Speeze EasyStream ™ 9T236B1M3
Add Your Comments
Quiet with sedate peformance – for P4 — Joe
SUMMARY: Conventional aluminum extrusion heatsink with quiet fan, sedate performance.
EasyStream™
Size: 78×90×47mm high; Fan: 21.7 cfm @ 3500 rpm; Lever Arm halfway closed.
The good guys at Speeze were nice enough to send over a sample of their P4 heatsink, the EasyStream™ 9T236B1M3. This is an aluminum extrusion unit with a fairly quiet fan.
The base
Base
was nicely finished – there were very slight polishing marks but barely discernible to the touch.
The fan is an Fanner Tech # FD07015B1M – a 70 x 15mm unit rated at 21.7 cfm @ 3500 rpm. I found it to be quiet – I measured its noise at 29 dBA @ 3950 rpm. It’s also safe to use a motherboard fan header – it draws 2.4 watts at 12 volts.
I found the clip about the best I ever used on a P4 – mounting and dismounting with this design was a breeze. The top lever articulates four arms which easily lock into a standard P4 bracket – a very nice implementation. The picture shows the lever arm halfway closed.
In summary, a fairly conventional aluminum extrusion heatsink with a very secure, easy to use clip for P4 use.
THE TEST
The EasyStream™ was first tested on the CPU Die Simulator which gives results that are unaffected by motherboard influences. I then tested it on an Lucky Star 4A845D with a modified P4 1500 to read CPU case temps, as an example of what users might see on their systems.
TEST RESULTS – CPU Simulator
Heatsink
Die Temp
Ambient Temp
Delta
C/W
EasyStream™ 3350 rpm 27dBA
55.5 C
20.5 C
35.0 C
0.47
EasyStream™ 3950 rpm 29dBA
54.3 C
20.5 C
33.8 C
0.45
EasyStream™ 4400 rpm 31dBA
53.0 C
20.5 C
32.5 C
0.43
TEST RESULTS – Motherboard
CPU/Motherboard
CPU Case Temp
Ambient Temp
Delta
C/W
CPU MBM
P4 1500/Lucky Star 4A845D
35.6 C
21.3 C
14.3
0.25
30¹ C
¹Motherboard Monitor
Delta = CPU temp – Ambient Temp
C/W = Delta / CPU Watts
Interpreting C/W: For every watt (CPUw) that the CPU
consumes, the HSF will limit the CPU’s temperature rise to (C/W x CPUw)
plus the temperature at the HSF’s fan inlet. For example, at an ambient temp of 25 C, a C/W of 0.25 with a CPU radiating 50 watts means that CPU temp will increase 50 x 0.25 = 12.5 C over ambient temp, or 37.5 C. The lower the C/W, the better.
Die Simulator results place the EasyStream™ in the lower rank of heatsinks (Heatsink Ranking).
CONCLUSIONS
Quiet means low airflow – the tradeoff is performance vs noise, and the EasyStream™ is one for consumers more interested in noise rather than all-out cooling performance.
Thanks again to Speeze for sending this our way.
Email Joe
Leave a Reply
