Zalman CNPS 5000
Add Your Comments
SUMMARY: No such thing as a free lunch: With air cooling, if you want low noise, expect low performance.
Zalman
Key stats: 91 x 66 x 70 mm, weight 230 grams, 64 fins, 0.92 ft² est. surface area.
The good guys at CoolingGears sent over the Zalman CNPS 5000 to test out. This is an aluminum radial fan heatsink powered by an 4100 rpm 60mm fan. It ships with a whole kit bag of goodies including bolts for either Socket A or PIV cooling, thermal grease, gaskets and resistors to enable what Zalman calls “Low-Noise” and “Silent” Mode.
Interestingly, if you use either one of these, it may drop the voltage so low that BIOS will not pick up the fan’s rpms (at least that happens with the Iwill KK266+; Zalman makes note of this in the instructions). I did not test these modes – the fan was barely ticking over in “Silent” Mode and I can only imagine how hot a T-Bird would get.
The construction method is very interesting. It looks like the fins are arrayed in a stack, and then two aluminum bars are pressed together under very high pressure to form the “core” of the heatsink. Once compressed, the bars are bolted together to hold the assembly in place. This top view gives you an idea of what it looks like:
Top
The pic below is of the base:
Base
Mounting does require that you remove the motherboard from the case. The four knurled brass standoffs are secured to the motherboard by screws secured from the back of the motherboard. Once these are in place, the heatsink is screwed into the standoffs using the long, spring loaded bolts. You must use an alternating pattern to tighten these bolts to avoid any possibility of core damage. Once the standoffs are in place, mounting and dismounting is very easy.
I found the base very smooth – Here’s a closeup that gives a better view of how its built and finished:
Fin Detail
This view from the top shows the unobstructed airflow through the fins to the top of the CPU’s carrier. I calculated the fin area at about 0.92 ft². Zalman ships the heatsink with the fan blowing out, which helps to reduce noise; I measured fan noise at 57 dBA – the YS Tech 26 cfm unit comes in at about 61 dBA. The inner holes are for Socket A, the outer for PIV.
Top View
When you mount the Zalman, you will note that it sits off-center on the CPU:
Imprint
THE TEST
I prepared the Zalman by boring a hole through the base and side so I could epoxy a thermocouple above the CPU. The thermocouple is attached to an Omega HH23 Digital Thermometer. Ambient temps were measured with a thermocouple placed about 1 inch from the fan’s intake when blowing in, and at the base of the fins when blowing out.
I used Prime 95 to stress the CPU on an Iwill KK266+. Arctic Silver grease was used in all tests. CPU Case Temp is the temp at that point where the CPU contacts the heatsink, CPU Back Temps are measured by a thermocouple on the center back of the CPU.
TEST RESULTS
CPU/Motherboard
CPU Case Temp
Ambient Temp
Delta
C/W
MBM Temp
CPU Back Temp
T-Bird @ 1200/Iwill KK266+ Stock fan Blowing OUT (67 watts)
53.8 C
26.7 C
27.1
0.40
44 C
67.1 C
T-Bird @ 1200/Iwill KK266+ Delta 38 Blowing OUT (67 watts)
50.6 C
25.9 C
24.7
0.37
44 C
63.7 C
T-Bird @ 1200/Iwill KK266+ Delta 38 Blowing IN (67 watts)
50.9 C
27.9 C
23.0
0.34
41 C
61.2 C
Delta = CPU temp – Ambient Temp
C/W = Delta / CPU Watts
Interpreting C/W: For every watt the CPU radiates, the heatsink will cool the core by the (C/W x watts) plus ambient temp. For example, at an ambient temp of 25 C, a C/W of 0.25 with a CPU radiating 50 watts means that the CPU temp will be 50 x 0.25 = 12.5 C over ambient temp, or 37.5 C. The lower the C/W, the better.
Measuring ambient air temps with a fan blowing out is inherently difficult¹, so I would look to the results with the Delta 38 blowing in as more representative of its performance. Note that the anemic stock fan does not cut it in “Normal” Mode, so I did not want to test at lower airflows.
The differences between the in-socket thermistor reading and actual temps measured at both the back and top of the CPU is one of the largest variances I have seen. Using the in-socket readings for anything more than an early warning device can lead to very misleading conclusions.
The Delta 38 did not push the Zalman into “acceptable” territory (< 0.30 C/W), which, I think, speaks to the use of aluminum. The copper version of this heatsink may be a better performer, although the use of a low-noise fan (= low cfms) will compromise its performance.
Zalman’s specs indicate a fan at 5600 rpm in “Normal” Mode (+/- 8 %). Even allowing for performance variance at 8%, the fan I received is way below spec at 4100 rpm. Even so, the Delta 38 numbers indicate a fan at spec will come in someplace between the two results.
Zalman’s published C/W specs are 0.27 for “Normal” Mode, 0.33 for “Low-Noise” and 0.40 for “Silent” Mode. To reach 0.27 C/W in this test, the Delta has to hit 18 C, compared to the observed 27 C – a 9 C difference, which is a bunch. I have written to Zalman for their test methodology to investigate this variance further.
CONCLUSIONS
Zalman’s design philosophy emphasizes noise reduction, a worthy goal (especially if you suffer the Delta 38 and its clones). However, heatsink noise is fan related, as is performance. Airflow is what makes it work, so performance rises and falls as do cfms, and as does noise.
The only heatsinks I have tested that will make the 0.30 cut without Delta 38 noise levels are the Glaciator, Swiftech’s 462A with the Sanyo fan and the Thermaltake SK6. The Zalman CNPS 5000 in aluminum does not make this cut.
Heatsink designers right now are between a rock and a hard place; acceptable air cooled performance dictates high air flow and heat transfer. Cost pressures dictate simple designs and common materials. All of these constraints continue to point to the “easy way out” – brute force air flow with Delta 38 (and its clones) fans on fairly conventional heatsinks. In my book, not a pretty picture and a great opening for water cooling.
Thanks again to CoolingGears for sending the Zalman our way.
¹Measurements are made along the heatsink’s base and averaged; the heatsink pulls air off the motherboard, and some areas are warmer than others due to components, such as capacitors, etc.
Email Joe
Leave a Reply
