucker comes with HDCP, 320 MB of graphics memory, a lifetime warranty and EVGA’s 90-day Step-Up program. Oh – and did I mention that it is overclocked right out of the box?
The back of the box features a list of the 8800GTS’ features, a performance comparison between it and other graphics solutions and a window and code that allow you to make sure that your card is genuine.
Pic
Did I mention that it includes a full version game? (a really good $60 retail one too).
Pic
Evga includes a ton of ways to make sure that your card has not been tampered with, including these seals on the box.
Pic
In the box you get the card, a manual, case stickers, a full version copy of Dark Messiah: Might and Magic, an S-Video card, an HDTV cable, and two DVI-VGA converters.
Pic
The card itself has a protective film on it to prevent it from getting scratched during shipping.
Pic
:drool:
Pic
The cooling system on this card consists of (from what I can tell) an aluminum base, aluminum fins and embedded copper heatpipes, a few of which have been nickel-plated.
Pic
The card is feed through a ton of all solid capacitors.
Pic
On the back of the board there are a number of chips and traces, plus the screws that hold the cooling solution tight to the card.
Pic
The card features a single SLI connector; I would love to see what a pair of these things could do in SLI!
Pros
  • Superclocked!
  • Supports DX10!
  • Wicked fast!
  • 90 Step-up program!
  • Lifetime warranty!
  • Only uses one PCI-E power connector
  • Priced the same or in some cases cheaper than other 8800 GTS 320mb cards
  • Includes a full version game (a good one nonetheless)
  • Is not as big as you think! (about the same size as a 6800)
  • Good cooler design that is quiet and exhausts hot air out of your case
  • Makes all your friends with 7900’s or 7950’s shake in their boots
Cons
  • I didn’t buy one sooner!
Overall
There is no doubt in my mind that this is one of the best video cards out there right now. Coming with a decent overclock, a lifetime warranty, a full version game, and the 90 Step-up program at the same price of many stock clocked cards with 3 year warranties and no game, this card is, I have no doubt, the best video card for the price on the market today. My compliments to EVGA for making a hell of a video card and pricing it so I have no alternative but to buy it!
{mospagebreak}
PSU
A good steady power flow is very important in a system like this, so I used a 730 watt PSU from Hiper – thanks to the guys at Hiper for sending this my way.
Pic
The Hiper 730watt non-modular PSU comes in a simple, but elegant cardboard box.
Pic
It comes with a manual, mounting hardware, a power cable, expansion cables, and the PSU itself.
Pic
Only a single 80mm fan cools the whole PSU.
Pic
It features no less than four 12-volt rails putting out 672 watts and 64 amps across them.
Pic
The huge number of leads on the PSU should be more than enough for any enthusiast
Pros
  • Quiet (Could not be heard over the Eliminator on low)
  • Very stable (I have had no power related stability issues)
  • 730 watts
  • High quality black cable sleeving
  • Classy flat black finish
  • Huge number of leads
  • Good price (about $140 USD)
  • Four 12 volt rails
Cons
  • None that I can think of
Overall
This PSU should be on your short list if you are building a new system or if you just need a new PSU. It isn’t modular, but it’s easy to hide the leads and they don’t look bad anyway. Its rock solid stable (I run this system at 100% CPU load all the time – rock on SETI!) and it’s nice and quiet. Its not flashy but it does what it’s supposed to do – perform well.
Memory
For memory, 2 gigs was a must, so in went a 2 Gig SuperTalent DDR2-1000 MHz memory kit – thanks to the guys at SuperTalent for sending this my way.
Pic
These modules come dressed in these awesome blue heatspreaders with SUPER*TALENT written in silver letters down the side. They are packaged in clear plastic with a cardboard insert on the back.
Pic
These modules are rated for 1000 MHz at 5-5-5-15 timings with 2.2 volts, if all goes well I will hopefully be able to test the modules at these speeds. Also notice that these modules are made in the good old U.S. of A
Pic
This modules really look slick dressed in their blue heatspreaders, notice that there are bumps in the heatspreaders to increase surface area and thus cooling potential.
