Vantec EZ-Swap EX 666
SUMMARY: Attractive, durable SATA package for mobile storage.
NEX
The good guys at Vantec sent over a sample of their EZ-Swap EX internal/external 2.5″ SATA hard drive enclosure to try out. This is a very sleek, aluminum alloy unit for portable storage which slides into a SATA sleeve docking unit that can be installed on your PC (Note: This will work as a hot-swap unit if your hard drive controller supports this feature).
Enc + Back In
  • Mounts into 3.5″ or 5.25″ PC Bays
  • Interfaces: Internal SATA, External USB 2.0
  • Sizes: External Enclosure: 141 x 73 x 16mm; Sleeve 144 x 100 x 24mm
  • Aluminum External Enclosure, Plastic 3.5″ Sleeve
  • LEDs for Power and HD Activity
  • Parts include USB Cable, SATA Cable, Power Cable, Manual, Carry Case and Mounting Screws
ENC + Back
Carry Case
Parts
Mounting a 2.5″ SATA HD requires removing two screws from the external enclosure’s back plate – the PCB easily slides out:
Apart
The SATA connector:
Connector
The back of the PCB shows the controller chip:
PCB
  1. Vantec EZ-Swap EX
  2. Vantec EZ-SWAP MRK-200ST-BK
  3. Vantec NexStar 3i
  4. Vantec NexStar 3 NTS-360SU
  5. Vantec NexStar 2.5″ HD Enclosure
Tags:
