Alphacool Eiswolf 2 All-In-One GPU Cooler Announced
Alphacool has announced the release of its latest GPU All-In-One cooler, the Eiswolf 2 GPU AIO. The Eiswolf 2 features a full-cover water block, quick disconnects for expansion, an all copper radiator, and more. Alphacool plans on releasing it for sale on July 30th, 2020. For more information please read the following product release.
Alphacool presents the first full cover AIO water cooler for graphics cards. The Eiswolf 2 GPU AIO combines the advantage of a DIY water cooling with the simplicity of an expandable all-in-one water cooling. Key Features:- Alphacool Eisblock Aurora GPX DIY graphics card cooler
– Alphacool Eisblock Aurora DIY fullcover GPU cooler
– New DC-LT 2 pump
– All copper radiator
– Digitally addressable LEDs on fans and graphics card cooler
– Expandable with quick release fasteners
The core elements of every All-In-On are the cooler, the radiator and of course the pump. The new DC-LT 2 pump has been equipped with new control electronics compared to the previous model and is, among other things, much quieter in operation than its predecessor.
The radiator is a NexXxoS ST30 240 mm copper radiator, one of the most popular DIY radiators on the market. The Alphacool Aurora Lux Pro 120 mm fans are used as fans. They have comprehensive 5V digital RGB lighting. These LEDs are also used in the graphics card cooler.
The GPU block is a real Eisblock Aurora that Alphacool offers for DIY custom loops. The only difference is that the terminal has been replaced by the discreet pump unit. This means that Alphacool can offer all custom graphics card models that also receive a normal DIY water cooler as Eiswolf 2 coolers also. This means that you get an AIO unit that has no disadvantages in cooling performance compared to DIY water coolers.
The new pump unit takes only about 5 mm more space in width and reflects the new design features of Alphacool. Clear edges, a flowing design that will fit in with the rest of the product range. This will be a new feature of all future products at Alphacool.
The Eiswolf 2 is expandable thanks to the quick-release fasteners and can be connected to all existing AIO solutions and pre-filled systems from Alphacool. Compatibility with other Alphacool products:
– All Eisbaer AIO systems
– All prefilled radiators
– All Extension Sets
Further products to extend the loop will follow.Alphacool will offer different models for different graphics cards. For the market launch there will be Eiswolf 2 models for the following graphics cards:AMD models with the PCB design of the:
– AMD RX 5700 Reference Design
– AMD RX 5700XT Reference DesignNvidia models with the PCB design of the:- Nvidia Geforce RTX 2080TI FE
– Nvidia Geforce RTX 2070 FE
– Nvidia Geforce RTX 2080 Super FE
– Nvidia Geforce RTX 2070 Super FE
More Eiswolf 2 models for custom PCB designs will follow shortly. In addition, there will also be prefilled models that can be equipped with a prefilled radiator as desired. Corresponding prefilled radiators are currently available in sizes 240, 280 and 360 mm. The RRP price is: 199,95 €
Technical Data
Voltage12V / 0,25A
Power consumption3W
Speed2300 rpm
Flow rate130 L/h
Pressure head0,7 m
Technical Data Radiator
MaterialCopper, brass (connection thread)
Dimension278 x 124 x 30 mm
Hose length40 cm
Technical Data Fans Eiszyklon Lux Pro Digital RGB
Power consumption4,8W (+ 2W LEDs)
Fan voltage12V DC
Voltage LEDs5V DC
Speed range800 – 2000 rpm
Pressure2 mm H2O
Connection4-Pin PWM
Compatibility list with over 70 graphics cards for the Eiswolf 2 AIO – 240 mm RTX2080/2080TI FE (2070 & 2080 Super):
https://www.alphacool.com/download/Eiswolf2_Compatibility_List_Nvidia.pdf
Compatibility list with 15 graphics cards for the Eiswolf 2 AIO – 240 mm RX 5700/5700XT Reference:
http://www.alphacool.com/download/Eiswolf2_Compatibility_List_AMD.pdf
Landingpage for Eiswolf 2: https://www.alphacool.com/alphacool-eiswolf-2-gpu-aio
(product links will work at: 30.07.2020 9am CEST)
 MSRP: 194,94€
-John Nester (Blaylock)
About John Nester 399 Articles
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Loading new replies...
Avatar of Overclockers.com
3,224 messages 219 likes
Alphacool has announced the release of its latest GPU All-In-One cooler, the Eiswolf 2 GPU AIO. The Eiswolf 2 features a full cover waterblock, quick disconnects for expandability, an all copper radiator, and more. Alphacool plans on releasing it for sale on July 30th, 2020.
Click here to view the article.
Reply Like
