Thermalright-947U
Add Your Comments
Very good P4/Socket A heatsink, depending on noise preferences – Joe
SUMMARY: A very good heatsink for P4 or Socket A use.
947
Size: L96 x W86 x H45 mm; Weight: 570 grams.
The good guys at The Heatsink Factory were nice enough to send us a sample of Thermalright’s 947-U. This is the usual all-copper construction we’ve seen from Thermalright; in addition, this unit is designed for both P4 and Socket A use.
The base is a copper baseplate:
Base
I could feel very slight ridges as I dragged my fingernail over it.
The 947-U ships with a bundle of parts:
Parts
There are mounts to use Intel’s retention bracket and spring-loaded bolts for bot Socket A and P4 mouting. Fan clips are included for 60, 80 and 92 mm units.
Overall, the build quality is very good.
THE TEST
The Thermalright 947-U was tested on an Acorp 4S845A motherboard with a modified P4 1500 to read CPU case temps; for Socket A, I used the CPU Die Simulator. For testing, I used a Delta FFB0812SHE, 68 cfm @ 4800rpm, 48.5 dBA; this features vanes in the base which straighten airflow into the heatsink. I varied rpms to give a range so users can match performance to noise tolerance.
P4 TEST RESULTS – Motherboard
Motherboard
CPU Case Temp
Ambient Temp
Delta
C/W
MBM Temp
Acorp 4S845A, 4840 rpm, 69 dBA²
32.0 C
22.5 C
9.5
0.16
28 C¹
Acorp 4S845A, 3523 rpm, 60 dBA²
34.1 C
23.8 C
10.3
0.18
30 C¹
Acorp 4S845A, 2021 rpm, <50 dBA²
38.6 C
25.0 C
13.6
0.24
35 C¹
Socket A TEST RESULTS – CPU Simulator
Heatsink
Die Temp
Ambient Temp
Delta
C/W
4816 rpm, 69 dBA²
42.6 C
24.4 C
18.2 C
0.26
3512 rpm, 60 dBA²
44.9 C
24.8 C
20.1 C
0.29
2010 rpm, <50 dBA²
50.4 C
25.2 C
25.2 C
0.36
Delta = CPU temp – Ambient Temp
C/W = Delta / CPU Watts
