Pentium 4 1.8A Shoot Out
Add Your Comments
– Three different chips and motherboard chipsets tested– Jason
I was given the chance to assemble two P4 1.8A systems this week and I grabbed the opportunity to clear some of my doubts regarding different batches of 1.8A.
You may ask what are the doubts??
There are rumors which states that SL68Q is being produced with an optically shrink core, it operates at a cooler temperature and is more overclockable. These are my doubts.
As all of us know, P4 1.8A comes in two batches namely SL63X and SL68Q. Majority of SL63X were made in Malaysia while SL68Q originated from Malaysia and Costa Rica. Currently, I own a SL63X, therefore I specially hunt down two different nationality SL68Q to do a mini P4 1.8A shoot out.
Some information on tested P4 1.8A:
Production Code	: SL63X
FPO/Batch		: L208A955 (week 8)
Pack Date		: 06/04/2002
Nationality		: Malaysia
Purchase Venue	: Best Bargain
Production Code	: SL68Q
FPO/Batch		: 3219A012 (week ?)
Pack Date		: 05/30/2002
Nationality		: Costa Rica
Purchase Venue	: Costronics
FPO/Batch		: L222A573 (week 22)
Pack Date		: 07/09/2002
Purchase Venue	: Bell
These SL68Qs were bought on Monday 12/08/2002. During my search in Sim Lim Square, I found the following batches of CPUs. If you know those unknown batches, kindly share with us your findings. Perhaps someone could go check out those unknown shops (these are computer shops in Singapore):
1.	Chamoxa - unknown
2.	IO Data - unknown
3.	Hardware Place - unknown
4.	Visit - unknown
5.	Skylet - Can't be bothered to check them out.
6.	Fuwell - SL68Q, week 22, Malaysia
7.	Costronics - Refer to above information.
8.	Cybermind - Bundle price is too expensive!
9.	Bliss - SL63X, week forgot, Malaysia
10.	Best Bargain - SL63X, week 09, Malaysia
11.	Unlimited - SL63X, week 19, Malaysia
12.	Laser - No Stocks
13.	Voodoo Pro - SL68Q, week ?, Costa Rica
14.	BELL - Refer to above information.
15.	Superpet - Unknown (My guess is SL68X Costa Rica)
Okie, that’s all to my findings. Hope it helps.
Let’s start the test!
Objectives: To find out whether SL68Q operates at a lower temp than SL63X and it’s overclockability.
Hardware Used For Testing:
CPU
3 * P4 1.8A
Motherboard
ABIT SA-7 (SIS 645DX) , ABIT BD7II ( Intel 845E ) Gigabyte IGX
(Intel 845G)
Memory
Kingston PC 2100 256MB DDRAM
HSF
Stock Intel HSF (Only one HSF is used through out the test)
VGA Card
Leadtek Geforce 2-MX
OS
WIN XP
Stability Test
Prime95 & 3Dmark 2001
All three CPUs ran 133FSB without any problem straight out of box. Therefore I started the test at 133FSB.
{mospagebreak}
Jason
Setup Test 1: ABIT SA-7 @ 133FSB 2.4Ghz
Settings: CPU: DRAM 4:3
CPU
Vcore
Temp Idle/Full
Condition
SL63X
1.5V
36/51 C
Stable
SL68Q (Malay)
1.5V
36/51 C
Stable
SL68Q (Costa)
1.5V
36/51 C
Stable
Setup Test 2: Gigabyte IGX @ 133FSB 2.4Ghz
Settings: CPU: DRAM 4:3, AGP/PCI: 66/33
CPU
Vcore
Temp Idle/Full
Condition
SL63X
1.5V
37/51 C
Stable
SL68Q (Malay)
1.5V
36/51 C
Stable
SL68Q (Costa)
1.5V
37/51 C
Stable
Setup Test 3: ABIT BD7II @ 133FSB 2.4Ghz
CPU
Vcore
Temp Idle/Full
Condition
SL63X
1.5V
47/65 C
Stable
SL68Q (Malay)
1.5V
48/65 C
Stable
SL68Q (Costa)
1.5V
48/64 C
Stable
The thermal probe is obviously not doing its job on ABIT BD7II. The temperature was offset by approximately 11 degrees! By touching the HSF on all three setups, my guess would be that both ABIT SA-7 and Gigabyte IGX were more accurate. The range of temperature, which all 3 CPU are operating at default voltage and stock HSF is approximately 36-51 degrees.
How accurate they were, I’m not sure. I’m still not technically skilled to accurately measure its temperature yet. But it doesn’t matters as results speak for itself.
As you can see from my findings, all 3 CPUs operate at almost the same temperatures. SL68Q might be optically shrunk in real fact (I don’t know) but its temperature is actually equivalent to SL63X. This is something that I am conclusive and positive about.
Setup Test 4: ABIT SA-7 @ 140FSB 2.5Ghz
CPU
Vcore
Condition
SL63X
1.5V
Stable
SL68Q (Malay)
1.5V
Stable
SL68Q (Costa)
1.5V
Cannot get past POST
Setup Test 5: Gigabyte IGX @ 140FSB 2.5Ghz
CPU
Vcore
Condition
SL63X
1.5V
Stable
SL68Q (Malay)
1.5V
Stable
SL68Q (Costa)
1.5V
Setup Test 6: ABIT BD7II @ 140FSB 2.5Ghz
CPU
Vcore
Condition
SL63X
1.5V
Stable
SL68Q (Malay)
1.5V
Stable
SL68Q (Costa)
1.5V
Surprisely, the Costa Rica chip cannot get past POST on all three setups @ 140FSB, default voltage. In terms of overclockablilty, Costa Rica is out of the competition. I was quite taken aback from this result as I thought all 3 CPUs should do well. Both SL63X & SL68Q(Malay) had no problems running at above settings.
The temperature is not included in this test as its not recorded down. Since the Costa Rica is eliminated, we have left with 2 chips to play with now.
{mospagebreak}
Jason
Setup Test 7: ABIT SA-7 @ 150FSB 2.7Ghz
CPU
Vcore
Condition
SL63X
1.5V
Cannot Boot
SL68Q (Malay)
1.5V
Not Stable, lots of errors
Setup Test 8: Gigabyte IGX @ 150FSB 2.7Ghz
CPU
Vcore
Condition
SL63X
1.5V
Cannot Boot
SL68Q (Malay)
1.5V
Cannot Boot
Setup Test 9: ABIT BD7II @ 150FSB 2.7Ghz
CPU
Vcore
Condition
SL63X
1.5V
Not Stable
SL68Q (Malay)
1.5V
Not Stable
From above results, I found that:
  1. Both CPUs fail to attain stability in all 3 setups.
  2. Gigabyte IGX is not meant for extreme overclocking, hence both CPUs couldn’t boot.
  3. With BD7II, both CPU fail at the several initial test of prime95.
Setup Test 10: ABIT SA-7 @ 150FSB 2.7Ghz
CPU
Vcore
Temp Idle/Full
Condition
SL63X
1.65V
NIL
Cannot Boot
SL68Q (Malay)
1.65V
NIL
Cannot Boot
Setup Test 11: Gigabyte IGX @ 150FSB 2.7Ghz
CPU
Vcore
Temp Idle/Full
Condition
SL63X
1.65V
NIL
Cannot Boot
SL68Q (Malay)
1.65V
NIL
Cannot Boot
Setup Test 12: ABIT BD7II @ 150FSB 2.7Ghz
CPU
Vcore
Temp Idle/Full
Condition
SL63X
1.65V
53/65 C
Stable
SL68Q (Malay)
1.65V
54/66 C
Stable
From above results, I deduce:
  • Both 1.8A requires 1.65V to attain stability @ 150FSB.
  • Even increasing Vcore on SA7 & IGX does not produce any positive results. My guess for Abit SA7’s failure: Lack of feature to lock PCI/AGP. At 150MHz FSB, PCI bus is running at 37.5MHz, while AGP is at 75MHz.
  • ABIT BD7-II is a good mobo to overclock your P4
Although Vcore was increased by 10% of the default voltage on ABIT BD7-II, Winbond doctor reports the voltage fluctuating around 1.58V.
{mospagebreak}
Jason
FINALE
Since both SA7 & IGX held hands with the Costa Rica chip and were eliminated from the competition, there was only one motherboard left to play with.
Setup Test 13: ABIT BD7II @ 155FSB 2.79Ghz
CPU
Vcore
Temp Idle/Full
Condition
SL63X
1.65V
53/65 C
Not Stable
SL68Q (Malay)
1.65V
53/65 C
Not Stable
Setup Test 14: ABIT BD7II @ 155FSB 2.79Ghz
CPU
Vcore
Temp Idle/Full
Condition
SL63X
1.725V
56/69 C
Stable
SL68Q (Malay)
1.725V
56/72 C
Not Stable
Setup Test 15: ABIT BD7II @ 160FSB 2.88Ghz
Settings: CPU: DRAM 4:3, AGP/PC: 66/33
CPU
Vcore
Condition
SL63X
1.725V
Cannot Boot
SL68Q (Malay)
1.725V
Cannot Boot
SL68Q temperature lower than SL63X?
