XBOX Cooling
Add Your Comments
SUMMARY: More on this later – first some questions.
Pic
If you have an XBOX, it’s a hot product – both figuratively and literally. What I’d like to hear from some XBOX owners is your experience with heat – has this been an issue for you? Have you experienced any heat-related issues affecting your XBOX’s performance? Appreciate your views – thanks!
Reader’s responded with some experiencing problems and some not – selected excerpts below:
Ryan
“I would just like to say that I’ve gone through 2
xbox360’s now that have had heat problems and freeze
up, even in the middle of a golf game. Ive exchanged
one in on the 30 day best buy warranty and after that
one had heating issues also I gave up on the xbox
completely.”
Henry
“No heat problem with Xbox 360… just noisy fan…”
Kevin
“I have had my xbox360 since launch roughly. I say roughly because even though it was pre-ordered, my order was not fulfilled until the end of January. I have had many hours of enjoyment from the box and did not encounter any problems heat or otherwise until recently. You might ask what changed? Gears of War is what changed – that game would make my box overheat faster than anything else before it.
My fix was the Nyko Intercooler. Yes – I read all of the “bad press” regarding the intercooler and it causing issues with the xbox so I rewired it before I ever plugged it in. My intercooler is powered externally off a 9v dc power brick that I had laying around. Now it is silent and the box never overheats. Perfect.
My only gripe is why should I have to go through all of those steps to make this thing operate as advertised? I mean I love the xbox and all but they were very over optimistic with their cooling solution that they came up with.
silver32
I’ve had an Xbox360 since day 1. Yes it’s hot. The fans in the back blow some hot air, Like a hair drier. It has worked perfect and have no complaints.
There is another after-market cooling solution called the XCM 360 in addition to the Nyko. The availability of these products and forum comments on XBOX cooling indicates that for some users there have been significant cooling issues.
I have to agree with Kevin – does it really cost XBOX that much more to include a decent cooling solution?
{mospagebreak}
XBOX Thermosyphon Cooling
Some XBOX consumers have had problems with overheating and we thought it would be an interesting project to see what a thermosyphon cooling solution would do compared to the stock XBOX heatsink.
Pic
The following comparisons were run with the stock heatsink in place, then with a thermosyphon (pictured above) cooled by the XBOX’s stock 70 mm fans and finally with 2 120 mm fans pulling air through the XBOX as pictured below (CPU Temps were measured by a thermocouple, diamond thermal grease was used):
Fans
Shown below are CPU temps over ambient – the thermosyphon is a clear winner compared to the stock heatsink; what’s interesting to note is that the 2 120 mm fans, while delivering better cooling, is not substantially better than using the stock 70 mm fans (an external power supply was used to vary voltages).
Graph
This chart is the same as above but with no correction for ambient temps – note that the thermosyphon at 6 volts cools as well as the stock heatsink at 12 volts – virtually the same cooling at substantially lower fan noise:
Graph
We used a single large boiler to cool both the CPU and GPU:
Graph
Shown below are stock heatsink temps vs temps using 2 120 mm fans on the thermosyphon. Running both GPU and CPU off one boiler may not be the best way to do this as the temp differential is not overwhelming.
Graph
Below is a comparison of the stock heatsink and thermosyphon with the stock 70mm fans pulling air through the case. Note that the thermosyphon has the same performance at 6 volts as the stock heatsink running at 12 volts – a substantial noise reduction.
Graph
In looking around at water cooling the XBOX, the thermosyphon delivers substantially the same performance at low cost with far less complexity (no waterpump, no maintenance required).
Overall, this was a fun project – a thermosyphon cooling option might be viable with a smaller condenser so that the whole solution fits inside the XBOX.
Email Joe
Leave a Reply
