Thermalright AX-7 Prototype
Add Your Comments
Top performing heatsink. — Joe
SUMMARY: Exceptional performance, but this is not a production version.
AX-7
77 x 77 x 42mm high; Weight 420 gm.
The good guys at Thermalright were nice enough to send a prototype of their 80mm heatsink, the AX-7. I think there is a new category of heatsinks – I’m going to call these the “SuperSinks”. These are heatsinks which use an 80mm fan, have considerable physical “bulk” and push the limits of aircooling performance. The other contenders are the Alpha 8045 and Swiftech’s 462/478. The AX-7 is about the same size.
Thermalright’s design is very interesting. If you look down at it,
Top
you see that there is a central aluminum core over the CPU die. Surrounding the core are the coolings fins. This design recognizes the “dead spot” immediately under the fan hub and fills this space with heat absorbing metal. The fins then wick the heat from the central core. Note also that air flow through this fin pattern is omni-directional; airflow through the fins cool surrounding components on the motherboard and the CPU carrier as well.
The base
Base
is solid copper, measuring 50 x 63 x 8mm thick. The fin structure is soldered onto the copper base. As a prototype, it is not a “polished” job. If you look from the front
Front
you can see that the clip rides in a channel (outlined in red) cut through the center of the fin assembly. The clip is not indexed and on this prototype was terrible; I had to use an angled screwdriver to mount/dismount it. However, I know Thermalright is not planning to use this one, so I can’t fault them.
Overall, the AX-7 is an interesting design.
THE TEST
The AX-7 was first tested on the CPU Die Simulator which gives results that are unaffected by motherboard influences. Tests then were conducted on a motherboard as an example of what users might see on their systems.
For this test, I used two 80 mm fans: The Delta 68 cfm (FFB0812SHE) and the Sanyo Denki 53 cfm (109P0812A201).
AX-7 TEST RESULTS – CPU Simulator
Platform
Die Temp
Ambient Temp
Delta
C/W
Simulator, 77.4 Watts, Delta 80mm
43.3 C
19.8 C
23.5
0.30
Next, I tested the AX-7 on an Iwill XP333 which is modified to take direct die readings from AMD XPs and Palominos. I also epoxied a thermocouple on the back of a Palomino 1200 for CPU back readings.
AX-7 TEST RESULTS – Motherboards
CPU/Motherboard
CPU Die Temp
Ambient Temp
Delta
C/W
CPU Back Temp
Palomino 1200, Iwill XP333, Delta 80mm
34.0 C
20.4 C
13.6
0.24
36.1 C
Palomino 1200, Iwill XP333, Sanyo 80mm
36.2 C
21.3 C
14.9
0.27
38.0 C
Performance on a motherboard and the Die Simulator indicate that the prototype is a top rate heatsink. These results, if they hold up in the production version (depends on which fan, final design, etc.), would place the AX-7 in the highest rank of heatsinks we have tested (Heatsink Rankings HERE).
CONCLUSION
The AX-7 looks very promising. IF Thermalright can produce it and IF it comes in at an attractive price point, they just might pull another “SK6” on the competition.
Thanks again to Thermalright for sending the AX-7 our way – an interesting design.
This is now available from Heatsink Factory.
Email Joe
Leave a Reply
