Thermalright TY-143 and TY-147A 140 mm Fan Review
Thermalright was founded in 2001, a long time ago in computer time. Since the outset, Thermalright has focused on heatsinks and fans — just cooling. No Thermalright PSU’s or cases. Even their accessories involve heatsinks and airflow. This is one dedicated company. Today we will be looking at two of Thermalright’s 140 mm PWM fans, the TY-143 and the TY-147A. If you have been following 140 mm fans at all, you know that Thermalright’s TY series of PWM fans are said to be among the best. Are They? Thermalright has sent us a pair of each to evaluate. Let us see.
00Features and Specifications
About the TY-143, Thermalright tells us:
PWM fan, provides simple and easy adjustment of fan speed with the latest ETC IC .
Seven Silent Torpedo Blades – “submerges”, gives most quiet and efficient airflow.
Two Ball Bearing – to ensure consistent and stable rpm, prolonged lifetime of usage.
Aerodynamic body–Less friction around the edges and give more centered and concentrated airflow.
As for the 147A, the only difference in features is that instead of two ball bearings, it has “Enhanced Hyper-Flow Bearing (EHFB) – to ensure consistent and stable rpm, prolonged lifetime of usage.”
Maybe you noticed that these fans do not have square frames. Like the TY-140 and the classic NF-P14, these fans have round frames, with screw-holes the same as for 120 mm fans – in other words, 105 mm apart. These fans go well with any heatsink that uses 120 mm fans but have room for 140 mm fans. These include the NH-D14, NH-D15 and the Megahalems, not to mention a slew of Thermalright heatsinks. If you have fan clips for 120 mm fans or 120 mm style screw-holes, those clips will fit the TY-type 140 mm fans. Thanks to doyll we have permission to use his diagram of these fans:
TY Diagram
Why doesn’t the TY series also come in square frames? Perhaps this is because Thermalright has been concentrating on heatsinks. They do make a fan with a square frame. It is called the X-Silent 140 and we will look at its performance later. For now, we can examine the specs of these fans. Some specs are on the Web, some were provided directly by Thermalright:
Model
X-Silent 140
TY-143
TY-147A
Speed in RPM
900
600 – 2500
300 – 1300
Energy in Watts
n. a.
1.8 – 7.2
1.2 – 2.4
Current in Amps
0.14
0.15 – 0.6
0.1 – 0.2
Static Pressure in mmH2O
n. a.
0.25 – 4.21
0.08 – 1.56
Sound Pressure in dBA
20.9
21 – 45
15 – 21
Airflow in CFM
60.2
16.69 – 73.64
31.46 – 130.04
Length in mm
140
151
151
Width in mm
140
140
140
Thickness in mm
25
26.5
26.5
The Fans
Most Thermalright fans come packaged on plain brown cardboard boxes with no accessories. The boxes outline the features and basic specifications of the fan inside. The packaging is recyclable.
01
TY-143 Box
TY-147A Box
TY-147A Box
The TY-147A and TY-143 are PWM fans. From the blade coverage, they look to be focused on static pressure. Notice that the fans cables are tightly sleeved and ended with well-fitted heatshrink.
TY-143
TY-143
TY-147A
TY-147A
Another issue is blade shape. These blades look to be very like the blade you will find on the impeller of the NF-A14 and the NF-A15.
TY-143 and NF-A15
TY-143 and NF-A15
Testing Setup
The fans were tested in an 8x8x8-inch box, with a circular exit window that matched their input aperture. The head of an Extech AN-100 was placed there. It averaged ten CFM measurements. Each fan was tested while pushing through a Hardware Labs Black Ice Nemesis 140GTS radiator (16 FPI). Whew! Lots of names. The second testing condition was to put the fan on the box, covered by a 140 mm generic metal mesh dust filter available through various vendors. Finally, each fan was tested in an unobstructed state.
