Thermalright SI-128
Add Your Comments
Heatsink Test – Joe
SUMMARY: Very good performance even at relatively low fan speeds.
Pic
The good guys at Thermalright were nice enough to send us a sample of their latest heatpipe heatsink, the SI-128, to test. This model features four large heatpipes cooled by a 120 mm fan.
The base is well finished; I used the Poor Man’s Flatness Test on it with good results:
Base
Base
Parts that ship with the SI-128 include mounting gear for Intel 775 and AMD K8 sockets:
Parts
The heatsink for Intel use is mounted to the motherboard using four mounting posts that engage the holes around the socket:
Post
You push down and then rotate the top to lock it in place – the only negative is that in some instances it may require some digital dexterity to reach under the heatsink and do the “push-rotate” sequence.
The Test
The SI-128 was tested on an Asus P5WD2 motherboard P4 Motherboard Test Platform with a modified Pentium D 805 to read CPU case temps (both supplied by Directron). The SI-128 was tested with a Delta 120 mm fan at various fan speeds to give a range of results.
Heatsink
Case Temp
Ambient Temp
C/W
On-Die Temp¹
Thermalright SI-128, 2451 rpm, 56 dBA²
38.9
25.7
0.14
52
Thermalright SI-128, 1766 rpm, <50 dBA²
40.7
26.5
0.15
54
Thermalright SI-128, 1028 rpm, <50 dBA²
46.2
27.9
0.19
59
Thermalright Ultra 120, 2504 rpm
34.8
24.6
0.11
44
¹MBM on-die temperatures.
²50 dBA measured 8″ from the fan intake corresponds to about 30 dBA measured 3 feet from the fan, a very quiet noise level.
Results place Thermalright’s SI-128 in the upper rank of heatsinks tested to date (Heatsink Ranking) with the fan at its highest speed setting. Performance at the lowest fan speed is acceptable; at this setting, the fan is almost silent – inside a case, the fan on low will not be noticeable. I included test results for Thermlaright’s Ultra 120 as a reference point.
CONCLUSIONS
Thermalright’s SI-128 is a very good all-around heatsink and a good choice for Intel’s hotties.
Disclosure: Joe Citarella has a financial interest in a company developing thermosyphon products for electronic chip cooling.
Email Joe
Leave a Reply
