Scythe Kamaboko
Heatsink test – Joe
SUMMARY: Good choice for CPU cooling.
Scythe
Size: 96 x 94 x 92mm; Weight: 700 grams.
The good guys at Scythe were nice enough to send a sample of the Kamaboko CPU Cooler for a test spin. It includes a rheostat controlled 92 mm fan which spins from 1000 to 3800 rpm. Mounting options include gear for Socket 478/775 P4 Prescott 3.6G+, Athlon64/64+, Socket754/940/939 and 3800+ (Not for 370/A).
Mounting is straight forward – there are four clips which engage the P4 retention bracket. I found the spring pressure to be fairly high – not unduly so, but not so easy to articulate with fingers only.
Parts that ship with the unit allow for multiple mounting options:
Parts
The base is well finished and polished:
Base
When I ran my nail over it, I could not feel or hear any ridges.
I noticed some gaps between the heatpipes and the copper base:
Pipes
Contact area is critical to performance, and gaps such as these diminish performance.
THE TEST
The Scythe Kamaboko was tested on an Acorp 4S845A motherboard with a modified P4 1500 to read CPU case temps.
TEST RESULTS – Acorp 4S845A Motherboard
Motherboard
CPU Case Temp
Ambient Temp
Delta
C/W
MBM Temp
3763 rpm, 65 dBA²
30.2 C
19.8 C
10.4
0.18
28 C¹
2503 rpm, 54 dBA²
32.1 C
20.3 C
11.8
0.20
30 C¹
1074 rpm, <50dBA dBA²
38.7 C
20.3 C
18.4
0.32
35 C¹
¹MBM on-die temperatures.
Die Simulator results place the Scythe Kamaboko in the mid-upper rank of P4 heatsinks tested to date (Heatsink Ranking).
CONCLUSIONS
Scythe’s Kamaboko Heatpipe is a good choice for CPU cooling. The rheostat is a nice touch – at its lowest speed, the fan is almost noiseless – a good idle setting.
Thanks again to Scythe for sending this our way.
²Note that manufacturers measure fan noise usually 3 feet from the fan.
Email Joe