I don’t think so…
This is my conclusion for all above tests:
Throughout these tests, I always mislead myself that SL68Q (Malay) is gonna’ be a brilliant chip – but these tests proved me wrong! In terms of temperature, it operates at the same temperature with SL63X. This is something that I’m conclusive about.
In terms of overclocking, SL63X proved me wrong. It reached stability at 1.725V core @ 155FSB, but SL68Q (Malay) failed to achieve the same level.
One point I would like to share and note down is:
BD7II + SL63X @ 155FSB 1.725Vcore
CPU @ full load reports : 69 degrees
Motherboard temperature reports : 78 degrees
Condition : Stable
SL68Q(Malay) @ 155FSB 1.725Vcore
CPU @ full load report : 72 degrees
Motherboard temperature reports : 84 degrees
Condition : Prime95 failed
This is something I found strange. With two identical setups, both motherboards report different temperature. I did both tests at midnight and it’s got nothing to do with ambiant temperature. If you have observed closely enough, at test 14, SL68Q was operating 3 degrees more than SL63X! I tred re-seatting the SL68Q, but reports are still identical.
This was something that I cannot explain!
Both 1.8As did well to reach 2.7Ghz but I suspect it’s the heat issue that’s preventing both CPUs to advance past 160FSB. At 160 FSB, the HSF was real hot and I estimate it’s about 60++ degrees. I would love to lift both CPUs to higher grounds but my friend is still working on my custom made waterblock. I’m quite positive that via reducing more heat on the CPUs, both CPUs have high chances of hitting 3Ghz.
Wait! Don’t be mislead by my reports. I’m not saying that SL63X > SL68Q in terms of overclockability. In overclocking, it’s all a matter of luck. I do believe that I was unfortunate to hunt down a poor Costa Rica CPU.
CPUs of the same batches and production week yields different results. It does not indicate that via purchasing a renowned week/batch of CPU, it will guarantee you success in overclocking. It all boils down to luck.
All P4 1.8As should reach 133FSB at default voltage easily. Is SL68Q is a great CPU to overclock?
Results speak for itself.
Read and judge for yourself.
SUMMARY TABLES
ABIT SA-7
P4 1.8A
133 FSB 1.5Vcore
140 FSB 1.5Vcore
150 FSB 1.5Vcore
SL63X /
Stable
36 C Idle
51 C Full
Stable
Cannot Boot
SL68Q
(Malaysia)
Stable
36 C Idle
51 C Full
Stable
Not Stable
Lots of errors
SL68Q (Costa Rica)
Stable
36 C Idle
51 C Full
Cannot Get Past POST
Cannot Boot
Gigabyte IGX
P4 1.8A
133 FSB 1.5Vcore
140 FSB 1.5Vcore
150 FSB 1.5Vcore
SL63X
Stable
37 C Idle
51 C Full
Stable
Cannot Boot
SL68Q (Malaysia)
Stable
36 C Idle
51 C Full
Stable
Cannot Boot
SL68Q (Costa Rica)
Stable
37 C Idle
51 C Full
Cannot Boot
ABIT BD7-2
P4 1.8A
133 FSB 1.5Vcore
140 FSB 1.5Vcore
150 FSB 1.5Vcore
SL63X
Stable
47 C Idle
65 C Full
Stable
Failed Prime95 at several initial tests
SL68Q (Malaysia)
Stable
48 C Idle
65 C Full
Stable
SL68Q (Costa Rica)
Stable
48 C Idle
64 C Full
Cannot Boot
ABIT BD7-2
P4 1.8A
150 FSB 1.65Vcore
155 FSB 1.65Vcore
155 FSB 1.725Vcore
160 FSB 1.725Vcore
SL63X
Stable
53 C Idle
65 C Full
Failed Prime95
53 C Idle
65 C Full
Stable
56 C Idle
69 C Full
Cannot Boot
SL68Q (Malaysia
Stable
54 C Idle
66 C Full
Failed
Prime95
54 C Idle
66 C Full
Failed
Prime95
56 C Idle
72 C Full
Cannot Boot
SL68Q (Costa Rica)
Cannot Boot
Not Tested
Not Tested
Not Tested
Jason
Leave a Reply
