Spire SP601B3 VertiCool II ™
Add Your Comments
Heatsink Test – Joe
SUMMARY: Low noise, good performance and a compact footprint.
Spire
Size: 95 × 65 × 100 mm; Weight: 495 grams
The good guys at Spire were nice enough to send a sample of the SP601B3 VertiCool II ™ heatsink for a test spin.
Key Features:
  • Copper base with dual copper heatpipes, forty five aluminum fins
  • Fan 2300 rpm, 19.0 dBA, 26 cfm
  • Mounting for Intel Celeron D, Pentium 4, Pentium D, Pentium EE, AMD Athlon 64, FX 51, FX 53, FX55, Opteron, Sempron
  • Fan rated 2300 rpm, 25.8 cfm @ 19 dBA
There is a lot of fin area on this heatsink, as a rear view shows:
Spire
The base is polished; I used the Poor Man’s Flatness Test on it with good results:
Spire
The center appears reasonably flat while there is some fall-off at the edges:
Spire
Mounts included with the heatsink, plus the ubiquitous white goop:
Mounts
The Test
I tested the Spire VertiCool II using the CPU Large Die Tester. Noise was measured 8″ from the fan’s intake with a Radio Shack sound meter; 50 dBA at this distance is very quiet 3 feet from the fan.
Test
Die Temp
Ambient Temp
C/W
Spire VertiCool II, <50dBA
34.3
19.6
0.21
Fan noise is very low – this is a very quiet heatsink. Results place the Spire’s VertiCool II in the mid rank of heatsinks tested to date (Heatsink Ranking).
I also tested it on an Asus P5WD2 motherboard P4 Motherboard Test Platform with a modified Pentium D 805 to read CPU case temps (both supplied by Directron), with the following results:
Heatsink
Case Temp
Ambient Temp
C/W
On-Die Temp¹
Spire VertiCool II, <50dBA²
44.0
24.4
0.21
54
¹MBM on-die temperatures.
²50 dBA measured 8″ from the fan intake corresponds to about 30 dBA measured 3 feet from the fan, a very quiet noise level.
CONCLUSIONS
A bit of a surprise – I did not expect performance to be as well as it tested – I think the large fin area greatly aided performance. Low noise, good performance and a compact footprint – what’s not to like?? Not for aggressive cooling, but a very good choice for a work/home utility PC.
Thanks again to Spire for sending this our way.
Disclosure: Joe Citarella has a financial interest in a company developing thermosyphon products for electronic chip cooling.
Email Joe
Leave a Reply
