What's that?
Add Your Comments
I came across a great site where you can find what processes do which are running on your PC when you enable Windows Task Manager called File Inspect Library. Use it with care but a quick way to find out what those cryptic files running on your PC are all about and if it is malware.
Leave a Reply
