The WaveMachster: Prometeia-Cooled, 24/7-Ready Record Breaker
Add Your Comments
“The goal of this project was to build the most powerful system possible, capable of pulling world-class benchmark results” – Gautam Bhatnagar
The goal of this project was to build the most powerful system possible, capable of pulling world-class benchmark results, but at the same time provide reliability and day-to-day usability, an odd balance that you don’t hear of very often these days.
The CPU was cooled by a Prometeia Mach II. The diehards know that technically one can get colder, but for all practical purposes it most definitely succeeds at providing excellent performance, along with low noise levels, at a reasonable price if you shop around. The Radeon X1900’s are beautiful performers as well; however they have one major flaw that makes them frustrating to overclock – their noise level.
From the factory, they use screeching fans and heavy copper heatsinks to cope with their massive heat dump. Thus, there was one obvious solution – use liquid cooling to allow for a much larger surface area coupled with the large specific heat capacity of water. Also one can use larger and quieter fans on the radiator.
But liquid cooling has its own flaws – the most conspicuous of all in this case is its size and weight. The system is to be built inside a CoolerMaster WaveMaster. Although the case is very sharp looking, it’s also nothing more than average sized and quite constricted inside. So, here is the breakdown of all the components used:
  • Intel Core 2 Extreme X6800
  • ATi Radeon X1900XTX+ CrossFire Edition
  • Asus P5W DH Deluxe
  • Team Group Xtreem PC2 5300 3-4-4-3
  • Zippy/Emacs 6701P
Watercooling Components:
  • 2x Swiftech MCW60 GPU Waterblocks
  • 1x Swiftech MCR220 Radiatior
  • 2x Evercool 120mm fans
  • 1x Eheim 1250 Hobby Pump
  • Tygon 3603 Tubing
Now that the challenges are laid out, let us proceed straight to the pics! Here are the victims in question:
Pic
In order to mount the case on top of the Prometeia, I had to cut a small hole in the bottom. I haven’t touched a Dremel for years, so please excuse the sloppiness of my cuts:
Pic
Next mod to the case that needs to be performed is mounting my Swiftech MCR220:
Pic
Here’s a test mount of how it will be placed inside at the top in the first optical drive slot:
Pic
Using a 4.5″ hole saw, I cut two blowholes for the fans in the top of the case:
Pic
With the major case modifications complete, we proceed to prepare the video cards for the liquid cooling. Here are both of the X1900’s with the Swiftech MCW60 blocks mounted and Thermaltake BGA ram sinks:
Pic
At this point my patience wore thin. Although it was still rough around the edges, I assembled the system. The jungle of cables still needed cleaning:
Pic
Next was to tidy things up. Here is how the system looks with the case closed…
Pic
… and from the front:
Pic
In order to cover up my sloppy hole saw job, I used a RadGrill on the top of the case. After seeing it being mentioned by fellow forum member catkicker, I decided that I just had to have one. Hopefully you can see why. Please excuse the mess of cables on the floor:
Pic
The system is complete, and as we will soon see, it successfully met my goals. However, it is still less than perfect in terms of practicality, as can be observed by the effect it has on a bathroom scale:
Pic
Eighty five pounds of pure bulk makes it rather difficult to move around. In order to partially rectify this, I used a polished wooden platform with wheels underneath to cart it around:
Pic
Now the part you’ve all been waiting for – putting the system to the test. It’s about as practical as it could ever be with such cooling capabilities, but how does it perform?
On its first night, I did a quick SuperPi 1M calculation to roughly gauge the processor’s maximum clock:
Pic
A very respectable “suicide” clock for what is meant to be a 24/7 ready system.
And then to test 24/7 stable speeds; “Blend” calculation in StressPrime for close to 11 hours – good enough for me in ensuring long-term stability. Running at 4.2 GHz, it is easily one of the fastest running CPU’s ready for daily usage:
Pic
But what to do with all that CPU power when not gaming or benchmarking? Helping Stanford University find a cure for cancer seemed like a good start. Here is a quick test run of Folding@Home on a beta work unit conservatively clocked at 4152 MHz instead to eliminate even the slightest chance of instability:
Pic
And now for the fun part – I proceeded to subject it to a battery of tests from Futuremark’s entire suite. The results were very favorable, placing the system in the very highest bracket of performance on a worldwide scale, taking no less than three Hall of Fame Top 5 spots, and even a first place PCMark05 result.
At the time of this article’s publishing, the results probably will have dropped a bit lower, but still within the top 20 worldwide in all categories. What sets these results apart from the others it keeps company with is that all of them were done in a very stable and repeatable condition:
Pic
Thank you for reading my article. I hope it was enjoyable and informative.
Gautam Bhatnagar
Leave a Reply