Pros
  • Really cool heatspreader design
  • Extreme performance
  • Works with an ASUS board (which is surprising considering ASUS’ narrow QVL list for ram)
  • Runs at high speeds and low latencies at less than rated voltage (3-3-3-7 at 667mhz with 2.1 volts)
  • Should be very fairly priced (judging from the rest of SuperTalent’s products)
  • According to my testing just going from 4-4-4-9 at 533mhz to 3-3-3-7 at 667mhz gives an up to 17% performance increase (in 3dmark03). I have no doubt that running these modules at 1000mhz could boost system performance by over 20%, which is incredible.
Cons
  • If you don’t like blue you are out of luck
Overall
Unfortunately the board was holding me up on frequency and I could not get the modules stable past 667mhz, but I was able to test the modules at tight timings of 3-3-3-7 and I did not have a single hiccup. This leads me to believe that I could easily hit 1000mhz at rated timings with a better board, and probably even higher with a little extra voltage. But even running at the lower speeds the performance jump from a cheap set of DDR2 would be huge. Judging from SuperTalent’s aggressive pricing on there other products I would guess that you could find this kit for a very fair price. Considering the quality, stability and speed offered by these modules I can do nothing but recommend them.
{mospagebreak}
Part III
Case Prep
Before I put the new system in my Thermaltake full tower I decided that it was necessary to cut some “speed holes” to route cables. Thanks to my friend Matt and a Dremel 400XPR for making this part of the project possible.
Pic
Marking out the cuts.
Pic
After cutting and dressing the holes with electrical tape.
Pic
Not too shabby!
Pic
The Build!
Pic
This is the pile of parts we are starting out with. It includes all the above parts plus 3 Western Digital 160 GB SATAII NCQ HDs, one WD 160 GB IDE drive, an LG DVD burner, a floppy drive, my USR8054 Xtreme G 125 mbps wireless card, and my Creative Audigy 2 Value sound card.
Pic
The first thing to go in is the PSU – no clearance issues here.
Pic
Lockin er in!
Pic
The PSU cables have all been routed behind the mobo tray and the ATX cable is coming out the proper hole.
Pic
Not so tidy back here.
Pic
In go the HDDs, the SATA cables go in between and the power cables go off the side
Pic
Not too shabby!
Pic
This is starting to get ugly!
Pic
DVD, floppy and IDE hard drive in okay, all the cables are hooked up.
Pic
Everything looks good up front (besides the gaping hole:)
Pic
Ewwww…..
Pic
This is starting to get a little ugly.
{mospagebreak}
Pic
Its time to dress up the motherboard and get it installed!
Pic
In went the CPU without a hiccup.
Pic
The RAM from SuperTalent was installed next.
Pic
And we are good to go!
Pic
On go the standoffs for the Eliminator block; the standoffs are separated from the board with nylon washers, no chance of shorting anything out here!
Pic
The board is in and the havoc back here has been reduced to acceptable levels, but what does the front look like?
Pic
Looks good up hear too! Note that all 3 SATA, 2 IDE, 1 floppy, front panel connections and both of the board’s power connections are hooked up.
Pic
On goes the block! Note that this is where the installation got a little tricky and I required another set of hands.
Pic
I drilled holes to allow the 120 mm spaced holes to work with my case’s 92 mm rear fan. Unfortunately, only one lined up properly, but it has been through a month and 2 LAN parties hanging from 1 screw, so it should be okay. But note that because of the way my case is formed, the unit is being supported on 3 sides anyway.
Pic
The Eliminator has been fully installed!
Pic
Here you can see how the case is supporting the Eliminator.
Pic
And in went the 8800! This thing is starting to look like a complete system!
Pic
Now with the Audigy and Wifi it is a complete system!
Pic
Looks pretty slick (notice the relatively few visible cables).
Pic
We are done!
{mospagebreak}
Running Into Problems
It goes without saying that basically ever build has its problems; we can only hope that they are small and easily fixable. Well let’s just say that this build had some pretty big problems.
Number 1 was that is was impossible to set up a RAID 5 array using the 3 SATA HDDs. If you take a quick peek online, you will notice that there are multiple reports of people having problems setting up a RAID using WD drives on an Nvidia chipset board. I ran into this exact problem: While I got the utility loaded up okay and the array built, getting Windows installed on the array proved impossible. I tried multiple RAID floppies but to no avail – it looks like I’m running without the RAID for the time being.
