Swiftech MCW50
Add Your Comments
GPU Waterblock Test, including TEC version – Joe
SUMMARY: Very good choice for GPU cooling.
MCW50
Size: 2.0″ x 2.0″ x 1.22″ high (50.8 x 50.8 x 31.0 mm)
The good guys at Swiftech were nice enough to send an MCW50 GPU Waterblock to test.
Swiftech MCW50 features
  • Push fittings for 1/2″ OD tubing
  • Pin fin copper base
  • Mounting hardware for a wide range of GPUs, such as ATI ® Radeon ™ 9000 to 9800 and NVidia ® GForce ™ products
  • Designed to be used either in straight liquid cooling configuration or in conjunction with a thermoelectric (Peltier) cooling element
The base is typical Swiftech:
Base
Very flat – do not try lapping this as you will only make it worse.
Parts shipped with the MCW50 should be sufficient for just about any situation:
Parts
Overall, very good build quality.
THE TEST
The Swiftech MCW50 was tested using the CPU Die Simulator and Waterblock Test Rig.
WATERBLOCK TEST RESULTS
Test Conditions: Inlet Water Temp: 28.5 C; Mounting force: 15 pounds; Heat Load: 70 Watts.
Plot
Waterblock
C/W
Pressure Drop – psi
Pressure Drop – inches H2O
Swiftech MCW50
0.18
0.26
7.2
NOTE: These results are NOT comparable to tests done by others.
Unrounded data: 0.178 C/W with 0.0023 std dev.
Test Results indicate that the Swiftech MCW50’s pressure drop (or head loss) across the waterblock is very low; resistance such as this means that Swiftech MCW50 will perform nicely with moderate power waterpumps, especially if other components in the system are not overly restrictive.
I found that performance degraded by about 0.7ºC with at a flow rate of 0.5 gpm and improved by about 0.6ºC at 1.5 gpm – very “even” results.
For a comparison of the Swiftech MCW50’s performance to other waterblocks tested to date, see Overclockers.com Waterblock Test Results.
CONCLUSIONS
Swiftech’s MCW50 Waterblock is a fine choice for GPU cooling. As GPU waterblocks are usually fitted in series with a CPU waterblock, low flow resistance is particularly important for a GPU waterblock. Note that this waterblock is 1.22″ high, so plan accordingly.
Thanks again to Swiftech for sending this our way. The MCW50 is available from the Heatsink Factory.
SUMMARY: Very good choice for aggressive GPU cooling, but only for experienced users.
MCW50-T
The good guys at Swiftech were nice enough to send an MCW50-T GPU Waterblock to test.
Swiftech MCW50-T features
  • 80 watt thermoelectric (TEC, or Peltier) cooling element
  • Foam insulation for condensation control
The TEC is fitted between the copper base and waterblock; the base is typical Swiftech:
Base
Very flat – do not try lapping this as you will only make it worse. Note that the foam skirt around the base is there to control condensation – this is covered in the accompanying instruction sheet. In addition there is a foam pad to place on the back of the video card.
Parts shipped with the MCW50-T should be sufficient for just about any situation:
Parts
{mospagebreak}
Using a TEC
Effectively using a TEC involves more than simply slapping one on and running it. I strongly advise anyone interested in using this product to carefully read all the items HERE. In particular, Swiftech notes that:
  • “The combined amount of heat (TEC + GPU) added to the circuit by the MCW50-T is approximately 115 watts (392 BTU/hr).
  • The thermoeletric module pulls approximately 6A at 12 volts. When connecting the MCW50-T module to an existing power supply, users should verify their power supply current rating for the +12 volts line.
  • [The MCW50-T] will dissipate 53 Watts continuous thermal load to ambient temperature.”
As I tested this unit, I noted that the heat load was considerably higher and I had to cool much more aggressively than for a waterblock without a TEC (no surprise). I also tested with a separate 12 volt power supply – a practice I highly recommend when using a TEC in any system.
I also want to point out that the load you can place on any TEC is limited. If you exceed its capacity, you will find that the TEC will run wild; that is, temps will continue to increase in a destructive heat loop. A safe, conservative operating guidline is to not exceed 50% of the TEC’s rating – in this case, 40 watts. In this instance, once I went over 50 watts, I started to see temps continue to creep up. At 70 watts, it started to get scary.
THE TEST
The Swiftech MCW50-T was tested using the CPU Die Simulator and Waterblock Test Rig. In this case, I will not report a C/W as it has no meaning when using a TEC, but show the delta T I achieved at 40 and 50 watts.
Test Conditions: Inlet Water Temp: 28.5 C; Mounting force: 15 pounds.
Waterblock @ watts, gpm
Die Temp Diff to Water
Swiftech MCW50-T @ 40 watts, 1 gpm
-8.1 C
Swiftech MCW50-T @ 50 watts, 1 gpm
1.6 C
Swiftech MCW50-T @ 50 watts, 1.5 gpm
-2.8 C
It was interesting to see the increase in performance by increasing waterflow through the waterblock; high efficiencies are key to extracting maximum performance.
CONCLUSIONS
Swiftech’s MCW50-T Waterblock is a fine choice for very aggressive GPU cooling, but I caution that TECs are tricky animals to tame. As GPU waterblocks are usually fitted in series with a CPU waterblock, in this case low flow resistance is VERY important; maximum performance may require a separate cooling loop.
Email Joe
Leave a Reply
