Sandboxie is a great freeware program offering virus and malware isolation within Windows.
I have been meaning to do an article about Sandboxie and yesterday’s article on internet threats reminded me of it and so here it is. What this program does is to build a protected area within Windows such that any virus or malware is isolated within this wall, preventing it from infecting your PC. It’s a small download (548 K) and if you are concerned with your PC getting infected, this is an easy way to build an effective firewall inside Windows.
After installing the program, you will see this opening screen:
There is a nice Tutorial and I would recommend you take the time to learn the finer details. I elected to use Sandboxie from the start:
As I was running Firefox, I restored the previous session:
You will notice a lag when opening the browser – maybe 5 seconds or so. This will happen every time and only when you first open the program under Sandboxie – I did not notice any difference in load times after the first screen. Note that in the upper left hand corner you will see Sandboxie running:
Running Sandboxie in your Programs list opens up these options:
You will also see a Sandboxie icon (extreme right side) as a Start item; you can elect to run your browser (or any other program, such as for emails) under Sandboxie or run it outside of Sandboxie as before:
Lots of flexibility, easy to use, well maintained and free to a degree – after 30 days you will get a nag-screen offering a purchase option. Buying Sandboxie gives you the following:
- “Is personal and is not transferable into computers or electronic media that you do not own;
- But does permit you to use Sandboxie on any number of computers that you personally own;
- Removes the nag screen that initially appears after you have used Sandboxie for more than 30 days;
- Enables the Forced Programs and Forced Folders features;
- Allows you to run programs in more than one sandbox at the same time (see message SBIE1303);
- But does not entitle you to any guaranteed level of technical support.”
Costs about $30 and basically it amounts to a site license. Trying it out is a no-brainer.
Related posts:
- Gadwin Printscreen Freeware Screen Capture Program
- Revo Uninstaller – A Freeware Gem
- DiskDigger Freeware File Recovery Program
- CleanMem – Freeware Memory App
- DeskPins Freeware App
Tags: Software
