ZEROtherm Heatpipe
Add Your Comments
Very low noise and performance – Joe
SUMMARY: Subdued noise, subdued performance; an OK low noise P4 solution.
ZEROtherm
Fan: 70 x 15mm, 2700 rpm, 18 cfm, 28 dBA; Radiator measures 70 x 70mm (2 3/4″ sq.); left is the P4 clip, right for a socket.
The kind folks at CoolingFlow were nice enough to send a sample of the heatpipe heatsink called the ZEROtherm, manufactured by Apack. This design is used for bot Socket A/370 and P4 cooling – a simple clip change and you can use it on either platform. Note that the maximum allowable CPU load is not more than 75 watts.
The heatpipes are routed up into the radiator:
Rad
The fan pushes air through it for cooling.
The base has channels machined into it for the clips:
Base Top
The heatpipes appear pressed into the aluminum base:
Pipes
I could not see any thermal grease between the heatpipes and base. The contact between the copper heatpipes and heatspreading aluminum base is critical to performance, as is the contact between the heatpipes and the radiator’s cooling fins. The quality of these interfaces directly impacts cooling performance.
One problem I noticed using it on a P4 is that the mounting clip does not ride in the base’s grooves:
P4 Mount
One of the heatpipes impinged on the clip (circled in red) such that it does not sit in the base’s grooves. This is not a problem that prevents its use with P4s, but be aware that this may happen.
The fan is an SDS Industrial Model #D7015sS- a 70 x 15mm unit rated at 18 cfm @ 2700 rpm, 28 dBA¹. I found it very quiet – I measured its noise at less than 50 dBA with a Radio Shack sound meter 8″ from the fan’s intake, substantially less than a Delta 38 (about 69 dBA). It’s also safe to use a motherboard fan header.
The base is aluminum and reasonably flat and smooth:
Base
In summary, a heatpipe heatsink with a very easy to use clip powered with a low noise fan.
THE TEST
The ZEROtherm was first tested on the CPU Die Simulator which gives results that are unaffected by motherboard influences. I then tested it on a Shuttle AK31 (modified to read AMD’s on-die diode) for Socket A and an Acorp 4S845A for P4, as an example of what users might see on their systems.
TEST RESULTS – CPU Simulator
Heatsink
Die Temp
Ambient Temp
Delta
C/W
ZEROtherm, 2909 rpm
57.0 C
19.6 C
37.4 C
0.54
TEST RESULTS – Motherboard
CPU/Motherboard
CPU Die/Case Temp
Ambient Temp
Delta
C/W
MBM Temp
XP @ 1467, Shuttle AK31
55.3 C
21.2 C
34.1
0.52
41¹ C
P4 @ 1500, Acorp 4S845A
37.4 C
20.8 C
16.6
0.29
31² C
¹In-socket thermistor per MBM; ²P4 on-die temp per MBM
Delta = CPU temp – Ambient Temp
C/W = Delta / CPU Watts
Interpreting C/W: For every watt (CPUw) that the CPU
consumes, the HSF will limit the CPU’s temperature rise to (C/W x CPUw)
plus the temperature at the HSF’s fan inlet. For example, at an ambient temp of 25 C, a C/W of 0.25 with a CPU radiating 50 watts means that CPU temp will increase 50 x 0.25 = 12.5 C over ambient temp, or 37.5 C. The lower the C/W, the better.
Die Simulator results place the ZEROtherm in the lower rank of heatsinks tested to date for Socket A and P4 cooling (Heatsink Ranking).
CONCLUSIONS
Once again, no such thing as a free lunch: Low noise air cooled solutions invariably yield low performance. Heatpipes are not magical nor particularly efficient compared to other technologies used for air cooling solutions (at least, not so far).
I think for heatpipes, the essential issue is the ability to overcome two thermal interfaces which “traditional” heatsinks do not face:
  • Base to Heatpipe
  • Heatpipe to Cooling Fins
The quality of both these joints directly impacts performance; the less efficient the joint, the less efficient overall thermal peformance, as demonstrated HERE. Considering these challenges and cost pressures, I wonder if any heatpipe solution can fill the bill.
The ZEROtherm is an OK solution for a low noise, spec P4 system; the maximum allowable CPU load is not more than 75 watts.
Thanks again to Y. Choi at CoolingFlow for sending this our way.
¹Note that manufacturers measure fan noise usually 3 feet from the fan.
Email Joe
