Tagan CS-EL Diablo BM PC Case
A very nice case for quiet operation – Joe
SUMMARY: A very nice case for quiet operation.
Case
The good guys at Tagan were nice enough to send a sample of Tagan’s CS-EL Diablo BM PC Case to check out. This is the only case I have seen which features two LARGE fans – a front 250 mm fan and a side 360 mm fan.
Case Side
  • Front 250mm Blue LED fan with on/off switch fan speed control, max 800 rpm @ 150 cfm, 32 dBA
  • Side 360mm Blue LED fan with on/off switch fan speed control, max 600 rpm @ 205 cfm, 31 dBA
  • Tooless HDD, DVD, rear 120mm fan mount bracket and Floppy kit
  • External watercooling kit holes at rear of case
  • Dual side VR blue LED light
  • Top audio, firewire, USB ports
  • 5 External 5.25″ bays, 1 External 3.5″ bays, 7 Internal 3.5″ bays
  • Size 205 x 520 x 570 mm
  • Supports Micro ATX, Standard ATX and Ext ATX (12″x13″)
  • Includes manual and mounting hardware
Each fan has 5 LEDs around its hub:
Fan LEDs
The side panel features the large 360mm fan and is well ventilated:
Fan Panel
The LEDs lit on the side fan:
Side Fan Lit
The front fan measures 250mm…
Front Fan
and here as lit:
Front Fan Lit
The fans are controlled by a knurled knob on each side of the front to vary fan speed:
Knob
I found at low speed the fans are almost silent. In addition to the fan LEDs, each side of the case LEDs as well:
Side LED
{mospagebreak}
The back of the case shows the power supply slot at the top of the case – there are also four round knock-outs for external watercooling hoses if needed:
The CD Bays are hidden behind a front panel which easily swings out:
CD Bays
Inside the case shows plenty of room to mount motherboards and watercooling gear:
Open Case
The lower front shows the HD Bays and the front 250mm fan – this washes cooling air over the hard drives, a nice feature needed these days for those hot 10,000 rpm drives:
Inside Front
There is plenty of room to mount up to 7 HDs, all using plastic rails for mounting:
HD Bays
There is room for 5 5.25″ devices, also using plastic rail mounts:
CD Bays
The back shows the PCI slots and a mount for an internal 120 mm fan, including hardware for mounting:
Inside Back
Note that the 120mm fan mount uses rubber bushings to isolate fan noise:
Fan Mount
A nice touch – there are directions pasted inside the case for various case features:
Directions
The PCI slots use a “slide and lock” system to secure cards:
PCI Slots
PCI cards can mount to the front of the case, if needed:
PCI Mount
A nice feature are top mounted slots for a firewire, 2 USB ports and audio ports:
Top Slots
CONCLUSIONS
This is a very nice case for quiet operation – the cooing fans move air at very low speeds and throw air where needed – on the hard drives and over the motherboard. It’s a good sized case that can hold internal watercooling gear – a nice package for the enthusiast.
Thanks again to Tagan for sending this our way – a very nice package.
Be the first to comment
Leave a Reply
