Pump-Off
A test of selected waterpumps – Joe
SUMMARY: System resistance takes a BIG toll in waterpump flow rates.
Pumps
The good guys at Xoxide.com were nice enough to send a bunch of waterpumps to test out:
  • Eheim 1048 – 10 watts
  • Eheim 1250 – 28 watts
  • Hydor L20 – 14 watts
  • Hydor L30 – 23 watts
  • Via Aqua 1300 – 28 watts
Eheim is a well known brand in watercooling circles, Hydor and Via Aqua less so. The Via Aqua is noteworthy for all its accessories:
Accessories
I particularly like the ball valve with “fill tube” (upper left) – for a closed loop system, this greatly simplifies bleeding the system; this can also be done using the intake nipple shown as the bottom left. Considering its price is about half that of the others, the Via Aqua deserves a look.
The Test
I assembled two watercooling setups:
Each pump was fitted with supplied intake/outake nipples; the filters and filter housings were removed.
I then immersed each pump completely, ran each until all bubbles were cleared and then timed how long each took to fill a quart container (three times for each pump). The only difference was the pump – everything else remained the same for each pump. In addition to the pumps listed, I included a Beckett G150APCP (not a current model – 60 watts) – a centrifugal pump rated at 150 gph (the rest are mag-drives).
Test Results
High Resistance
Pump
Measured gph
Rated gph
Percent M/R
H Max   ft
Hydor L30
34.5
320
11%
6.4
Beckett 150
32.6
150
22%
na
Via Aqua 1300
31.6
343
9%
5.7
Eheim 1250
31.1
317
10%
6.6
Hydor L20
26.1
185
14%
4.4
Eheim 1048
25.5
158
16%
4.9
Moderate Resistance
Pump
Measured gph
Rated gph
Percent M/R
H Max   ft
Hydor L30
53.9
320
17%
6.4
Beckett 150
53.2
150
35%
na
Eheim 1250
49.5
317
16%
6.6
Via Aqua 1300
49.3
343
14%
5.7
Eheim 1048
43.0
158
27%
4.9
Hydor L20
39.2
185
21%
4.4
Note: All pumps are mag-drive except the Becket (centrifugal).
Much better, but nowhere near ratings a 0 head. Of particular interest is the higher ratio of the Beckett pump to its rated capacity compared to the mag-drive units. All pumps were reasonably quiet, although the Eheim 1250 had a noticeable hum – sound dampening (eg, mounting on foam) is necessary.
CONCLUSIONS
Waterpump ratings and H Max are important selection criteria to consider when purchasing for a watercooling system. However, critically important is the overall resistance of the system. Systems with small nipples will exact a high toll to flow rates compared to those which use larger (3/8″ to 5/8″) sizes. Any “chokepoint” constricting flow will exact a high toll.
On a price/performance basis, the Via Aqua 1300 is a clear winner, although as a new brand, I have no data on reliability or longevity; the Hydor L30 is a good performance choice, with attractive pricing compared to Eheim.
Thanks again to Xoxide.com for sending these samples our way.
Manufacturer websites:
Hydor
Eheim
Becket
  1. Hydor Seltz L30
  2. Fuel Pump Water Pump
  3. $13.32 Supreme Pondmaster Mag-Drive Utility Pump 2
  4. Eheim 1046 In-line Water Pump
  5. CPU Water Pump Shootout
Tags:
