SansDigital 5-Bay 3.5″ IDE / SATA Hard Drive Rack
A neat way to organize and power a bunch of hard drives – Joe
SUMMARY: A neat way to organize and power a bunch of hard drives.
Pic
The good guys at SansDigital were nice enough to send a sample of their 5-Bay IDE / SATA Hard Drive Organizing Rack to try out.
Key Features
  • Aluminum frame construction
  • Can be powered by ATX power supply, 20 or 24 pin
  • 120 mm cooling fan
  • Securely holds five hard drives
  • On/Off power switch
  • Size: 6.7″ x 6.9″ x 7.6″ H; Weight: 1.2 lbs; stackable
A view from the back shows the fan and rails on which the drives sit:
Inside
Lots of holes to keep air flowing:
Side
The view from the front with one drive installed:
Front
The cage features a 20/24 pin ATX power plug for ample hard drive power:
Power
Once a power supply is hooked to the cage. there’s a green LED to indicate power:
Power Lit
The drives are held in place by screws designed to ride in the rails:
Screws
After sliding in the drive, it’s held in place by snapping a plug against the drive:
Plug
In use, there is no way the drive is loose – it’s as secure as if it were bolted in place.
CONCLUSIONS
If you have a bunch of drives and routinely switch among them, this drive cage may fill the bill – a neat way to organize and power a bunch of hard drives.
Thanks again to SansDigital for sending this our way.
  1. iStarUSA X-Rack Removable SATA Hard Drive
  2. Rosewill SATA/IDE USB 2.0 Drive Adapter
  3. Hard Drive Mobile Rack
  4. Kingwin Mobile Hard Drive Rack KF32
  5. MAPower KC-31 3½” SATA Hard Drive Enclosure
Tags:
