PolarFLO Universal Waterblock
Add Your Comments
SUMMARY: Very nicely made, although aluminum construction and high resistance may compromise its performance.
PFLO
Mounts for Socket 423, 462, 478 and 603.
The nice folks at Horse of Iron, Inc. sent me a sample of their entry into watercooling, the PolarFLO Universal Waterblock. This is an all aluminum waterblock consiting of two pieces: The top, with machined-in nipples, and the base. The base features a spiral water channel. The retail version ships with 6′ of 3/8″ OD, 1/4″ plastic ID hose, plastic hose clamps, plastic bolts for motherboard mounting and instructions.
The block itself measures 2.75″ x 3.75″ x 1″ high. The inside diameter of the nipples measures about 4mm (3/16″), a tad on the small side. Considering its design, I would speculate that this is a high resistance design that will require a good pump.
The base
Base
looks great – finished to a mirror shine. It appears very flat and will aid its performance.
Overall, the build quality appears first rate.
CONCLUSIONS
Very well made, although aluminum construction and small diameter nipples may compromise its performance.
Email Joe
Leave a Reply
