Thermalright SK7
Add Your Comments
Solid performer – Joe
SUMMARY: Top Rank socket A cooling, depending on noise preference.
SK7
The kind folks at Thermalright were nice enough to send a sample of their latest heatsink, the SK7. We took a look at the Thermalright SK6+ earlier, and it’s not a stretch (actually, it was) for Thermalright to come up with an 80mm version, the SK7.
The base
Base
finish is very good – there are no polishing marks on it, although not a polished finish; lapping might improve performance a tad but I think not worth the effort.
One notable factor in the SK7’s favor is the amount of air flowing onot the motherboard due to the 80mm fan overhanging the heatsink’s sides – the top measures 85 x 58mm. There is a significant secondary cooling benefit as a result, and components around the heatsink should run cooler. In addition, since the motherboard acts as a secondary CPU heatsink, there will be a positive impact on CPU cooling.
The clip mounts on all three of the socket’s lugs – a plus. However, you must use a screwdriver to engage the lugs. As with all screwdriver-assisted mountings, make doubly sure the screwdriver tip is securely in the clip’s slot – a slip under pressure could trash a motherboard.
Included with the SK7 are fan clips for 60, 70 and 80 mm fan mounting – very
versatile – plus a small tube of non-descript thermal grease.
THE TEST
I tested the SK7 with Vantec’s Tornado, a Sunon 80 x 38mm fan, model #PMD1208PMB1-A rated at 84.1 cfm @ 5700 RPM, 55.2 dBA, 9.1w; this fan features vanes in the base to straighten airflow off the blades. I varied voltage to get a range of fan speeds and measured rpms using an Omega digital techometer.
I measured noise using a Radio Shack sound meter placed 8″ from the fan’s intake and recorded noise at a number of rpms – these should not be far off the mark far other 80mm fans at similar rpms. I normalized the readings I found to the manufacturer’s spec for the fan, as shown in the table below.
The SK7 was first tested on the CPU Die Simulator which gives results that are unaffected by motherboard influences. I then tested it on a Shuttle AK31, which is modified to read AMD CPU die temps directly, as an example of what users might see on their systems.
TEST RESULTS – CPU Simulator
Heatsink
Die Temp
Ambient Temp
Delta
C/W
SK7, 5567 rpm, 55 dBA
40.0 C
22.6 C
17.4 C
0.25
SK7, 4466 rpm, 51 dBA
43.4 C
25.4 C
18.0 C
0.27
SK7, 3524 rpm, 47 dBA
44.3 C
26.1 C
18.2 C
0.30
SK7, 2526 rpm, 38 dBA
44.7 C
25.7 C
19.0 C
0.34
TEST RESULTS – Motherboard
CPU/Motherboard
CPU Die
Ambient Temp
Delta
C/W
MBM CPU Temp
Shuttle AK31, 5621 rpm
41.6 C
23.3 C
18.3
0.28
31 C¹
¹ In socket thermistor reading.
Delta = CPU temp – Ambient Temp
C/W = Delta / CPU Watts
Interpreting C/W: For every watt (CPUw) that the CPU
consumes, the HSF will limit the CPU’s temperature rise to (C/W x CPUw)
plus the temperature at the HSF’s fan inlet. For example, at an ambient temp of 25 C, a C/W of 0.25 with a CPU radiating 50 watts means that CPU temp will increase 50 x 0.25 = 12.5 C over ambient temp, or 37.5 C. The lower the C/W, the better.
Die Simulator results place the SK7, running at 5567 rpm, in the top rank of heatsinks (Heatsink Ranking).
The difference between aggressive cooling/high noise and “reasonable” cooling and noise is about 9 C over 100 watts. For a CPU radiating half that, the difference starts to fade very quickly (note: 38 dBA is the generally accepted noise standard for PCs).
The C/Ws shown here are at high load for at least 30 minutes – the number of times most users even come close to this loading is minimal.
The upshot is that for the AVERAGE user who is not pushing the CPU and spends most of the time for surfing and email, a quiet fan, such as the Vantec Stealth, might do the job OK. Each user must make a choice, balancing cooling needs vs noise tolerance.
CONCLUSIONS
Thermalright’s SK7 is a fine choice for Socket A cooling. Depending on how aggressive your cooling requirements are, noise can range from the sublime to the ridiculous.
The SK7 is available from The Heatsink Factory.
Email Joe
