Vantec 1U #CCK-6012
Add Your Comments
A 1U, all copper heatsink — Joe
SUMMARY: A heatsink for the 1U market.
Vantec 1U
Size: 60 x 62 x 23mm high; Fan: 60 x 10mm, 21 cfm @ 4800 rpm; Weight: 220 gms.
The good guys at Vantec were nice enough to send a sample of their 1U heatsink, the Vantec CCK-6012. This is a sawed heatsink – its fins are cut from a copper block.
Heatsinks that meet 1U specs face a very difficult challenge – the height restrictions are such that fin height is severely compromised; consequently, there is a struggle to squeeze as much surface area and airflow into the package as possible. These heatsink are not intended for overclocked CPUs.
The base
Base
is very nicely done – flat and polished.
The fan is an Delta Model #R127015DU – a 60 x 10mm unit rated at 21 cfm @ 4800 rpm. I found it to be quiet – I measured its noise at 57 dBA with a Radio Shack sound meter 8″ from the fan’s intake, substantially less than a YS Tech 26 (about 62 dBA).
The clip does not require a screwdriver to mount onto the socket – it was easy to use and is a plus.
In summary, a fairly conventional copper, sawed heatsink with a secure and easy to use clip.
THE TEST
The Vantec CCK-6012 was tested on the CPU Die Simulator which gives results that are unaffected by motherboard influences.
TEST RESULTS – CPU Simulator
Heatsink
Die Temp
Ambient Temp
Delta
C/W
Vantec 1U #CCK-6012
70.2 C
19.2 C
51.0 C
0.65
Delta = CPU temp – Ambient Temp
C/W = Delta / CPU Watts
Interpreting C/W: For every watt the CPU radiates, the heatsink will cool the core by the (C/W x watts) plus ambient temp. For example, at an ambient temp of 25 C, a C/W of 0.25 with a CPU radiating 50 watts means that the CPU core temp will be 50 x 0.25 = 12.5 C over ambient temp, or 37.5 C. The lower the C/W, the better.
Die Simulator results place the Vantec CCK-6012 in the bottom ranks of heatsinks (Heatsink Ranking). Vantec’s published spec is 0.78 C/W, so we found it to perform better than spec.
CONCLUSIONS
The Vantec CCK-6012, with some more airflow, might perform better, but as usual, increased airflow = increased noise. The 1U market is a very tough challenge.
Thanks again to Vantec for sending this our way.
Email Joe
Leave a Reply
