If you’re looking for a review of Gigabyte’s 890FXA-UD5 with AMD’s Thuban X6 and super high end graphics, there’s a really good one posted here. If you want to see Gigabyte’s 890FXA-UD5 turn a wimpy 2.7GHz single-core sissy into a 4.2GHz+ dual core beast, you’ve come to the right place. I will do some Thuban testing with this board in the near future though. So while this review will be short and to the point, the follow up article will be more extensive as far as overclocking and performance results are concerned.
First Look
| CPU | AMD Phenom II / Athlon II / Sempron AM3 Processor |
| Chipset | Northbridge: AMD 890FXSouthbridge: AMD SB850 |
| Hyper Transport Bus | 5200 MT/s |
| Memory | 4 x 1.5V DDR3 DIMM sockets supporting up to 16 GB of system memory Dual channel memory architecture Support for DDR3 2000(OC)/1333/1066 MHz memory modules |
| Expansion Slots | 2 x PCI Express x16 slots, running at x16 (PCIEX16_1, PCIEX16_2) 1 x PCI Express x16 slots, running at x8 (PCIEX8) 1 x PCI Express x16 slots, running at x4 (PCIEX4) 2 x PCI Express x1 slot (All PCI Express slots conform to PCI Express 2.0 Standard.) 1 x PCI slot |
| Multi-Graphics Technology | Support for 2-way/ 3-way ATI CrossFireX™ technology |
| LAN | 2 x Realtek 8111D chip (10/100/1000 Mbit) Support for Teaming Support for Smart Dual LAN |
| Audio | Realtek ALC889 codec High Definition Audio 2/4/5.1/7.1-channel Support for Dolby Home Theater Support for S/PDIF In/Out Support for CD In |
| Storage Interface | South Bridge: 6 x SATA 6Gb/s connectors supporting up to 6 SATA 6Gb/s devices Support for SATA RAID 0, RAID 1, RAID5, RAID 10 and JBOD GIGABYTE SATA2 Chip: 1 x IDE connector supporting ATA-133/100/66/33 and up to 2 IDE devices 2 x SATA 3Gb/s connectors supporting up to 2 SATA 3Gb/s devices Support for SATA RAID 0, RAID 1, and JBOD JMicron JMB362 chip: 2 x eSATA 3Gb/s connectors (eSATA/USB Comobo) on the back panel supporting up to 2 SATA 3Gb/s devices Support for SATA RAID 0, RAID 1 and JBOD ITE 8720 chip: 1 x floppy disk drive connector supporting up to 1 floppy disk drive |
| USB | South Bridge: Up to 14 USB 2.0/1.1 ports (8 on the back panel, including 2 eSATA/USB Combo, 6 via the USB brackets connected to the internal USB headers) NEC D720200F1 Chip: Up to 2 USB 3.0/2.0 ports on the back panel |
| Form Factor | ATX Form Factor; 30.5cm x 24.4cm |
Removing the 890FXA-UD5 from the box, the first thing we see is the white and blue color scheme typical of Gigabyte motherboards. Next, we see the UD5 has a nice, neat layout.
There’s a lot going on around the CPU socket, and although it’s neat, it’s also a little crowded. For anyone overclocking this board on air or water, this is not a problem, but it may make insulating for sub ambient cooling a hassle. Also, the DDR3 slots are a little close to the CPU for my liking, so we may run into clearance issues with tall DIMMs and an oversized CPU heatsink. Another thing to consider is condensation in the inner memory slots under sub ambient cooling. Here we see the memory slots have been pushed over to make room for the onboard power and reset buttons, some power handling circuitry, and the included floppy and PATA connectors.
The 8-pin CPU power connector is easily accessible, even with the huge MOSFET heatsink hanging out right next to it.
In addition to the 6x SATA 3 6Gb/s ports, Gigabyte has thrown in the usual GSATA2 for some extra storage options.
The onboard Clear CMOS button makes life much easier for the serious overclocker. Gigabyte put this one in a pretty good spot, between the SATA and PATA connectors. On some of their boards it’s located out back on the I/O panel. This is a feature that has become commonplace on Gigabyte’s mid to high end products.