This was fine for square-framed fans. But the screw-holes of round-framed fans do not line up with the screw-holes of a 140 mm filter. The answer came from an old retail version of the NF-P14. It came with four metal adapters which would reach from the fan’s screw-holes to standard 140 mm screw-holes. Those adapters adapted the fans to the radiator. Looking at the picture, you can see how that worked. Included in the picture is the dust filter it would draw air through, the anemometer head’s handle, and the anemometer itself.
Setup
Fan Testing Setup
The comparison actually began with square fans. An almost-unused eleven-bladed X-Silent obtained at retail some years previously was tested against two seven-bladed NF-A14 fans, slowed to 1200 RPM. The latter were provided by Noctua. The reason for this test was to see why Thermalright had the X-Silent 140 as its only square frame 140 mm fan.
Following that, the main comparison pitted the round-frame Thermalright TY-14x fans against two “known good” fans, the Noctua NF-A15 and the NF-A14 iPPC 3000, all provided by Noctua (a big thank-you to both fan manufacturers). The fans were matched for speed. Because the NF-A15 fans have a nominal speed of 1200 RPM, those fans and the two TY-147A fans (nominally 1300 RPM) were all slowed to as close to 1200 RPM as I could get them. The TY-143’s have a nominal speed of 2500 RPM and the NF-A14 iPPC have a nominal speed of 3000 RPM, so all of those fans were slowed to 2400 RPM. Speeds on all fans were controlled either by the motherboard’s PWM function or by a Zalman Fan Mate. The results for each of these fans were shown separately to highlight the manufacturing variability that you will find in any man-made thing. All RPM measurements were through a utility on the motherboard.
TY-143
TY-143 – Angle View
TY-147A
TY-147A – Angle View
Results of Testing
Let’s look at the X-Silent 140 first. We can see that it is not for radiators. Even on this rad with only 16 fins per inch, it was inhibited. But when there were no obstructions, even at a lower RPM its eleven blades allowed it to catch up to the NF-A14.
X-Silent
One interesting thing: the X-Silent sounded about as loud as the NF-A14 but it had a higher pitch. This makes sense. In the standard formula, the “Blade Pass Frequency” BPF = n*t/60, where n = rotation velocity in RPM and t = number of blades. The number 60 converts revolutions per minute to beats per second. So, for the X-Silent, 953*11/60 = 174. I checked the pitch with a website named the “Online Tone Generator,” which converts a frequency number to a tone. The calculation and the tone matched. The NF-A14, with its blade-count of 7, sounded lower in pitch than the X-Silent.
Comparing the TY fans to the known good fans at the same RPM, the TY fans did quite well.
PWM
The TY-143 is listed for sale at Nan’s Gaming Gear for $16.95. The TY-147A is listed there for $14.95. At other sites these fans were listed as “Currently Unavailable,” but you could find them mounted to various Thermalright heatsinks.
Pair
Pair of TY Fans
Conclusions
The TY-143 and the TY-147A fans perform very well. They are quiet, and they push a lot of air. They are controlled by PWM circuits that do not make any noise. The TY-147A even seems to break the rule that good fans have to come in odd colors.
We learned that there is a tradeoff between pitch/frequency and CFM: with more blades you get more CFM but a higher pitch, which doesn’t sound as nice as a lower pitch fan. This might explain why the TY series has fewer blades than the X-Silent.
The TY fans do very well on heatsinks. As we have seen, they should do very well on radiators as well.
But most of all we learned that the TY fans from Thermalright are very good fans indeed. And their price is moderate.
TY Pros
  • Move a lot of Air
  • Quiet
  • PWM Silent Circuits
  • Well Sleeved and Heatshrinked
  • Moderately Priced
TY Cons
  • Limited Availability
  • No Square-framed TY Fans . . . Yet
Click the stamp for an explanation of what this means.
Ed Hume (ehume)
About Ed Hume 75 Articles
Ed Hume has been a contributor to the Overclockers.com community for over 10 years. He has written nearly 100 reviews and guides mostly focused on cooling. His scientific and technical approach to analyzing airflow, temperatures, heatsinks and fan performance have made him a fan favorite. In one of his well-known fan roundups, he compared the performance of over 60 fans at once, now that's dedication to the craft!
Loading new replies...
