Vantec Mach 1 Heatpipe Heatsink
Add Your Comments
Heatsink Test – Joe
SUMMARY: A OK choice for non-aggressive P4 cooling.
Mach 1
Size: 83 x 70 x 85 mm; Weight: 515 grams.
The good guys at Vantec were nice enough to send a sample of the Mach 1 heatpipe heatsink for a test spin. Mounting options include gear for Intel Pentium4 (Socket 478), AMD Athlon 64 (Socket 754), AMD Athlon 64FX (Socket 940), AMD Sempron 64FX (Socket 754)and AMD Opteron 64FX (Socket 940).
The fan is infinitely adjustable with a PCI slot-mounted slide switch:
Rheostat
The 70 x 15 mm fan is rated at 2800 – 3800 rpm, 29 – 34 dBA. The full package:
Mach 1 Slide
This is a twin heatpipe unit:
HP
There are two sets of fins, the smaller set on the base and the large array to cool the heatpipes.
Mounting is straight forward – there are two clips which engage the P4 retention bracket. Note that the clips are off center, so you must “stagger” them.
Parts that ship with the unit allow for multiple mounting options:
Parts
The base is well finished:
Base
When I ran my nail over it, I could not feel or hear any ridges.
THE TEST
The Vantec Mach 1 was tested on an Acorp 4S845A motherboard with a modified P4 1500 to read CPU case temps. I tested the Mach 1 at its highest and lowest fan settings.
TEST RESULTS – Acorp 4S845A Motherboard
Motherboard
CPU Case Temp
Ambient Temp
Delta
C/W
MBM Temp
4095 rpm, 58 dBA²
33.8 C
20.1 C
13.7
0.24
32 C¹
3016 rpm, <50 dBA²
35.9 C
20.3 C
15.6
0.27
33 C¹
¹MBM on-die temperatures.
Results place Vantec’s Mach 1 in the lower rank of P4 heatsinks tested to date (Heatsink Ranking).
Small Die Test
I have built a new die-tester with a 100mm² die. This is about as severe a test as can be devised – there are no comparable results to compare this to yet. I will be reporting dual results to get some idea of the relationship between the two methods.
Test
Die Temp
Ambient Temp
Delta
C/W
4078 rpm, 58 dBA²
49.9 C
19.5 C
30.4
0.43
3034 rpm, <50 dBA²
52.7 C
19.6 C
33.1
0.47
CONCLUSIONS
Vantec’s Mach 1 Heatpipe is attractively packaged and an OK choice for non-aggressive CPU cooling.
Thanks again to Vantec for sending this our way.
²Note that manufacturers measure fan noise usually 3 feet from the fan.
Email Joe
