Speeze CopperRock Heatsink
Add Your Comments
A low noise, mediocre heat remover.–Joe
SUMMARY: Another lower noise heatsink, the Speeze “CopperRock” may be acceptable for Socket A cooling with its stock fan.
Speeze¹ sent samples of some of their latest heatsinks for a test; of particular interest was the “CopperRock” unit. This is an all copper heatsink of modest proportions:
Speeze
Measurements: 63×60×42 mm high; weight about 300 grams.
The fan is a 60 x 15mm unit rated at 23 cfm @ 5000 RPM, with noise at about 32 dBA. I found it to run faster – I measured it at 5700 rpm, so the unit I had might be pumping out a few cfm more than this. I measured noise at 63 dBA 8″ from the fan’s intake; this is slightly more noise than a YS Tech 26 cfm fan, but nowhere near a Delta 38. It ships with a small tube of thermal grease that has 25% silver.
The clip is an OEM type – you must use a screwdriver to mount it on the socket lug. As OEM clips go, this one is fairly easy; the indent for the screwdriver is deep and wide.
Base
The base is smooth and flat.
Side
Looking at it from the side, you can see how the fins are constructed and attached to the base. The fins are folded into shape and then soldered to the base. There are 28 fins in total, measuring 23/32″ x 2 3/8″. This translates to about 96 inches², or 0.66 ft² surface area. Compared to other units on the market, fin surface area is on the low side.
Top
Looking down into the Speeze, you can see that airflow through the fins should be relatively high; while not measuring it for this test, airflow does feel higher and is a key component of its effectiveness. This design trades off surface area against airflow through the fins.
Clip
The clip channel has two inserts that serve to index the clip – this means that every time you mount the CopperRock, it will sit exactly the same, as the heatsink can not move along the clip’s axis. This is a good move, as it prevents the heatsink’s base from contacting the cam box (the high part of the socket) when you mount it correctly; we’re seeing more of this in heatsinks.
THE TEST
I prepared the Speeze CopperRock by boring a hole completely through the base so I could epoxy a thermocouple above the CPU. The thermocouple is attached to an Omega HH23 Digital Thermometer. Ambient temps were measured with a thermocouple placed about 1 inch from the fan’s intake. I used Prime 95 to stress the CPU on an Iwill KK266, BD133 (MBM temps are on-die) and Abit KT7. Arctic Silver grease was used in all tests. CPU Case Temp is the temp at that point where the CPU contacts the heatsink, CPU Back Temps are measured by a thermocouple on the center back of the CPU.
In addition, the Speeze was tested on the Simulated CPU Die Tester at 100.5 watts. This is the “purest” test of a heatsink’s performance as extraneous factors, such as secondary heat path effects, are not included.
TEST RESULTS
CPU/Motherboard
CPU Case Temp
Ambient Temp
Delta
C/W
MBM Temp
CPU Back Temp
T-Bird @ 1200/Iwill KK266+ (70 watts)
43.5 C
23.4 C
20.1
0.29
39 C
50.8 C
T-Bird @ 1200/Iwill KK266+ 40 cfm fan (70 watts)
41.8 C
23.5 C
18.3
0.26
36 C
47.0 C
Duron @ 1000/Abit KT7 (63 watts)
42.5 C
24.1 C
18.4
0.29
42 C
NA
PIII @ 933/Iwill BD133 (25 watts)
32.4 C
24.1 C
8.3
0.32
39 C
NA
Simulated CPU Die @ 100 Watts
55.7 C
23.5 C
32.2
0.32
NA
NA
Delta = CPU temp – Ambient Temp
C/W = Delta / CPU Watts
Interpreting C/W: For every watt the CPU radiates, the heatsink will cool the core by the (C/W x watts) plus ambient temp. For example, at an ambient temp of 25 C, a C/W of 0.25 with a CPU radiating 50 watts means that the CPU temp will be 50 x 0.25 = 12.5 C over ambient temp, or 37.5 C. The lower the C/W, the better.
Mounting a noisy YS Tech 40 cfm fan on the CopperRock improved results somewhat, but nowhere near enough to justify the increase in noise. I think this indicates that the CopperRock was designed to maximize airflow through the fins with a relatively low cfm fan; pushing a lot more air through it very quickly bumps up against diminishing returns.
CONCLUSIONS
Speeze’s CopperRock is an interesting entry – for its size and weight, it’s an OK performer and looks like a good heatsink for system integrators. Based on its construction, I expect it will not be premium priced. If you’re not pushing your CPU to the max, the CopperRock will give your ears a break and keep CPU temps in OK territory.
While it doesn’t make our recommended list (cutoff C/W: 0.30), for “normal” lower noise use, the CopperRock could be good way to go.
Speeze lists a C/W 0.53 – unfortunately, heatsink manufacturers’ listed C/Ws are all over the place. I visited a number of them while in Taiwan and found testing capabilities and methodologies vary widely, so results among them are not comparable.
Thanks again to Speeze for sending this our way.
Email Joe
¹Speeze is marketed by Spire Products, which is under Electronic Cooling Tech Corp.,Ltd, located in Taiwan. The US distributor is JamiTech Corp.
Leave a Reply
