Swiftech MC462-A with Sanyo Fan
Add Your Comments
SUMMARY: A quieter fan results in slightly lower performance – still the “Heatsink to Beat”.
MC462-A
Swiftech was kind enough to send us a sample of their latest MC462-A. The differences between the original MC 462-A and this version fall into three areas:
  • A less aggressive fan – lower noise;
  • Six fewer pins on the heatsink;
  • Cutouts to accommodate some motherboard’s capacitors.
Of the mods, the last two have no real impact on performance compared to the new fan.
The fan is the biggest change between the two versions; the earlier fan was a Delta 68 cfm with fan noise at full speed rated at 48.5 dBA. This latest version features a Sanyo-Denki #109P0812A201 rated at 53 cfm, 45 dBA, 4600 rpm, 0.56 amp. Swiftech provides a four pin hard drive connector for power and a separate yellow 3 pin molex connector so that you can read rpms – great for those motherboards that require a spinning fan to boot up.
The base of this latest revision is notched to accommodate those motherboards’ capacitors which violate AMD’s clear zone:
MC462-A
MOUNTING SYSTEM
Swiftech has paid a lot of attention to mounting their heatsinks on motherboards. This is one of the best around – just about foolproof. Pictured below is one of the bolts that secures the heatsink to the board.
Bolt
There are four nice holes per AMD’s Socket A spec. On the left I marked where the motherboard sits. The round chrome piece is secured to the motherboard with a nylon nut (you must remove the motherboard from the case to do this).
There is a washer that isolates the chrome piece from the top of the motherboard. The round chrome piece is threaded to accept the spring loaded bolt. You screw this bolt into the chrome fitting until it hits bottom; at this point, the spring places the right load on the CPU per AMD’s spec.
Simple. Effective. Foolproof. I like it.
THE TEST
I bored a hole through the copper base so I could epoxy a thermocouple above the CPU. The thermocouple is attached to an Omega HH23 Digital Thermometer. Ambient temps were measured with a thermocouple placed about 1 inch from the fan’s intake. I used Prime 95 to stress the CPU on an Iwill KK266, running a T-Bird 1133 @ 1330, 1.85 v (82.7 watts). I measured noise 8 inches from the fan’s intake with a Radio Shack Sound Meter. Arctic Silver grease was used in all tests.
TEST RESULTS
Test
CPU Temp
Ambient Temp
Delta
C/W
Noise
T-Bird 1330 MHz, Sanyo Fan
37.8 C
21.0 C
16.8 C
0.20
63 dBA
T-Bird 1330 MHz, Delta Fan
36.7 C
21.7 C
15.0 C
0.18
74 dBA
Delta = CPU temp – Ambient Temp
C/W = Delta / CPU Watts
Interpreting C/W: For every watt the CPU radiates, the heatsink will cool the core by the (C/W x watts) plus ambient temp. For example, at an ambient temp of 25 C, a C/W of 0.25 with a CPU radiating 50 watts means that the CPU temp will be 50 x 0.25 = 12.5 C over ambient temp, or 37.5 C. The lower the C/W, the better.
The performance difference with the relatively quieter fan is minimal while the noise level is noticeably quieter; 63 dBA is a couple of dBA higher than what I get with a YS Tech 26 cfm fan. There is no high-pitched whine such as you hear with fans rotating at very high cfms, like the Delta 38 60mm unit. All told, a good compromise between performance and noise.
CONCLUSION
The Swiftech MC 462-A continues to lead the air-cooled performance race, now with noise somewhat tamed with the Sanyo fan. The mounting system is superb and about as goof-proof as you can get, although you must take the motherboard out of the case to set it up. The is still the “Heatsink to Beat”.
Email Joe
MC462-A
MC462-A
MOUNTING SYSTEM
Bolt
THE TEST
TEST RESULTS
Test
CPU Temp
Ambient Temp
Delta
C/W
Noise
37.8 C
21.0 C
16.8 C
0.20
63 dBA
36.7 C
21.7 C
15.0 C
0.18
74 dBA
CONCLUSION
Email Joe
Leave a Reply