Number 2 is that the board does not seem to accept any voltage adjustment. Now while it SHOULD go up to 1.6 volts, I have not been able to get past 1.28 volts. Let me tell you about what I did to investigate this:
I had the CPU voltage set to automatic and the voltage was moving between 1.26 and 1.34 volts. Now if you know about CPUs and the voltage that they use, a fluctuation that big is not good. So I upped the VTT voltage from 1.25 to 1.35. This stabilized the voltage at between 1.264 and 1.28 volts, so it was time to up the voltage and do some overclocking!
So I upped the Vcore from 1.3 volts to 1.4 volts (as I was constantly getting instability with overclocking attempts at lower voltages) and booted into Windows. I started up CPUZ and see to my dismay that the voltage was exactly where it was before, fluctuating between 1.264 and 1.28 volts. I though to myself that there was no way that was true and that CPUZ must be messed up.
So I started up Everest and guess what? 1.25 to 1.28 volts. Then I started thinking that maybe the software reading was screwed up, so I decided to try overclocking some more. Again I hit a brick wall. Just to see if this was a problem at 1.4 volts or if it was a linear decrease in voltage, I tested it at 1.45 volts. Again I got 1.264 and 1.28 volts.
It would seem that this board is broken! Or more likely, that ALL P5NSLI’s are broken. If you check out the ASUS forum on this board, it is nothing but complains and very poor overclocking results all around – I think I may have found the problem!
Benchmarks
Test
Stock – memory at 533 MHz, 3-4-4-9 timings
Memory at 667 MHz 3-3-3-7
Memory at 667 MHz 3-3-3-7, videocard 650 MHz core, 2000 MHz memory
Full OC
Memory at 667 MHz 3-3-3-7, videocard 650 MHz core, 2000 MHz memory, Chipset transfer at 5x
Aquamark
75790
80963
81781
82610
PCMark05
4575
4963
4987
5195
3DMark06
Overall: 5917
SM3.0: 3061
CPU: 1318
Overall: 6054
SM3.0: 3301
CPU: 1357
Overall: 6211
SM3.0: 3118
CPU: 1348
Overall: 6231
SM3.0: 3314
CPU: 1355
3DMark05
7998
7765
8317
8317
3DMark03
20083
23551
26159
26197
SuperPi 1M
48s
46s
46s
46s
Percentage Improvements
Benchmark
Stock
Memory OC
Memory, VGA OC
Full OC
Aquamark
0
7
8
9
PCMark05
0
8.5
9
13.5
3DMark06
Overall: 0
SM3.0: 0
CPU: 0
Overall: 2.3
SM3.0: 8
CPU: 3
Overall: 5
SM3.0: 2
CPU: 2.2
Overall: 5.3
SM3.0: 8.2
CPU: 2.8
3DMark05
0
-3
4
4
3DMark03
0
17
30
30.4
SuperPi 1M
0
4
4
4
Average Improvement
0
5.85
8.03
9.65
Comments
From these benchmarks you can really see what high speed, low-latency memory can do for your system performance. I saw an average improvement of 5.85% and a maximum improvement of 17% by running at higher speeds and lower latencies. This really shows that high performance memory should be a priority in your next build.
{mospagebreak}
Time Benchmarks
Function
Old Rig: Athlon XP at 2.2 Ghz and 1 Gb of DDR 350
New Rig
Boot Time
37.35 sec
32.73 sec
Firefox Load Time
Initially: 17.37 seconds
Average: 4.38 seconds
Initially: 3 seconds
Average: 1.5 seconds
BF2 Level load time
Initially: 1 min/ 44.7 sec
2nd run: 45.56 seconds
3rd run: 43.16 seconds
4th run: 43.36 seconds
5th run: 42.81 seconds
Initially: 1 min/ 12sec
2nd run: 24 seconds
3rd run: 22 seconds
4th run: 22 seconds
5th run: 23 seconds
Shutdown Time
16.32 seconds
38 seconds
Restart Time
1 minute 18.03 seconds
2 minutes
Comments
In the time benchmarks, the new system spanked the old one in a couple of areas. The biggest improvement is in the load times of Firefox right after getting into Windows. The times are much faster but I believe some of this has to do with the lack of anti-virus software on this machine at the moment. Once Norton has been installed, those times will likely slow down considerably.
On the other hand, the BF2 scores would likely not be affected by anti-virus software in the same way. The reason that it is so much faster is because all of the data is going to RAM instead of a page file, with the RAM being much faster. The boot time was a little faster, likely because I’m using a SATAII NCQ drive compared to an old-fashioned IDE drive.
