A Contest Review. The good guys at Sunbeamtech.com were nice enough to send a Tuniq Potency Power Supply to check out.
This power supply features a quiet 120 mm fan for cooling.
{highslide}articles/Tuniq_Potency/tun1.jpg{/highslide}
Connectors:
1 * 20+4Pin Mainboard
2 * PCI Express (1 * 6Pin, 1 * 6+2Pin)
1 * 4Pin Molex Y Cable
4 * 4Pin Molex
1 * 4Pin FDD
4 * SATA
1 * 8Pin EPS12V
1 * 4Pin P412V
The nominal specs are shown below, as a decal on the power supply:
{highslide}articles/Tuniq_Potency/tun2.jpg{/highslide}
I’m kind of booked out for a while, so I thought I’d combine a contest and review in one – Email Joe with your test plan for this power supply, showing how you would stress it to see just how quiet and warm it gets under serious use – temp measurements should be a part of the test plan. I’ll pick what I think is the best test plan considering the tester’s available resources and send it for testing – the reviewer gets to keep the power supply for his/her efforts.
As always at Overclockers.com, I expect an objective analysis.
Related posts:
- Vantec Ion2 Power Supply
- HEC-350TW-TX Power Supply
- Zalman Low Noise Power Supply
- Global Win Power Supply #SAF420 420W-P4
- How to Power Your Water Pump Without Cutting Into Your Power Supply
Tags: Systems & Components
