Reeven Ouranos Heatsink Review
Add Your Comments
Reeven seems to be making quite a splash. The company describes themselves:
REEVEN is a newly established international manufacturer of PC related products. REEVEN’s product lines includes the best quality of advanced CPU coolers, cooling fans, PC cases and many other items. The target of our products will be a wide range of audience under our philosophy “Professional Quality Gears”, for products that will withstand the highest demand.
So, they are offering a range of fans, heatsinks and cases to us enthusiasts. In this review we will look at Reeven’s Ouranos, which is Greek for ‘the heavens’ or ‘celestial.’ Does this heatsink provide ‘celestial’ cooling? Let us investigate.
00Introduction
The Ouranos is a single tower cooler. It has a single 140 mm fan pushing air through it. The fan has a nominal speed of 1700 RPM. The heatsink comes with a low-speed adapter which reduces that to 1300 RPM. Reeven sells the fan separately as the Coldwing 14.
Reeven describes the heatsink’s features:
OURANOS is the CPU cooler with 140 mm quiet PWM fan, it is easy to upgrade to maximum efficiency with 2nd fan.
Long-shape AL [aluminum] fin allows maximum heat dissipation
Slim structure without conflicting with RAM zone gives wide range of compatibility
6 high-quality heatpipes guarantees superior performance
They don’t mention the fact that two of the heatpipes are 8 mm in diameter.
Specifications & Treats
Now, let’s dig a bit. First, the specifications:
Model Number RC-1401
Socket INTEL: LGA 1150 / 1151 / 1155 / 1156 / 1366 / 2011 / 2011-V3
AMD: AM2 / AM2+ / AM3 / AM3+ / FM1 / FM2 / FM2+
Overall Dimension (W)143 x (H)161 x (D)95 mm
Fan Dimension 140 x 140 x 25 mm
Heatpipe 4x Ø6 mm + 2x Ø8 mm
Fan Speed 300~1700 (300~1300*) RPM
Air Flow 16.3~92.4 (16.3~69.9*) CFM
Static Pressure 0.002~0.091 (0.002~0.048*) inchH2O
[0.5 – 2.3 mmH2O, 0.5 – 1.2 mmH2O*]**
Noise Level 5.8~36.4 (5.8~24.7*) dBA
Weight (with Fan) 1030 g
*Equipped with SSA(Speed Switch Adapter) to lower the noise & RPM rate.
**Note that the static pressure conversion to mmH2O [in brackets] was added, not provided by Reeven.
Now, Reeven puts all of this on their website. The treats: the user manual and a helpful fan installation video are on the website as well. It even illustrates a problem you might have, and how to fix it, quickly, without words. Very nice, Reeven. Keep it up.
1401-b
Packaging & the Ouranos
The Ouranos comes in a slick-sided retail box, covered with pictures, diagrams and print – a veritable treasure trove of information about the heatsink.
Front of box
Front of box
Back of box
Back of box
Open the box, and you find a smaller box of smaller parts. Remove that and you have the heatsink and its fan. You won’t inflict much damage on the base of the heatsink, since it’s covered with a sticky label. The fan cable has four wires, which tells you right then that it’s a PWM fan.
Small Parts box off
Small Parts box off
Bottom View
Bottom View
A side view of the Ouranos shows the 4-wire fan cable again, as well as giving us a good look at one of the fan clips. Let’s tilt it over and come closer so we can look at the heatpipes. The center two are Ø8 mm heatpipes with the rest are Ø6 mm.
Side View
Side View
Underside
Underside
A view of the fan through the fin stack shows us that the fins are not very close together and not too far apart. A close-up of the heatpipes show that they are encased by finstack material. The only way heat is going to get out of those heatpipes is through the aluminum of the fins. Is the fin stack’s grip tight enough to pass that heat through without any impediment? Our testing will find out.
View Through the Fin Stack
Hidden Heatpipes
Hidden Heatpipes
The contact surface – you might call it the bottom – of the heatsink is mirror-like enough that you can see beams reflected on its surface. You can tell from the wing-nut’s reflection that the surface is not a perfect mirror, though.
Bottom of the Heatsink
Before we mount the Ouranos, let us see how much convexity it has. I have a simple rule here: The more convexity, the less time the heatsink spends on my CPU. The first picture shows just a little convexity aligned with the airflow, not too bad. The second picture shows the convexity crosswise to the airflow. Whoops! Too much. This heatsink will spend just the minimum amount of time on the CPU.
Razor Aligned with Airflow
Crosswise to Airflow
Now, this should mean nothing to you. A reviewer’s problems are not your problems. If a heatsink’s bottom is well-curved, it’s a problem for me: I have to reuse that CPU for a number of heatsinks. But for you, if you use a heatsink with a mild convexity (and the convexity here is mild), it gets you better cooling. If your CPU and the heatsink conform to each other, you get better contact. This is a good thing.
