The Atlantis from OverclockedPC
Add Your Comments
Bill Adams waterblock test
OCPC Describes Their Design Goals for the Atlantis:
The main priorities in designing the Atlantis were to provide the best combination of high cooling performance, best appearance, and low waterblock weight possible at a reasonable cost.
A waterblock first has to fulfill its main purpose: keeping processors cool.
To do that, we wanted to keep as much surface area close to the critical die area (highest loading) as possible to maximize the transfer of energy into the water. We did not want to create a waterblock that was too restrictive, required a large pressure pump or would not match the rest of our range of products.
Special machining techniques were chosen that help to create turbulence and improve surface area. To do that, we made the base cut as flat as possible base with as many small ridges as possible.
We put performance ahead of polishing. Highly polished surfaces are nice, but if they are not flat, you get poor contact with the CPU die and performance loss. So we put flatness above beauty in the overall base finish.
This doesn’t mean we ignore looks. A block design has to work well, but as more people switch over to water-cooling, it’s not just about performance any more. Many people use water-cooling for other reasons, like quietness and even looks.
We use acrylic because people like how it looks (though we also supply the unit with an anodized aluminum cap for those still unsure about using it).
Our testing has shown that weight is indeed an important issue. A vertically mounted motherboard combined with a heavy waterblock hurts performance. A lot of weight hanging from the motherboard makes it difficult for clamping mechanisms to provide equal pressure to all areas covered by the waterblock.
We aimed to reduce waterblock weight to a minimum. This lets the four mounting springs provide as even a clamping effect as possible. Our testing showed that this was very important for overall performance, since poor, uneven clamping pressure causes poor performance of the thermal interface due to unequal contact or thermal compound distribution.
All designs must also consider future trends in terms of die size and heat generation. For this reason, we provide an adaptor bracket for PIV and future CPU mounting.
Jess, OCPC
Bill Adams
First Impressions:
This waterblock is a looker. Without question, it is the most ‘eye catching’ waterblock I have ever seen, and that’s even before adding any LEDs, which can be easily mounted in the thick acrylic top cover plate.
The aluminum P4 adaptor ring (not shown) complements the waterblock’s styling. The brass barbed connectors and intricately machined internal curved fins and even adds to the unit’s attractiveness.
For the fellows with windows in their cases, this wb looks slick.
The copper wb itself is 60 mm long by 50 mm wide (the baseplate thickness over the die was not specified). The barbs are threaded into the acrylic cover and sealed with o-rings (more on this later), and the cover is retained with 4 ss cap screws compressing an o-ring in a groove.
The barb ID is 10.5 mm and the unit w/o the P4 adaptor weighs 258 gm dry, and 284 gm when full of coolant.
Crucial to the performance of any wb is the flatness and finish of the bp. On the Atlantis’ bp there were faint machining (fly cutting ?) marks, but there were none visible however in the CPU contact area. Overall, the bp had a slightly matte surface.
Test Results:
The Atlantis was flow tested:
You can see that its flow resistance is quite low.
The Atlantis was then mounted under carefully controlled conditions 10 times and its “C/W” determined under ‘standard conditions.’
(‘Standard conditions’ are defined as 70W applied heat load, 3.8lpm coolant flow rate at 25.0°C, and 10kgf applied compressive load across the TIM joint).
We got the following results:
  • “C/W” mean = 0.267
  • “C/W” range = 0.005
  • “C/W” standard deviation = 1.96E-03
    The data is consistent with a normal distribution.
    (P= 0.80 where the normal distribution has a mean = 0.2665 and sdev= 2.2581E-03.)
    The “C/W” distribution is shown below. ‘Standard Error’ bars are shown to enable an estimate of the measurement uncertainty.
    Bill Adams
    The “C/W” was then determined with an applied heat load of 70W (about 100W per Radiate) under a range of flow rates from 1 lpm to almost 14 lpm. The slope of the “C/W” curve at high flow rates suggests that some further improvement would be possible from even higher flow rates than those tested.
    Combining this data yields the graph below which enables one to estimate the “C/W” based on the pressure drop (or head loss) across the wb. (The wb pressure drop will be only a portion of the total coolant system’s flow resistance, the flow rate being a consequence of the pump’s capability at the total system head.)
    After testing, the bp surface was again inspected. After a dozen mountings, the CPU contact area had begun to take a slight luster, indicating that the matte finish was quite fine.
    There was no indication of unevenness in the pattern of the residual thermal grease upon disassembly (uniform widely dispersed very small ‘specks’, characteristic of the grease used).
    To better understand the bp, I then inspected it with an optical flat in a reflex viewer using monochromatic light from a filtered mercury bulb. On a suitably reflective surface, ‘fringes’ will be apparent and each one represents a height (difference) of ~0.000273mm (0.000010749in.). These are VERY small numbers and while ‘absolute’ flatness is a desirable ideal, the purpose here was to look for grosser indications of unevenness.
    The image below is of the CPU contact area (faintly visible in the center), manipulated to make the contrast between the fringes more visible.
    While it’s difficult to judge with this compressed image, the full-blown image shows that bp of the Atlantis is remarkably flat. There is nothing to be gained by lapping this wb’s bp.
    Bill Adams
    Discussion of Results
    It should be clear that this is a wb for high flow rate systems, and by extension for systems optimized for low flow resistance and utilizing a large pump. The wb’s low pressure drop at high flow rates means that it can benefit from the low head capability (aquarium type) pumps in common use by WCers. Substantial pumps warrant a large radiator with good air flow as well.
    One serious problem occured during testing: a leak at a barb/cover plate connection.
    I disassembled and found that two small o-rings had been used where a single larger cross-section one was needed. The change was made to both barbs and no further leaks were experienced. The appropriate o-ring (in the US) is 1/2 x 3/8 x 1/16, #7.
    After reporting this to OverclockedPC, I’ve been informed by them that the o-rings used have been changed.
    Thanks to Jess and
    for sending us this attractive waterblock, which can be ordered here.
    Details on the testing of commercial
    wbs may be found here.
    be cool
    Bill Adams
  • Leave a Reply