The other times were much slower. Why? The shutdown was slower because programs are not shutting down when they stop responding and I am being prompted to close them. The old system was streamlined using a Windows XP tuning guide from www.pcstats.com and does not prompt to close these programs, it just closes them by itself. The restart time is so long for two reasons:
  1. The P5NSLI BIOS is EXTREMELY slow and it sits around detecting drives, etc. for about 30 seconds;
  2. I currently am dual-booting the system, because one of my HDDs died and the OS on it is still being detected (don’t ask me how).
Overall
I have had a couple of months to use this system everyday and after the instability problems were fixed, using the system is an incredibly enjoyable experience. The dual-core powers through map editing tasks in the Valve Hammer editor and video up conversion. The 8800 slices through games like a hot knife through butter. Here’s a list of the apps it has sliced to bits on max settings (note this is at 1280 x 1024 resolution and that I am running Windows XP):
  • BF2
  • BF2142
  • Empire Earth II
  • Supreme Commander
  • F.E.A.R.
  • Titan Quest
  • Need For Speed: Carbon
  • Any game from Valve (CS:S, Half-life 2, etc.)
The only game that I had so much as a hiccup on was Dark Messiah: Might and Magic. My guess is that it’s because the levels are very large with lots of enemies and it’s pushing the Source Engine to its absolute limit. It might also benefit from more RAM, considering that it happily gobbles up a full 2 gigs.
Speaking of RAM, the 2 gigs allows me to run system tasks, anti-virus software etc., while gaming without problem (as we speak, I have a system cache of 1.2 gigs with 800 megabytes used, but I am running SETI and iTunes). I notice that I can run a lot more programs without slowdowns then with 1 gig RAM.
Conclusion
All in all this is a great system for any purpose, and while I had quite a number of hiccups in the beginning, it has ended up being an excellent main system. If I could do anything differently I would have gone with a better board, either a 650i or 680i. Whatever board you choose, don’t just trust the reviews – check out the manufacturers forums or other forums to see what people who BOUGHT the board have to say.
Don’t worry about the validity of this guide, though – I bought the board! This is true for any computer product – make sure you read everything you can from everyone you can; this is how you form a good opinion of your future purchase. So in conclusion, I had a lot of fun putting this system together and I hope you enjoyed reading it.
Side Notes:
I will be contacting ASUS in the coming days to see what’s up with this board and why so many people are having problems. If it comes down to it, I will use a bit of journalistic leverage to get the answers out of ASUS. Then I will update the article and if what ASUS says is groundbreaking, I’ll post it up on the ASUS forums. Hopefully they are more helpful than the horde of ASUS forum members say they are.
If anyone has any additional benchmarks they would like me to perform (as long as they are free and don’t involve moving the earth) or other games to test out (as long as I have it already or am willing to purchase it), please contact me by email and I will do my best to accommodate you. Also, if you have any questions about the benchmarks that were performed or if you think, “screenshot or it didn’t happen” you can email me.
Finally, if you have a RAID of Western Digital drives running on an Nvidia chipset with or without problems, PLEASE email me – I would really like to see if this is a genuine problem or if it is being blown out of proportion.
Pricing
For those of you who are looking for a system for gaming, work or other leisure activities, you will be happy to know that this system comes in at less than $1500 US (without a case or optical drives).
Pricing (From Newegg): CPU: $95
Cooling (price from FrozenCpu.com): $199.99
Motherboard: $98.99
PSU: $139.99
VGA: $304.99
Memory: ~$300 (estimation)
HDD’s: $62.99 each
Total (Without HDD’s): $1139
Total (With HDD’s): $1328
Acronyms
If you read through the guide and you are confused about some of the acronyms I used, I will clarify all of them here:
RAID: Stands for Redundant Array of Inexpensive Disks; for more information on how RAID works and its benefits check this out HERE.
SLI: Nvidia’s technology for using two video cards working together to improve graphics performance; for more info check this out HERE.
TEC: Thermal Electric Cooler; for more information check this out HERE.
Thank You
I would like to send out a big thank you to the guys at SuperTalent, CoolIt, and Hiper for being so patient in waiting for this article and for providing the awesome gear that made it possible – thank you!
Kyle Lunau
Leave a Reply