Accessories & Installation
We can see the speed reducer (an accessory), four “silicon” (silicone rubber?) washers and the backplate sitting on the manual. The rest of the first picture shows the small parts – going counter-clockwise, the LGA 775 spacer (a sticker), two fan clips, a tension screw, a tiny wrench, another tension screw, four through-shafts, the mounting bar (no slots on this for sliding screws), two nuts, two more fan clips and a small package of TIM. You must cut that open with a pair of scissors. Inside the mounting bracket we have the four LGA-2011 spacer/screws, four regular spacers and two nuts. What makes this interesting is that some manufacturers provide slots on the mounting bar to accommodate Intel and AMD. Here, the AMD through-bolts and spacers attach in different places on the mounting bracket, allowing for invariant tension screw positions. See the manual for details. Good Design.
In the next picture we see the “silicon” washers in action. The through-shafts have cams on them to prevent their turning. The rubber washers squeeze on and hold them in place. The washers also hold the backplate away from the motherboard and cushion it.
Small Parts
Small Parts
Washers on Backplate
Having put together our backplate assembly, we stick it up through the motherboard. While you hold it in place, you pop on the spacers. You then screw on a nut or two. That will hold it so you can screw on the other nuts. The manual shows you how to lay down the mounting bracket … three separate times. They want you to get it right.
Up Through the Motherboard
Mounting Bracket
Mounting Bracket
The Ouranos attaches itself with a torsion pressure. No springs. Take a close look at that steel. The mounting bar is grooved not to bend and the mounting bracket has thick steel. Combined with the marked convexity, this heatsink has the potential for putting a lot of pressure on the center of the CPU.
21
Torsion Mount — No Springs
The first picture shows the gap between the RAM and the push fan. The second picture shows the RAM’s heatsinks are indeed in front of the push fan.
Does Not Interfere with RAM
Behind the RAM
Behind the RAM
Testing Setup
CPU Intel i7 4790K @ 4.5 GHz
Vcore Set to 1.23 V, read at up to 1.248 V
Vrin Set to 1.8 V, read at down to 1.704 V
GPU Intel HD Graphics 4600, integrated into the i7 4790K
Motherboard Gigabyte Z97X Gaming-7
RAM Crucial Ballistix Sport Ultra Low Profile; 2 x 4 GB – 8 GB total
SSD Samsung 840 EVO 500 GB + 1 TB
PSU Seasonic SS-460FL 460 W Fanless
Heat Stress Software Linpack with AVX2 – LinX 0.6.5 user interface
Operating System Windows 10, 64-bit
Core Temp Log Real Temp
Ambient Temp Log Digital TEMPer USB Thermometer, with logging software
Package Watt Log Intel Power Gadget 3.0
Sound Pressure Meter Tenma 72-942
Reeven provided the Ouranos. The other comparators were provided by their respective OEM’s, except for a Prolimatech Megahalems, which was purchased retail at the end of 2009, and a Prolimatech Genesis and a Noctua NH-D14 SE2011 both purchased retail at the end of 2013. Each heatsink was mounted on the night before testing. This gave the TIM most of a day to do any migrating it was going to do.
Linpack runs in surges. When the temperature is graphed, you see ragged plateaus. In looking for cooling solutions, you want to know how well a heatsink cools those plateaus. So the temps under 70 °C (the valleys) are ignored in analyzing to core temps.
Each test run was 30 minutes in duration. The last 20 minutes of each run was measured, and the core temperature logs were analyzed in Open Office spreadsheets. An Intel chip reports its temps in one degree increments, so for best accuracy these reports should be averaged in aggregate. Here the core temps were measured once a second, resulting in 1200-line spreadsheets. Three test runs were averaged.
The digital thermometer measuring air temp reported its measurements in increments of 0.1 °C. The ambient temperature was measured every five seconds, resulting in 240-line spreadsheets. The mean ambient temp was subtracted from the mean core temps, resulting in a net temp for each run. The net temps were then averaged.
The sound pressure level was measured 1 meter from the heatsink, with the motherboard set vertically, the way it would in your case. The ambient noise for this testing was 31 dBA. So the net SPL is the sound pressure level measured at 1 meter, less 31 dBA.
Results of Testing the Ouranos
The Reeven Ouranos was the best cooler tested in this rig:
Ouranos
The question one must ask is “Why?” This was no fluke. What you see is the average of three runs. I did one interesting thing: I held my hand downstream from the heatsink. The air was hot! Since I record the ambients for these runs, I know that the ambient was 22.4 °C, which means the air flowing out from that heatsink was more than 75.8 °C! So yes, it was doing its job. We must conclude that the convexity was just right to transfer heat, the heatpipes had a really good contact with those fins, and that the thickness of those fins and their spacing was just right. Let us not forget the two Ø8 mm heatpipes. Whatever the engineers did at Reeven, they did it right.
