Thermaltake Dragon ORB 3
Add Your Comments
SUMMARY: Thermaltake jumps on the copper bandwagon with an ORB that is acceptable for cooling AMD’s CPUs.
ORB 3
The good folks at Thermaltake were nice enough to send us a sample of their latest, the Dragon ORB 3. This ORB has at its core a copper cylinder about 1 1/2″/40mm long by 1 11/16″/43mm in diameter. This cylinder has 110 pins cut into its top about 5/16″/8mm long.
Inside
The copper core is surrounded by circle of aluminum fins (blue in the picture above) that looks to be a friction fit. Good cooling performance depends on a very tight fit between the two.
Fan
On top of this base sits the fan (7000 rpm, 38 cfm, 37 dBA – Thermaltake specs) surrounded by a ring of very delicate fins. If you hold the ORB 3 by these fins, you will push them in. I expect many will find this out the hard way.
These fins are non-functional for cooling – there is very little contact between the fan assembly and the base, where all the cooling action takes place. As you can see from the pic above, there are three contact points for attachment to the base:
Strut
As this detail shows, the fan assembly is screwed onto the base with three metal screws. The point of attachment is minimal:
Strut Attach
This means that there is little, if any, cooling from the fan assembly’s fins to the base; the sole function of this top piece is to house the fan.
Base
The copper base shows slight concentric machining marks that you can feel by dragging your fingernail over it. The ORB 3 ships with a thermal pad which I did not use – I removed it and used Arctic Silver instead.
Clip
The clip can engage all the socket’s lugs (this I like) and is very secure – so secure that you can’t reasonably expect anyone to mount this heatsink with just your fingers. The semi-circular cutout is for the screwdriver shaft; the tab near the bottom is for the blade. Using a screwdriver, the ORB 3 mounts OK but I found I had to exert some force to get it onto the socket’s lugs.
Getting it off is another matter – I doubt very few can exert enough finger force to get the clip below the socket’s lugs while rotating the clip away from the lugs at the same time. In addition, I inadvertently removed one leg of the clip from the front piece, so please be careful when manipulating this clip.
The clip is very secure partly because the ORB 3 weighs in at about 640 grams – almost 1 1/2 pounds. This is not an AMD or Intel spec heatsink and is clearly targeted to the performance market.
THE TEST
The following test results were on an Iwill KK266, T-Bird 1133 @ 1330, 1.85 volts – 82.7 watts; Duron 800 @ 1000 on an ABIT KT7, 1.9 volts – 63.1 watts; PIII 700 @ 933, 1.8 v – 29.2 watts. AMD CPU watts were calculated by the formula shown below. All motherboards ran Prime 95 to stress the CPU, temps taken after at least one hour. The static test block radiating 47.4 watts was also used.
A 1/16″ hole was drilled through the copper core and a thermocouple was epoxied into place over the center of the CPU’s core. Ambient temps are measured 1″ from the heatsink fan’s intake. Fan Noise was 69 dBA, measured using a Radio Shack sound meter placed 8″ from the fan intake; this is slightly less noise than a Delta 38.
CPU back temps were recorded using a thermocouple placed inside the socket and located at the CPU’s back center. Motherboard Monitor (MBM) temps used the in-socket thermistor for AMD CPUs and the on-die diode for the PIII 700E.
TEST RESULTS – Thermaltake Dragon ORB 3
Test Platform
CPU Temp
Ambient Temp
Delta
C/W
MBM
CPU Back Temp
Static Block – 47.4 watts
36.8 C
23.7 C
12.7 C
0.27
NA
NA
Iwill KK266 – T-Bird 1330MHz @ 1.85v
45.7 C
26.5 C
19.2 C
0.23
43 C
54.5 C
ABIT KT7 – Duron 1000MHz @ 1.9v
42.0 C
26.3 C
15.7 C
0.25
41 C
44.0 C
Iwill BD133 – PIII 933MHz @ 1.8v
32.8 C
25.0 C
7.8 C
0.27
37 C
NA
Delta = CPU temp – Ambient Temp
C/W = Delta / CPU Watts
CPU watts = (new MHz/spec MHz)x((new volts/spec volts)^2)xspec CPU watts
Interpreting C/W: For every watt the CPU radiates, the heatsink will cool the core by the (C/W x watts) plus ambient temp. For example, at an ambient temp of 25 C, a C/W of 0.25 with a CPU radiating 50 watts means that the CPU temp will be 50 x 0.25 = 12.5 C over ambient temp, or 37.5 C. The lower the C/W, the better.
CONCLUSIONS
The Dragon ORB 3 turns in some respectable test results, placing it about mid-range of the current crop of heatsinks with C/Ws of 0.30 or lower. As for almost all these heatsinks, performance comes at the expense of high noise levels.
This is the first ORB I have tested that performs acceptably for AMD CPUs, so if you’re an “ORBie”, this is one you can use with some degree of comfort.
Email Joe
Leave a Reply
