The German website hardware-infos.com (Google translation) has scraped some performance numbers from the BOINC database on AMD’s upcoming Ontario accelerated processing unit (APU). The Bobcat architecture is most closely comparable to Intel’s Atom, where the name of the game is low power. As such, the numbers aren’t anything mind-blowing, but it does beat the Atom D10 processor in floating point speed and integer speed. Using two other AMD CPU’s, the guys at hardware-infos.com deduced that the Ontario is probably clocked at 1.4 or 1.6 GHz. Another interesting note is that the Ontario reports an odd 488 KB of cache while the Atom D10 has 512 KB. I’d suspect that this is just a glitch since it is an engineering sample.
(table adapted from hardware-infos.com)
| CPU | OS | Clock [GHz] | Integer Performance | Floating-point performance | Performance (vs. Ontario) |
| Ontario | Server 2008 R2 | 1.40 to 1.60? | 3.047 GIPS | 1.351 GFLOPS | - |
| Atom D510 | Windows 7 x86 | 1.66 | 1.892 GIPS | 0.735 GFLOPS | 58% |
| Athlon X2 II 250U | Windows 7 x86 | 1.60 | 3.465 GIPS | 1.591 GFLOPS | 115% |
| Phenom X4 II 965 BE | Windows 7 x64 | 3.40 | 8.452 GIPS | 2.792 GFLOPS | 242% |
Continue reading at hardware-infos.com (Google Translation) or bit-tech.com for more details.
- splat
Tags: amd, apu, bobcat, ontario
08-01-10 03:19 AM
08-01-10 09:32 AM
08-01-10 11:50 AM
08-01-10 07:35 PM
08-01-10 07:54 PM
If bobcat can have higher performance while maintaining similar power draw and heat production, THEN it is competition.
08-01-10 07:59 PM
08-02-10 02:10 AM
