A good choice for aggressive cooling.
The good guys at Xigmatek were nice enough to send a sample of the Xigmatek HDT-SD964 heatsink. This is a “direct contact” heatsink – the heatsink’s heatpipes are in direct contact with the CPU’s IHS.
- Aluminum fins, four copper heatpipes directly contacting the CPU
- Dimension 140 x 95 x 79 mm
- Fan speed 2800 rpm, 55 cfm, 34 dBA – four pin molex connector
- Weight 466 grams
- All Intel® Socket LGA 775 CPU ((Core™2 Extreme / Core™2 Quad / Core™2 Duo / Pentium® Extreme Edition / Pentium® D / Celeron® D) Pentium® D / Celeron® D)
- All AMD Socket AM2 / 754 / 939 / 940 CPUs (Athlon™ 64 / FX / X2 / Opteron™ / Sempron™)
The fan mounts with rubber pins which serve to isolate fan noise; included are four extra pins for a second fan, if desired. It might be easier to mount the fan after mounting to the motherboard, as there is a tight fit with the two pins under the fan.
The base is made from the bottom of the heatpipes:
Mounting is very simple with four push-pins – this system does not require removing the motherboard from the case.
The Xigmatek HDT-SD964 was tested on an Asus P5WD2 motherboard with a modified Pentium D 805 to read CPU case temps while running Prime 95. For this test, I ran it first with one fan and then with two fans in a push-pull configuration.
| Heatsink |
Case Temp
Ambient Temp
C/W
On-Die Temp¹
| Xigmatek HDT-SD964, one fan 2778 rpm, 53 dBA² |
41.6
24.7
0.18
51
| Xigmatek HDT-SD964, two fans 2813 & 2935 rpm, 57 dBA² |
40.5
25.0
0.16
51
¹On-die temperatures.
²50 dBA measured 8″ from the fan intake corresponds to about 30 dBA measured 3 feet from the fan, a very quiet noise level.
Performance with one fan is quite good, landing in the upper third of heatsink’s tested to date HERE. With two fans performance increased by 2ºC – whether this is acceptable considering the increase in noise levels is up to each user to determine. Xigmatek’s HDT-SD964 is worth a look for aggressive cooling.
Thanks again to Xigmatek for sending this our way to test out.
Disclosure: Joe Citarella has a financial interest in a company developing products for electronic chip cooling.
Related posts:
- xigmatek Apache CD901 Heatsink
- SunbeamTech Core Contact Heatsink
- JETART MiniStand Notebook Cooler
- NewerTechnology Portable Toolkit
- JETART CoolStand3 Notebook Cooler
Tags: Cooling
