Winchester Double Barrel Water Cooling Mod
Adapting a Thermalright SK6 heatsink for watercooling. — Terry Miller
Your site inspired me to try a water mod on my own. I received a damaged Thermalright SK6 and decided that I couldn’t hurt it any more. So I created this water cooling mod after learning about water cooling from your site. I called it my “Winchester Double Barrel Water Cooling Mod”.
Done
On the inside I made an “S” curve from one of the inward barrel ends to flow the water across the area directly above the
CPU> There is a baffle on the other side to help prevent any vortices while exiting.
Top
Here’s the SK6 before:
SK6
The areas marked in blue were trimmed to fit the pipe’s contour.
Assembly
I don’t have results yet but will post them when I do.
  1. Duron Double-Peltier Cooling Results
  2. Logic Cooling Nemesis Waterblock Mod
  3. Cheap As Free Air Cooling Mod
  4. My Water Cooling System
  5. Blizzard Water Cooling System
Tags:
