Thermaltake HARDCANO 2
Effective hard drive cooler and dual temp sensor – Joe
SUMMARY: Effective hard drive Cooler/Temp Sensor from Thermaltake.
The fine folks at Thermaltake were nice enough to send over a sample of their combination hard drive cooler/dual temp sensor unit called the HARDCANO 2 (how they came up with this name is beyond me – that’s why they call it the “Mysterious East”).
Hardcano 2
The HARDCANO 2 ships unassembled with a bunch of parts, including drive rails, screws, power plug adapter and tape for the temp probes.
The probes
Probes
are thin enough to slip under a heatsink to contact the side of a CPU. The thin green wires are about 4″ long and the probes about 36″ – long enough to mount just about anyplace in a case.
There are three screw types:
Screws
The small one is important – there are only two, so don’t lose them.
You have to mount the drive rails to the body – there is an instruction page that is not exactly clear on how to do this. I played around with it and found that you have to mount the drive rails this way:
Bracket
Not that there is only one small screw holding each bracket in place. At first, I thought this would be kind of flimsy, but it does the job. The two holes on the right have raised edges that seat into the side, ensuring that the rail does not rotate.
When you mount the unit into a 5¼” slot, everything snugs up nice and secure. This is what it looks like with a hard drive:
Installed
Slip the unit into an empty slot
Face
and you’re off and running.
Performance
I checked the temp sensors against my digital thermometer and found them within +/-0.5 C, which is OK. I also found that the sensors did not exactly agree with each other, but only by about 0.3 C – fine for temp monitoring purposes.
I mounted an IBM drive into it and I’m using it as I write up this review. I plugged the fan into a motherboard fan header – it reads about 4500 rpm (spec: 5.1 cfm @ 5000 rpm +/- 10%). It is quiet and, unless your system is literally silent, you won’t hear it (spec: 23 dBA).
Note that the fan’s intake in unobstructed – the airflow, as a result, is pretty close to spec. I placed a probe at the case’s intake fan and one in the side of the hard drive rail so that the fan’s airflow would not hit the probe. After running with and without the fan, I found:
  • Fan OFF: 32.4 C
  • Fan  ON: 27.7 C
  • Case temp: 21.1 C
Frankly, this surprised me! I knew if would make some difference, but an almost 5 C is not bad at all. I think the unimpeded airflow helps its effectiveness.
Overall, a nice double-duty addition; gets key temps to the front of the case where you can see them and cools hot drives. For really hot drives, such as some of the IBMs, this looks like one solution.
Thanks again to Thermaltake for sending this our way. Available from Heatsink Factory.
  1. Thermaltake VOLCANO 11+
  2. Thermaltake Volcano 6CU+
  3. Thermaltake Volcano II
  4. Thermaltake Dragon ORB 3
  5. Thermaltake Silent PurePower Power Supply
Tags:
