Spire's GigaPod III SP110-NEB 3.5" HD Enclosure
Add Your Comments
Very simple to mount and use – Joe
SUMMARY: Very simple to mount and use.
Pic
The good guys at Spire were nice enough to send a sample of their GigaPod III 3.5″ HD Enclosure to try out.
Pic
Key Features
  • Aluminum external enclosure for 3.5-inch IDE HDs
  • Supports USB 2.0 and 1.1
  • Supports up to 400 GB IDE
  • Includes external power supply, USB cable, mounting screws, screwdriver and driver disk (if needed)
  • Size: 200 x 107 x 30mm
Cooling is passive with vents in the front
Pic
and rear:
Pic
There is a power On/Off button, USB and power ports on the back. The PCB slips out of the case for HD mounting.
Pic
The HD is held in place by four screws which mount in holes behind the removable black trim strips:
Pic
Very simple design and setup.
Performance Test
I mounted a Seagate Barracuda 120 GB 7200 rpm HD to test out the transfer rate with the following results:
Pic
Fairly typical results for a USB HD enclosure.
CONCLUSIONS
Spire’s GigaPod III SP110-NEB 3.5″ HD Enclosure is very simple to mount and use – a nice package for backup storage. There are other versions available with USB & IEEE1394 ports for higher transfer speeds.
Thanks again to Spire for sending this our way.
Email Joe
Leave a Reply
