TherMax Tech XtFlux - GA
Add Your Comments
Thermal grease test – Joe
SUMMARY: A well performing thermal grease.
Xt
The good guys at TherMax Tech were nice enough to send a sample of their thermal grease, XtFlux – GA to try out. This is a non-metallic, silicone oil based thermal grease.
The Test
I tested TherMax XtFlux – GA on the CPU die tester using a Glaciator Lite for the heatsink; the results shown below were after 24 hours and a number of thermal cycles:
Thermal Grease
Die Temp
Ambient Temp
Delta
C/W
TherMax Tech XtFlux – GA
43.8
20.7
23.1
0.33
Based on tests I did recently, These results place TherMax Tech XtFlux – GA in the same ballpark as Arctic Silver 5 – not bad company to be in.
CONCLUSIONS
TherMax Tech XtFlux – GA looks like a decent performing thermal grease; depending on pricing, could be a good buy.
Thanks again to TherMax Tech for sending this our way.
Email Joe
Leave a Reply
