UXD Quick Tech Personal
Add Your Comments
Versatile software tool for serious PC hardware trouble shooting and burn-in – Joe
SUMMARY: Versatile software tool for serious PC hardware trouble shooting and burn-in.
QTP Kit
Pic courtesy of UXD
UXD was nice enough to send a sample of their Quick Tech Personal system diagnostic software suite. This is a software version that contains some of the test routines found in Quick Tech Pro. It does not have all of the features that are built into QuickTech Pro, such as the ability to save results, network testing and SCSI support. Similar to Quick Tech Pro, you can boot-up the test routines directly without the OS, although you can run tests also from the OS (running DOS). The test suite has multiple uses – it’s not only for debugging.
If you mention Overclockers.com when you call-in, you can purchase QuickTech Personal for only $79.00 – a saving of 38%. Also included is a free QuickTech Personal CDROM version of the software.
Package Contents:
  • QuickTech Personal Bootable Diskette
  • QuickTech Personal Bootable CDROM
  • 2 – 9 pin Serial Loopback
  • 1 – 25 pin LPT/COM Loopback
  • Technician Certified Labels
  • Resource CDROM
QuickTech Personal performs the following:
  • System Configuration Information:
    On screen details about a systems configuration including CPU, math coprocessor, video, parallel and serial ports, floppy drive and hard drive specifications.
  • RTC/CMOS RAM Tests:
    Performs a memory data and address test on the systems Real-Time Clock/CMOS RAM; plus tests all CMOS
    functions and Interrupt generation.
  • Base and Extended RAM Tests:
    Tests base RAM up to 640 kb and extended RAM up to two gigabytes using up to 9
    multiple pattern testing algorithms.
  • External Cache RAM Tests:
    Performs cache detection, sizing and a low-level memory data and address test on the systems external cache.
  • Hard Drive Tests:
    Provides a series of non-destructive tests including controller, seek and read tests to check a drive’s overall condition. All IDE drive types are tested.
  • Floppy Drive Tests:
    Provides a series of tests to verify a system’s floppy drives are functioning properly including read and write tests and rotation speed test.
  • CD-ROMs:
    Complete testing and benchmarking of EIDE CD-ROMs; direct testing without the need for drivers etc.
  • Video Tests:
    Tests various color and alignment attributes of a SVGA /EGA video card, color monitor, plus tests graphics and text modes supported by a VESA-compliant video card.
  • Parallel and Serial Port Test:
    Performs internal and external loop-back tests on active LPT and COM ports.
  • Printer Test:
    Tests one or more printers connected to the system under test at the active LPT ports.
  • I/O Port Monitor:
    Byte-level display utility that provides quick address identification for all active ports. Helps troubleshoot address conflicts and locate unused addresses when installing option cards.
Basically, whatever you want to know about a system or to test any component can most likely be handled by Quick Tech Personal. In addition, the rigorous test routines are perfect for a full system burn-in. Running something like Prime95 only exercises a portion of the system; Quick Tech Pro’s test suite stress tests just about everything that can be tested (note that tests are sequential). As a burn-in tool, it can run for as long as you wish – I’ve run full system tests for 24 hours; it it’s going to blow, it should show up by then.
Screen Shots
I decided to show many of the test screens that are available – these are my screen shots.
As it boots up, the Intro Screen:
Intro
First selection:
ScreenShot
These give detailed data for each area.
Test screen for the system:
ScreenShot
This is an example of the test routines:
ScreenShot
For Disk Drives, you can get this data for hard drives:
IDE ScreenShot
IDE ScreenShot
IDE ScreenShot
ScreenShot
{mospagebreak}
The test routine for hard drives (note the drive timing):
ScreenShot
and the routine for CDs – there is also a floppy test, (not shown):
ScreenShot
Ram test – much more rigorous than OS based tests:
RAM
These test routines will display the failure point down to locations inside each chip.
Peripheral tests include Keyboard (not shown) and Serial Ports…
ScreenShot
and LPT ports (this is where you use the loopback plugs):
ScreenShot
Video test screen:
ScreenShot
You can read out all the possible display options…
ScreenShot
and perform a series of monitor test routines…
ScreenShot
including color testing:
ScreenShot
And finally, Burn-in:
Burn-in
This function exercises components on the system that typically are not included by running something like Prime95 or video tests routines.
CONCLUSIONS
UXD’s Quick Tech Personal is a comprehensive software system testing tool for burning in and certifying a total system or debugging the smallest part. Yes, there are freeware test utilities around, such as SiSandra, but for the level of detail and depth of testing outside of the OS, UXD’s Quick Tech Personal is hard to beat.
If you mention Overclockers.com when you call UXD, you can purchase QuickTech Personal for only $79.00 – a saving of 38%. Also included is a free QuickTech Personal CDROM version of the software.
Email Joe
Leave a Reply
