Taisol CGK742092 Heatsink
Add Your Comments
SUMMARY: A very competent heatsink for Socket A cooling – Alpha class!
Taisol
You’ve all seen fans before – this is more interesting.
Taisol has come up with a very nice heatsink – model # CGK742092 (you would think they could call it something like the “Coolerator”). It is made in the same manner as the Alphas – a forged product. This means that they use a hydraulic press and basically squeeze a piece of aluminum into shape. This means no joints (like the Hedgehog) and a greater pin density (= more surface area) than an extruded product.
I purchased the base model that comes with the usual puny 60x15mm, 21 cfm fan, and I did not bother to test it. I tried three different fans: ADDA 28 cfm, Papst 33 cfm and Delta 38 cfm.
Taisol
This is a BIG heatsink – note that it extends BEYOND the socket into the “safe” area (where the four holes are located) per AMD’s spec. The base measures 80 x 60 mm (3.2 x 2.4 inches) and weighs 248 grams (1/2 lb). As long as the motherboard manufacturer stays within this spec, the Taisol should fit (fits on the space-constrained ABIT KT7 – I tried it). I think we may see more heatsinks using this larger footprint.
The Taisol sports 120 fins; I estimated a total fin surface area of about 137 square inches, or 0.95 square feet.
THE CLIP
If there’s one thing that gives people more fits about almost all Socket A heatsinks, it’s the clip. AMD’s clip pressure requirements result in clips that are difficult to engage and almost impossible to remove once installed in a case (notable exception: Swiftech MC462). The Taisol’s clip is a good example of a design that, while still more difficult than we are used to, is a bit more manageable than some others.
More Than You Ever Wanted To Know About a Clip
The Taisol clip has an opening in which you can insert a screwdriver to install and remove the heatsink without too much pain.
One nice feature is that the clip engages all three socket lugs (the SOYO uses only two lugs, most use three) so it is quite secure and, should you somehow break one lug, the socket is still usable.
Taisol
If you look closely inside the red circle, you can see that there is a lip for the screwdriver’s tip.
Taisol
You place the tip into the hole, making sure that the tip engages the lip inside the hole. Absolutely a must: Use a screwdriver with a tip small enough to go through the hole! If you slip, who knows what damage might ensue when you hit the motherboard.
Taisol
Now to mount or dismount the heatsink, push DOWN on the clip and rotate the screwdriver TOWARDS the heatsink at the same time. This will ensure that the clip clears the socket’s lugs. Once you clear the lugs, then rotate the screwdriver AWAY from the heatsink so the clip engages the lugs.
If you look at other heatsinks, you will find some that have the same arrangement, so you can use this technique on them also.
THE TEST
I marked where the CPU would contact the base, drilled a 1/16″ hole, inserted a thermocouple and epoxied it into place. After it set, I lapped the heatsink’s base so the thermocouple would be flat to the base. The base could stand some lapping in any event, but I did not want to “overlap” it and distort results. I used the Omega HH23 Digital Thermometer to measure temps. Ambient temp was measured by a thermocouple placed about 1″ from the fan’s intake.
I ran Prime 95 for at least 30 minutes to stabilize temps and took readings. Each fan was replaced with the heatsink mounted on the SOYO K7VTA-B motherboard. The T-Bird at 1100 MHz, 1.85 v, radiates 65.5 watts; Arctic Silver was used for thermal grease. I also ran the Papst and Delta on an ABIT KT7A with a 1 GHz T-Bird running at 1133 MHz, 1.85 v, 67.2 watts, as an additional test.
TAISOL CGK742092 TEST RESULTS
Fan
CPU Temp
Ambient Temp
Delta
C/W
Notes
Delta 38 cfm
37.6 C
22.8 C
14.8 C
0.23
LOUD!
Papst 33 cfm
38.1 C
23.3 C
14.8 C
0.23
Best Compromise
ADDA 28 cfm
39.7 C
23.0 C
16.7 C
0.25
Tolerable
ABIT KT7A, Delta 38
38.1 C
22.1 C
16.0 C
0.24
T-Bird @ 1133 MHz
ABIT KT7A, Papst 33
39.1 C
22.6 C
16.5 C
0.25
T-Bird @ 1133 MHz
Delta = CPU temp – Ambient Temp
C/W = Delta / CPU Watts
Interpreting C/W: For every watt the CPU radiates, the heatsink will cool the core by the (C/W x watts) plus ambient temp. For example, at an ambient temp of 25 C, a C/W of 0.25 with a CPU radiating 50 watts means that the CPU temp will be 50 x 0.25 = 12.5 C over ambient temp, or 37.5 C. The lower the C/W, the better.
What surprised me was that there was little difference between the Delta and Papst fans. I repeatedly cycled the two fans to see if it was some kind of fluke, but after 4 paired tests and similar runs on the ABIT KT7A, I continued to get the same results. Although there may be a slight advantage to the Delta 38, I do believe that the Delta is not worth the noise.
CONCLUSIONS
Impressive performance! C/Ws in the 0.23 to 0.25 range place the Taisol in some select company – this is as good as the Global Win FOP series and certainly places it squarely as equal to the Alpha’s performance. I think forging enabled the Taisol to pack a lot of surface area into a small package, with obvious performance advantages.
The Taisol CGK742092 is a fine performer and widely available. With some lapping, you might squeeze a little bit more out of it. How much noise you’re willing to tolerate determines how well it will do for you. Overall, a price/performance winner.
Email Joe
Leave a Reply
