Today, Thermalright announced the Archon heatsink, a new tower CPU cooler. The cooler is thinner than standard tower heatsinks, which Thermalright claims will eliminate compatibility issues with large memory heatspreaders. Boasting compatibility with Intel’s 1156 and 1366 sockets, the Archon also comes with the same AMD bracket system as the Venomous X. Also included is a 140mm TY-140 fan, but users can mount their own 120 or 140mm fan.
Specifications (Courtesy Thermalright)
Heatsink Specifications:
- Dimension: Length 155mm x Width 53mm x Height 170mm
- Weight: 806g (excluding fan and mounting brackets)
- Heatpipe: 6mm heatpipe*6 units
- Copper Base: C1100 Pure copper nickel plated with mirror shine
Fan Specification:
- Dimension: L160mm x H140mm x W26.5mm
- Weight: 140g
- Fan speed: 900~1300RPM (PWM controlled)
- Fan noise: 19~21dBA
- Airflow: 56~73CFM
- Connector: 4 Pin (PWM Fan connector)
Estimated Performance
This cooler is similar in shape and design to the Venomous X, which is important because it gives a baseline indication of how the Archon will perform. Thermalright claims that despite its slimmer profile, the Archon has 1.6x more surface area than the Venomous X. There is only a 6% weight difference between the Venomous X (755 g) and Archon (806 g), which are both made of the same material. With that in mind, it is safe to assume that performance can be approximated with relative accuracy by comparing the volume of both coolers:
| Heatsink | Volume |
| Venomous X | 1280 cm3 |
| Archon | 1397 cm3 |
With 8% more volume than the Venomous X, the new Archon is a pretty safe bet. Taking a look at muddocktor’s comprehensive Premium Heatsink Shootout, it appears as though the Archon (depending on fan setup of course) will be able to keep up with some of the best air coolers out there.
Thermalright has not released expected retail pricing or an estimated ship date. Once we have a review sample in hand, we should be able to provide an accurate assessment of this cooler’s performance.
Tags: archon, heatsink, Thermalright
10-20-10 02:24 PM
10-20-10 02:30 PM
10-20-10 02:45 PM
This thing should be a monster.
EDIT:
I would not assume the performance will be the same, personally.
10-20-10 03:11 PM
10-20-10 04:01 PM
Watch at the gaps pointed by those red arrows, maybe those pipes are making contact at the upper fins, while the blue one is the one that is making contact with the bottom fins.
Really curious to see how this perform against current top dog like Silver Arrow or Noctua D14.
87297
10-20-10 04:23 PM
10-20-10 04:55 PM
Another things to concern about, this HS is the tallest and widest (length) among other TR high end heatsinks, with this height, this might create problem with tight mid tower size case, especially with a thick side fan mounted.
Comparison :
Archon : Length 155mm x Width 53mm x Height 170mm
Venomous X : Length 127mm x Width 63mm x Height 160mm
Silver Arrow : Length 147mm x Width 123mm x Height 160mm
87299
10-20-10 05:14 PM
10-20-10 05:26 PM
- It's thinner than other tower coolers, like the Venomous X, by 10mm. Did Thermalright supply the volume numbers? They say you can use either 140 mm or 120 mm fans, but would a 120 mm cover all of the fins? If not, then the dissipation area of the Archon when using a 120 mm fan would be smaller.
- The spreading of heatpipes seems like a good idea. One issue I see that may arise is how high-performance fans with huge hubs work with the Archon. Personally, I like the majority of the heat being on the ends of the fins so my San Ace fans can dissapate all of it. The heat from the inner heatpipes may not get dissipated well unless using a fan with a small hub.
10-20-10 05:27 PM
Just kidding...very true...of course the target market for this thing will not be SFF I'd imagine.
10-20-10 09:42 PM
http://www.thermalright.com/products...=172&cat_id=27
10-27-10 12:21 AM
10-27-10 12:38 AM
10-29-10 07:28 PM
Judging from the information source and also the claim by comparing their own products, looks like TR is preparing to launch a new champion.
10-29-10 07:56 PM
10-29-10 08:47 PM
10-29-10 08:56 PM
11-21-10 06:07 PM
11-21-10 08:37 PM
11-24-10 02:50 PM
88394
Will post pics of unboxing soon.
11-24-10 02:55 PM
11-24-10 04:48 PM
11-24-10 05:46 PM
11-24-10 05:56 PM
Side by side shots with D14 and Megahalems, currently don't have True or VX with me now, they're both loaned to friends, so stay tune.
