9/6
2005
Thermosyphons – The Half Pint Test
Posted by Joe Citarella in Uncategorized
SUMMARY: Small 92 mm condenser delivers competitive performance.
One of our test objectives is to see how small we can get the condenser with “acceptable” performance; with micro case sizes taking an increasingly larger share of the market, a compact 92 mm thermosyphon could have some definite advantages. We took a 200 mm condenser, cut it in half and tested it with a single 92 mm fan.
THE TEST
The Thermosyphon shown above (spec’d for 200 watts) was tested on an Acorp 4S845A motherboard with a modified P4 1500 to read CPU case temps. For testing, I used 1 NMB 92 mm fan (#3610K4-04W-B50 vented) spinning at 3298 rpm.
TEST RESULTS – Acorp 4S845A Motherboard
| Motherboard |
CPU Case Temp
Ambient Temp
Delta
C/W
MBM Temp
| 3210 rpm, 61 dBA² |
33.2ºC
25.4ºC
7.8
0.14
34ºC¹
¹MBM on-die temperatures.
This places results in the top rank of P4 air cooled solutions I’ve tested to date (HERE), with the added benefit of a cooling solution that will handle 200 watts.
Another test I ran was using a die simulator with a die measuring one inch square at 69.7 watts. This test resulted in a C/W of 0.14 – similar to the Acorp result.
CONCLUSIONS
While not directly comparable to earlier thermosyphon tests (the boiler design is different, among other factors), it is interesting to note that this more compact design does not degrade markedly from a condenser twice as large – roughly a difference of about 0.02 C/W.
- Thermosyphons – Progress Report
- Thermosyphons – Better Approach to CPU Cooling?
- Passive Thermosyphon
- Five Thermal Grease Test
- Aqua Joe Watercooling Kit – Preliminary Test
Tags: Systems & Components
