The Tool-less Reservoir
Add Your Comments
$15 PVC Reservoir – Mark Goudie
Pic
I needed a cheap reservoir and someone in the OCforums recommended using PVC pipe. I went to Lowes and John and I looked around in the PVC isle for a while. He came up with the idea of using and elbow, “T” and caps for the barbs instead of drilling. The total price of all these items was around $15 – this includes everything you see in the picture. I forgot Teflon tape, but that is about $1-2.
  1. The first step is to clean each joint that will you will be priming later. I used my shirt to wipe any large debris of the pipe – you could use soap and water as an alternative.
  2. Then apply the primer to all the joints that you plan on gluing together. The primer dries extremely fast – I only had to wait about 5 minutes.
  3. Once everything is primed and dried, you can apply glue to both sides of the joints, one at a time, and squeeze them together [ed note: Paul emailed a tip – “A suggestion for assembly of PVC to help prevent any leaks – when putting two pieces of PVC together, give them a 1/4 twist as you insert one piece into the other.]
  4. Once all the joints are glued, wait 2 hours for the glue to set.
  5. Then apply Teflon tape to the barbs and cap and screw on.
  6. Leak test and you are done.
Parts Needed
Pic
Priming…
Pic
Pic
Pic
And gluing…
Pic
Pic
The finished product before screwing in the barbs…
Pic
Mark Goudie
Leave a Reply