19
Conclusion
The Ouranos is one great heatsink. It is a single tower heatsink and still, it does a great job cooling. It seems that single tower heatsinks are making a comeback. First, the Noctua NH-U14S has been doing as well as the tandem tower heatsinks in some reviews. Then, the Noctua C14S with heatpipes oriented vertically did amazingly well. Next, the Scythe Ninja 4 beat the tandem tower rigs in my review. Now the Reeven Ouranos beat even that. I am putting the D15 and the D15S on my rig between test runs for other heatsinks, and they are cooling as well as they always have. I am testing my overclock to make sure the system is making just as much heat as it did for the other heatsinks. No doubt about it: the Reeven Ouranos is one devil of a heatsink. It pours out the heat.
The heatsink bottom, the contact surface, is a little convex. This is more of a problem for me than it is for you. The mounting bar is loose, but without slots for the tensioning screws, the mount is OK. It could be easier, but it is OK.
Mounting the Ouranos is straightforward. Overall, the Ouranos is a fine heatsink.
20MSRP: $49.95
Ouranos Pros
  • Online Manual
  • Online Fan Installation Guide
  • Fan Clips and Unclips easily
  • Cools like the devil
Ouranos Cons
  • Sleeve Bearing Fan
Click the stamp for an explanation of what this means.
Ed Hume (ehume)
Leave a Reply
Discussion
  1. ddotto
    Might this cooler interfere with RAM slots on the X99 MB?
    Look at the photographs in the review again. Also look at the diagram.
    ddotto
    And, will it accommodate RAM w tall heatsinks? Reeven's site doesn't offer dims for clearance between CPU and heatsink.
    Why did you buy RAM with tall heatsinks? I had to dig up an old kit for the review. Always get low profile or utra-low profile RAM.
    Might this cooler interfere with RAM slots on the X99 MB? And, will it accommodate RAM w tall heatsinks? Reeven's site doesn't offer dims for clearance between CPU and heatsink.
    Yea I keep hearing about CF/SLI not being worth doing. I been debating if I should just leave the system as is since is working fine anyways. Next GPU step up for me will have to be a GTX 980ti or new AMD GPU when they are out. Was even considering a 295x2 but I was told today that I will run into the same CF issues even with a single card.
    Running 2 GPU in is problematic in the best of conditions and CPU cooler needed is not an issue. Case airflow removing GPU heated exhaust and supplying GPUs and CPU cooler intakes with uncontaminated cool air is the challenge.
    I don't mind helping, but all you need to do is look at the measurements of Ouranos to figure out if it will fit or not.
    doyll
    EVGA X99 Micro2 is only 63mm center CPU to near side of PCIe socket. R1 is 70mm
    If I wanted to downgrade on the cooling but still have a good enough cooler to run dual cards. Which cooler should I get? I normally keep my system OC to 4.2 or in some occasion 4.5 since temps never reach even during stress test pass 68C.
    Can the Reeven Ouranos RC-1401 fit perfectly on my motherboard? I like the looks of it too.
    ITAngel
    Question, Would the R1 Ultimate block the first PCIe on a EVGA X99 Macro motherboard?
    ehume
    But if I was on a budget, I'd consider the Ouranos. At least, I'd read all the reviews and make a decision. Your own mileage will certainly vary.
    Agreed.
    Some variance is expected, but this much... well if peeps buy it they can gives us their own say in the matter ?
    You're confused. I was blown away. Remember, this system also shows the Ninja beating the NH-D15 and NH-D15S.
    Also, I am using Linpack with AVX2 and harvesting the plateaus rather then averaging the entire trace. This maximizes the heat you get from any particular overclock. I don't know if this is relevant or not, but that is one way my reviews differ from other reviews on the web.
    I have been watching heatsink reviews for years. They do vary. Not only that, but Skinnee Labs showed us that mounts matter. But I did re-test the NH-D15 and got within a fraction of a degree of the previous mount, so it is a consistent finding. As shown by some 2006 testing at Overclockers, mount pressure makes a huge difference. That is one reason I look at springs -- which indicate that the manufacturer is staying at Intel's recommended 50 lbf. Having no springs allows a heatsink mount to exceed this. That is why I don't leave a heatsink like this on my test system.
    Putting my hand behind the heatsink was a way of feeling the heat directly. I didn't believe my own findings. As noted by Blaylock, the 8mm heatpipes may make a difference. Personally, I think the the whole combination -- convexity, mount pressure, heatpipes and fins -- makes a difference. Why this differs from other results: there are always outliers.
    At bottom, I think we must accept that different people have different systems that respond to different heatsinks differently. So you must read all of them, and make up your mind what you want.
    As for me, I keep all of my better heatsinks. For my personal use I tend to fall back on the Noctuas because they are known good and because they have the easiest of all mounts to use. But when I am testing various fans I use the Megahalems because it has no fans of its own and because it is sensitive to differing fans . . . and because it is so easy to re-mount the Noctuas.
