RAM - 512 MB Single vs 1024 MB Dual Channel
Add Your Comments
Worth doing? – Kyle Lunau
After recently purchasing another stick of RAM for my system, I figured I would measure performance before and after so the rest of you can make educated decisions about upping your RAM. Enjoy!
The System used for this test is as follows:
  • Asus A7N8X motherboard
  • AMD Athlon XP 2500+ processor at 2.3 GHz and 1.825 volts
  • Maxtor 40GB 7200RPM drive
  • Western Digital 160 GB 7200RPM drive
  • PNY Nvidia 6800 GS AGP w/ stock clocks
The testing was carried out as follows:
  • In both tests RAM was run at 175 MHz, 3-3-3-7 timings and 2.6 volts
  • 3DMark 2001 SE was run on highest settings and 1280 x 1024 resolution
  • 3DMark 2003 was run with 1024 x 768 x 32 resolution and optimal settings (the non-pro versions settings are not changeable)
  • 3DMark 2005 was run with the same settings as 3DMark 2003 for the same reason
  • Aquamark 3 was run with 1024 x 768 x 32 on very high detail with no AA and 4x Aniso
  • Load times were an average of 5 tests, boot 2 tests and reset and shutdown 1 test
  • BF2 level load was Strike at Karkand Singleplayer with bots on easy
  • PCMark was run with the system tests only
  • Firefox average was taken starting right after entry to Windows
Benchmarks
Test
512 MB Single Channel
3DMark 2001 SE
13,590
13,671
3DMark 03
9,700
9,504
3DMark 05
4,434
4,485
3DMark 06
2,075
2,077
AquaMark 3
49,465
49,805
PCMark 04
3,789
3,805
PCMark 05
3,282
3,361
BF2 Max Playable – Resolution: 1280 x 96
Terrain: High
Effects: High
Geometry: High
Texture: Medium
Lighting: Medium
Dynamic Shadows: Medium
Dynamic Light: Medium
AA: Off
Texture Filtering: Medium
View Distance: 100%
Terrain: High
Effects: High
Geometry: High
Texture: High
Lighting: High
Dynamic Shadows: High
Dynamic Light: High
AA: Off
Texture Filtering: High
View Distance: 100%
Boot Time
41.88 seconds
37.35 seconds
Firefox Load Time
Initially: 17.20 seconds
Average: 4.46 seconds
Initially: 17.37 seconds
Average: 4.38 seconds
BF2 Level load time
Initially: 4 min/ 44.1 sec
2nd run: 47.78 seconds
3rd run: 30.48 seconds
4th run: 27.51 seconds
5th run 30.54 seconds
Initially: 1 min/ 44.7 sec
2nd run: 45.56 seconds
3rd run: 43.16 seconds
4th run: 43.36 seconds
5th run: 42.81 seconds
Shutdown time
17.81 Seconds
16.32 seconds
Restart time
1 minute 16.30 seconds
1 minute 18.03 seconds
WOW!! I would have to say the extra 512 MB is definitely worth it just from the reduction in BF2 load times!
Although I didn’t include it in the testing, I also found that the extra RAM greatly reduced load times in Counter Strike: Source as well. In general use, the extra RAM could not really be noticed though and most of the tests I ran showed only modest increases in performance. But I have to say the gig is good to have in BF2!
All in all I think this proves that for today’s latest games – or newer titles at least – the full gig really makes a difference!
Kyle Lunau
Leave a Reply