With Gigabyte’s On/Off charge, you can charge you iPhone, iPad, ect. with the computer in sleep mode, hibernation, or even turned off. I actually use this feature to charge my phone every night.
Four full-size PCI-E slots is almost always a good thing. From the specs above (as well as common sense), we already know we’re not going to be able to run four graphics cards in 16x mode on this board, or any similar board from any manufacturer. I’m only saying this because if I don’t I’ll get eight dozen people asking if all of the slots are 16x. The important thing to note is that the board does support Tri-Fire (3-way Crossfire).
So who still uses a PS2 keyboard or mouse? Lately I’ve seen a few motherboards excluding the PS2 slot altogether, but for that one unique case where you need one, Gigabyte went ahead and threw a combo PS2 port in. This has actually been pretty common on Gigabyte motherboards for quite some time now. Since some of them (in my experience anyway) have issues with a USB keyboard at first, this has come in handy for me countless times. We also see two USB 3.0 ports on the I/O panel, dual gigabit LAN, and tons of audio and storage options.
Gigabyte always has stylish, functional, and unique heatpipe assemblies and I wasn’t expecting this motherboard to deviate from this.
Here we see the top two full-size PCI-E slots are indeed wired for 16x, the 3rd one for 4x, and the bottom one for 8x.
Testing
- AMD Sempron 140
- Gigabyte 890FXA-UD5
- 2x2GB Kingston HyperX DDR3 2000MHz, BDBG chips
- HD 5870
- OCZ 1000w PSU
- Sub-ambient cooling
I said this was going to be some quick testing, and I meant it. The reason for this is Gigabyte also sent me an X58A-UD3 for some extra testing, and between that and GO OC 2010 NA Finals, I chose to run the Sempron testing on this for now (since I’m quite impressed with the results), move on to the X58 board, go to GO OC 2010 NA Finals, finish the X58A-UD3R, and then grab a nice Thuban and do some follow up testing with this board and some LN2.
I have no idea how many Sempron 140′s I’ve bought in the past year to get a head start on reviewing various AMD motherboards. They’re around $30 at Microcenter, and I always end up selling them for half that after finishing a review, thinking I’ll never possibly have a use for them. So when this board arrived, I promptly went to Microcenter to buy a Sempron 140. Again. Anyway, none of the 140′s I’ve purchased to date unlocked. The first thing I tried, after installing Windows and getting all of my benchmarking apps installed, was going straight to the core unlocking section of the UD5′s BIOS. I enabled core unlocking, booted into Windows, and checked CPU-Z, which showed two processing cores. A 1024m wPrime run showed there were no apparent stability issues so I kept going. I ended up with this for a good 24/7 setup, provided adequate CPU cooling.
3.9GHz was about the highest I got completely stable with the second core locked.
So I decided to drop the temps to a few degrees below freezing point with some extra LN2 I had left, and here are my results. I’ll definitely be revisiting this at some point in the near future.
Final Thoughts
My experience so far with the 890FXA-UD5 has been a blast. I haven’t put any hex-core monsters under the cold, and I haven’t done any serious game testing. But, I haven’t had this much fun overclocking anything in a long time, and that’s what this hobby is really about for me. So what have I shown here really? Well, for starters I’ve shown you a ton of cool features the 890FXA-UD5 has to offer. I’ve also shown that if you want to do any overclocking and unlocking of some budget AMD chips, this board will not disappoint. I’d like to thank Gigabyte US for letting me test this product. I’ll be back with more results when I get another Phenom II X6 to go with my HD 5870.
- sno.lcn
Related posts:
- MSI 890FXA-GD70 Motherboard Review
- Gigabyte P55A-UD6 Review And Testing
- Sneak Peak: Gigabyte X79 Motherboards
- USB 3.0 Testing on the Gigabyte UD3R and UD6
- Gigabyte 990FXA-UD7 Motherboard Review
Tags: 890fx, AM3, amd, Core Unlocking, gigabyte, overclocking, Sempron, UD5
08-20-10 12:52 AM
08-20-10 01:08 AM
08-20-10 01:35 AM
Are you gonna sub-zero bench it sno?
08-20-10 02:35 AM
08-20-10 11:50 AM
08-20-10 07:36 PM
08-20-10 07:40 PM
