Table of Contents
Alphacool has announced its Core Distro Plates for all custom water-cooling enthusiasts. Constructed of clear acrylic with chrome-plated brass fittings and addressable RGB lighting, the new Core Distro Plates are sure to look fantastic in your next build. Four variants are available with two offerings in 240 mm and two in 360 mm sizes each compatible with VPP/D5 water pumps. Pricing starts at $172.86 and is available on Alphacool’s website. For complete details, see Alphacool’s press release below.
Alphacool Core Distro Plate
The new Core Distro Plate from Alphacool is a must-have for every performance-oriented custom water cooling system. It greatly simplifies the planning, construction and maintenance of complex water loops. The Distro Plate features an integrated reservoir with pump top for VPP/D5 pumps. Due to the arrangement of the G1/4″ connections, confusing and complicated tubing paths will be a thing of the past. Therefore, the Core Distro Plate is ideally suited for custom water loops in which CPU and graphics card(s) are to be cooled simultaneously.
A beautiful and elegant element of the Core Distro Plate are the chrome-plated, brass G1/4″ connectors. Recessed into the acrylic and fitted with an O-ring, the connectors are absolutely leak-proof and support the clean and functional look of the Alphacool Core Design series. The connections are not screwed directly into the acrylic to prevent cracking and resulting leakage.
Alphacool’s Core Distro Plate is made of high-quality acrylic, which allows a clear view of the coolant and provides brilliant illumination through the built-in, digitally addressable aRGB LEDs.
With the help of the included Core Push Mounting Kit, the Distro Plate can be easily mounted on the case panel or on a radiator. This ensures stable positioning as well as easy disassembly for maintenance or expansion projects. The Core Distro Plate is now available as 240mm or 360mm variant with left or right placement of the pump top in the Alphacool Online Shop.
Technical data
Core Distro Plate 240 Left VPP/D5:
– Dimensions: (L x W x H) 240 x 125 x 42mm
– Volume: 164ml
– Pump compatibility: D5
– Threads: 8x G1/4″ inner thread / 1x drain port
– Quantity digital aRGB LEDs: 12
Core Distro Plate 240 Right VPP/D5:
– Volume: 164ml
Core Distro Plate 360 Left VPP/D5:
– Dimensions: (L x W x H) 360 x 125 x 42mm
– Volume: 309ml
– Threads: 10x G1/4″ inner thread / 1x drain port
– Quantity digital aRGB LEDs: 18
Core Distro Plate 360 Right VPP/D5:
– Volume: 309ml
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Today, Alphacool released the Eisblock Aurora Acryl GPX-A water cooler for the reference design AMD RX 6700 XT GPU. Like all of the water coolers in the Eisblock Aurora series, it is made from nickel-plated copper is a full-coverage design, and includes an aluminum backplate. The MSRP is $166 and is available on the Alphacool website. The Eisblock Aurora Acryl GPX-A fits several other models as well which are listed below in the press release.
Recently Alphacool announced its Apex thermal grease with a rated thermal conductivity of 17 W/mk. This is considerably higher than the average, and anything rated above 8.5 W/mk is generally considered high performance. Alphacool accomplishes this by utilizing “nano-particles” with lower thermal impedance. The Apex Thermal Grease will be available at Alphacool’s website for $15.62 and come in a four-gram syringe. Below is Alphacool’s press release, along with additional specifications.
Alphacool has announced its Core Distro Plates for all custom water-cooling enthusiasts. Constructed of clear acrylic with chrome-plated brass fittings and addressable RGB lighting, the new Core Distro Plates are sure to look fantastic in your next build. Four variants are available with two offerings in 240 mm and two in 360 mm sizes each compatible with VPP/D5 water pumps. Pricing starts at $172.86 and is available on Alphacool's website. For complete details, see Alphacool's press release below.
Loading new replies...
